On publishing and reporting [message #4894] |
Mon, 10 March 2008 19:03 |
[Michael Fox said]
- I don't think only text based requirements documents are sufficient.
You need to be able to pull requirements into a document that conforms
to corporate layout standards and contains other content material.
Most of these are in MS-Word today, but you could look into ODF.
Since you're creating XML, this may be large an exercise in transforms.
- BIRT integration is essential (I'm on the BIRT PMC, so I have to say that)
- You may also need exports to PDF, MS-Excel
Joel Rosi-Schwartz
Etish Limited [http://www.etish.org]
/ o,o \ The proud parents of Useme
|) ::: (| The Open Requirements Management Tool
====w=w==== [https://useme.dev.java.net]
Re: On publishing and reporting [message #4962 is a reply to message #4894] |
On 2008-03-10 19:03:01 +0000, Joel Rosi-Schwartz
<Joel.Rosi-Schwartz@Etish.org> said:
> [Michael Fox said]
Absolutely. Would you be interested in working on ORMF and leading the
reporting and publishing efforts. Btw, I am not kidding?
B. and Joel
Joel Rosi-Schwartz
Re: On publishing and reporting [message #561777 is a reply to message #4894] |
> [Michael Fox said]
B. and Joel
Joel Rosi-Schwartz
FUDForum. Page generated in 0.03696 seconds
