Home » Eclipse Projects » Equinox » Class Loading Architecture
Class Loading Architecture [message #55001] Fri, 16 December 2005 08:35 Go to next message
Originally posted by: chs.tipas.at
OSGi_R4.core.pdf -> 3.4 Class Loading Architecture defines the "class
space".
It further points out:
"A class space must be consistent, such that it never contains two classes
with the same fully qualified name (to prevent Class Cast Exceptions). "
I have tested this with a simple example Plugin A, B and C.
B and C exports the same class in the same package. A creates a dependency
to B and C.
It perfectly runs at least with my eclipse 3.1.0 installation.
It also fits the deep first search, if B requires C the class from C is
loaded.
Is this a defined behaviour for equinox or is there any strict mode that
avoids this feature ?
Re: Class Loading Architecture [message #57638 is a reply to message #55001] Mon, 23 January 2006 23:10 Go to previous messageGo to next message
Originally posted by: jeff_nospam_mcaffer.ca.ibm.com
This is expected behaviour. Is it causing you a problem?
Jeff
"Chris Schaefer" <chs@tipas.at> wrote in message
news:dnufru$ls9$1@news.eclipse.org...
> space".
> to B and C.
> loaded.
Re: Class Loading Architecture [message #57937 is a reply to message #57638] Tue, 24 January 2006 05:05 Go to previous messageGo to next message
it does not cause a problem if it is known.
But it does not reflect the osgi standard in reflect to the "consistency of
the class space" ?
"Jeff McAffer" <jeff_nospam_mcaffer@ca.ibm.com> schrieb im Newsbeitrag
news:dr49ap$r1m$1@utils.eclipse.org...
> Jeff
>> space".
>> classes
>> dependency
>> to B and C.
>> loaded.
Re: Class Loading Architecture [message #58189 is a reply to message #57937] Thu, 26 January 2006 09:00 Go to previous message
Might be best to enter a bug report in the Eclipse/Equinox bugzilla with
some example code. I'm not quite seeing the problem.
Jeff
news:dr4u5f$10t$1@utils.eclipse.org...
of
> the class space" ?
> > Jeff
> >> space".
> >> classes
> >> dependency
> >> to B and C.
> >> loaded.
that
Previous Topic:How to resolve the PATH containing the OSGi's DLL
Next Topic:Bundle-RequiredExecutionEnvironment: supported in 3.1/3.2?
Current Time: Tue Sep 16 16:23:08 EDT 2025
Powered by FUDForum. Page generated in 0.03293 seconds
