Re: [bug?] problem with xsi:nil [message #54963 is a reply to message #54936] |
Thu, 08 January 2009 22:34 ![Go to previous message Go to previous message](theme/Solstice/images/up.png) |
Ed Merks![Friend of Eclipse Friend](/donate/web-api/friends_decorator.php?email=ed.merks%40gmail.com) Messages: 33170 Registered: July 2009 |
Mauro,
I imagine that's because xsi:nil and xsi:type have special "meta
meaning" in the XML instance and hence aren't treated like any other
attribute. The <name xsi:nil="true"/> will be treated as if the name
were set to null, which would look the same as there being no name at
all. Likely that's the root of the issue...
mauro wrote:
> I think I hit a strange bug... using the transformation
> <c:get select="/name" />
> on
> <name xsi:nil="true" />
> I get the error:
> templates/main.jet(1,1): <c:get select="/name">
> Error: XPath expression returned no result
> while it works for any other namespace/attribute:
> <name any:nil="true" />
> <name xsi:any="true" />
> <name nil="true" />
> <name any="true" />
> any idea on the reason why?
Ed Merks
FUDForum. Page generated in 0.03901 seconds
