Using XSD API with DOM [message #55042] |
Tue, 23 November 2004 10:20  |
Originally posted by: ooi.de.ibm.com
I am currently trying to use the xsd API with DOM to generate XML files
which do not only contain the schema element.Is it possible to use these
the xsd API and the DOM API together in the same Java Implementation? if
not,how do i go about this situation?
Thank you.
Re: Using XSD API with DOM [message #55221 is a reply to message #55194] |
Thu, 25 November 2004 06:51  |
--------------060807050408030108000804
HT,
When you call setElement with an element you constructed, it builds a
model to reflects exactly what's in that element and it discards all the
other information you might have set up that does not reflect what's in
the element. So your invalid blank element wipes out all the other
settings you did. If you are going to create a valid element manually,
you need to make sure to use createElementNS to give it the right
namespace and you'll need to create an xmlns declaration for that
namespace.
In this scenario, you should have done something like this:
Document document;
XSDSchema xsdSchema = XSDFactory.eINSTANCE.createXSDSchema();
xsdSchema.setDocument(document);
xsdSchema.setTargetNamespace("http://www.eclipse.org/xsd/examples/createxsd");
java.util.Map qNamePrefixToNamespaceMap =
xsdSchema.getQNamePrefixToNamespaceMap();
qNamePrefixToNamespaceMap.put(xsdSchema.getSchemaForSchemaQN amePrefix(),
XSDConstants.SCHEMA_FOR_SCHEMA_URI_2001);
qNamePrefixToNamespaceMap.put("createxsd",
xsdSchema.getTargetNamespace());
xsdSchema.updateElement();
I.e., give the schema the document you want it to use to create elements
and let it do all the work of creating the DOM. Failing that, create a
correct DOM, set it to the schema, and then do other settings, which
will write through to update the DOM. (I would generally avoid using
the null prefix for the schema for schema namespace, since that makes
the null namespace inaccessible, if it's needed.)
HT Ooi wrote:
> Hi Ed,
> I'm tried using :
> Document document;
> Element schemaElement = (Element) document.createElement("schema");
> document.appendChild(schemaElement);
> xsdSchema.setElement(schemaElement);
> but the output in my file is just :
> <?xml version="1.0" encoding="UTF-8" ?> <schema />
> instead of using the above (writing schema directly into file ) i have :
> <?xml version="1.0" ?> <xsd:schema
> xmlns:xsd="http://www.w3.org/2001/XMLSchema" />
> why is there a difference?
> the reason i want to do this is because i am using WSDL4J to create
> WSDLs and schema elements can only be represented as DOM elements.
> Thank you.
<html>
<head>
http-equiv="Content-Type">
<title></title>
</head>
HT,<br>
<br>
the other information you might have set up that does not reflect
what's in the element.
Re: Using XSD API with DOM [message #592619 is a reply to message #55042] |
Tue, 23 November 2004 10:28  |
Hee,
I'm not sure I understand. The XSD model uses DOM itself, so certainly
XSD and DOM can be used in the same application. The XSD model can be
used to load a .wsdl file which contains embedded schemas, but I'm not
sure if that is what you are driving at...
Hee Tatt Ooi wrote:
> Hello,
> files which do not only contain the schema element.Is it possible to
> use these the xsd API and the DOM API together in the same Java
> Implementation? if not,how do i go about this situation?
> Thank you.
Re: Using XSD API with DOM [message #592640 is a reply to message #55068] |
Tue, 23 November 2004 11:04  |
How do i use xsd and dom together? i mean can i convert my XSDSchema to a
Element so i can write in into my wsdl? or when reading a wsdl using DOM ,
how do i convert the schema Element into a XSDSchema instance..
Thanks.
HT.
Re: Using XSD API with DOM [message #592661 is a reply to message #55115] |
Tue, 23 November 2004 12:32  |
--------------000308080106090905030907
HT,
Have a look at org.eclipse.xsd.util.XSDPrototypicalSchema. In
particular, look at printComponent and createElement. You probably will
want to try registering the XSD resource factory to handle wsdl like this
resourceSet.getResourceFactoryRegistry().getExtensionToFacto ryMap().put
("wsdl", new XSDResourceFactoryImpl());
and then try loading a .wsdl file just as you would load a .xsd file...
HT Ooi wrote:
> to a Element so i can write in into my wsdl? or when reading a wsdl
> using DOM , how do i convert the schema Element into a XSDSchema
> instance..
> Thanks.
> HT.
<html>
<head>
</head>
HT,<br>
<br>
Re: Using XSD API with DOM [message #592674 is a reply to message #55168] |
Thu, 25 November 2004 04:22  |
Hi Ed,
I'm tried using :
Document document;
qNamePrefixToNamespaceMap.put("createxsd", xsdSchema.getTargetNamespace());
<schema />
<xsd:schema xmlns:xsd="http://www.w3.org/2001/XMLSchema" />
the reason i want to do this is because i am using WSDL4J to create WSDLs
Thank you.
Re: Using XSD API with DOM [message #592685 is a reply to message #55194] |
HT,
namespace.
Document document;
HT Ooi wrote:
> Hi Ed,
> I'm tried using :
> Document document;
> Thank you.
<html>
<head>
<title></title>
</head>
HT,<br>
<br>
FUDForum. Page generated in 0.02774 seconds
