Home » Archived » Test and Performance Tools Platform (TPTP) » RAServer failed to start
RAServer failed to start [message #54965] Sun, 26 February 2006 07:44 Go to next message
Hi Group,
I've problems to get the Agent Controller to start. I'm using linux and
followed the instructions. I set the LD_LIBRARY_PATH variable and set the
bin folder to PATH. Then I run the configuration.
The next would be to start the controller with RAStart.sh but it always
tells me: "RAServer failed to start".
Without any other information.
As I looked into the servicelog I found the following error log:
"Cannot create master named pipe: ramaster. Make sure the named pipe is free
and no other Agent Controller is using the same named pipe."
So I tried to delete the /tmp/IBMRAC/ramaster and start the RAStart.sh
again, but with the same result.
Whats going wrong?
Please help me, I ran out of ideas.
Andreas
Re: RAServer failed to start [message #55019 is a reply to message #54965] Mon, 27 February 2006 07:25 Go to previous messageGo to next message
Can you check the following?
1. If "/tmp/IBMRAC" writable by all user (mode 777)
2. If "/tmp/IBMRAC/ramaster" is recreated after you run "RAStart.sh" the
second time
3. You Linux distribution and kernel version
You can generate a detailed log by editing the Agent Controller's
"config/serviceconfig.xml" file and change the "loggingLevel" attribute
to "DEBUG". Rerun "RAStart.sh" and you can check the log for more
detailed information.
Samson
Andreas Heinecke wrote:
> Hi Group,
> Whats going wrong?
> Andreas
Re: RAServer failed to start [message #55349 is a reply to message #55019] Tue, 28 February 2006 03:47 Go to previous messageGo to next message
thanks for your answer.
You asked for the following:
Yes, it is.
> second time
Yes, ramaster is recreated after I run RAStart.sh the second time.
I use an Fedora Core 4 with a self compiled kernel 2.6.12.1.
The log tells:
"Cannot resolve the host name of the local machine. Ensure the fully
qualified host name of the local machine is registered with the Domain Name
Server (DNS)."
and
The other log entries are no error messages, as far as I can see.
Andreas
Samson Wai wrote:
> second time
> Samson
>> Hi Group,
>> free and no other Agent Controller is using the same named pipe."
>> Whats going wrong?
>> Andreas
Re: RAServer failed to start [message #55454 is a reply to message #55349] Tue, 28 February 2006 07:47 Go to previous messageGo to next message
This still doesn't work. Why is it so complicated to get this thing running?
I recently read about IAC. How can I use this? Am I right, that using IAC
will keep me from using RAC, if profiling on the same machine?
The problem is now that I dont know how to configure TPTP to use the IAC
instead of the RAC.
Andreas
> Yes, it is.
>> second time
> The log tells:
> Name Server (DNS)."
> and
> Andreas
> Samson Wai wrote:
>> second time
>> Regards,
>> Samson
>>> Hi Group,
>>> the bin folder to PATH. Then I run the configuration.
>>> Whats going wrong?
>>> Andreas
Re: RAServer failed to start [message #55537 is a reply to message #55454] Tue, 28 February 2006 12:52 Go to previous messageGo to next message
The IAC itself does not require any configuration at all. Unlike the Agent
Controller, which requires the user to enter information such as the path
for the Java executable, the IAC will determine the required information
from Eclipse workbench during startup.
To use the IAC:
1) Run --> Profile --> External Java Application
2) In the host tab select: Local Direct Connection rather than localhost
3) Specify the Class name, Class path under the Main tab
4) Profile
Thay
Re: RAServer failed to start [message #55780 is a reply to message #55537] Wed, 01 March 2006 02:55 Go to previous message
thank you very much for your help. Finally I solved the problem.
@Samson: The problem was a misconfiguration of my hostname. My hostname
couldn't be resolved by /etc/hosts, because it wasn't listed there. After
fixing this the Agent started.
@Thay: Thank you for your help in getting the IAC to run. This works, too.
Andreas
> To use the IAC:
> 4) Profile
> Regards
> Thay
Previous Topic:NullPointerException when trying to view Coverage Statistics
Next Topic:AGR Test Case playback problem with dialog box
Current Time: Thu Nov 06 12:21:37 EST 2025
Powered by FUDForum. Page generated in 0.03494 seconds
