Home » Modeling » M2T (model-to-text transformation) » JET, custom XPAth function and iterating through the nodes which get passed in.
JET, custom XPAth function and iterating through the nodes which get passed in. [message #54800] |
Wed, 07 January 2009 10:02 ![Go to next message Go to next message](theme/Solstice/images/down.png) |
Originally posted by: johannes.nel.gmail.com
HI All
First of, I am generating from an xml doc without a schema at this stage.
I have a custom xpath function which gets a nodeset. I iterate through
the nodeset
//CODE///
NodeSet o = (NodeSet)args.get(0);
//Element controlElement = (Element));
Iterator it = o.iterator();
String s = "";
while(it.hasNext())
EObject e = (EObject)it.next();
//CODE END///
I get back a an EObject, but would like to be able to access the nodes
attributes (where each item I am iterating over is a node with a
collection of attributes). All casts I have tried thus far have failed ,
this should be something really silly easy but I am failing at this
currently.
In short, how do I cast the EObject to something from which I can access
the attributes specified in the xml.
Johan
Re: JET, custom XPAth function and iterating through the nodes which get passed in. [message #54855 is a reply to message #54800] |
Thu, 08 January 2009 06:56 ![Go to previous message Go to previous message](theme/Solstice/images/up.png) ![Go to next message Go to next message](theme/Solstice/images/down.png) |
I hacked this with some brutally ugly string parsing, but its crappy and
prone to break (understatement). I would love some pointers on this,
pretty please.
Johannes Nel wrote:
> HI All
> the nodeset
> //CODE///
> String s = "";
> while(it.hasNext())
> //CODE END///
> currently.
> Thanks
> Johan
Re: JET, custom XPAth function and iterating through the nodes which get passed in. [message #54883 is a reply to message #54855] |
Thu, 08 January 2009 11:43 ![Go to previous message Go to previous message](theme/Solstice/images/up.png) ![Go to next message Go to next message](theme/Solstice/images/down.png) |
Ed Merks![Friend of Eclipse Friend](/donate/web-api/friends_decorator.php?email=ed.merks%40gmail.com) Messages: 33196 Registered: July 2009 |
--------------020205070407000900030105
Johan,
This article will likely help:
< http://www.theserverside.com/tt/articles/article.tss?l=Bindi ngXMLJava>
I suppose these EObjects instances of AnyType? You can cast to that
interface then, and process with the feature map for the attributes...
In general, given an EObject x that's not a subclass of anything more
concrete, you can use x.eClass().getEAllStructuralFeatures() and for
each one, call x.eGet(feature). Of course each feature will have a
name, and you can use ExtendedMetaData.INSTANCE to access underlying XML
details, like the namespace of the feature...
> and prone to break (understatement). I would love some pointers on
> this, pretty please.
> Johannes Nel wrote:
>> HI All
>> stage.
>> through the nodeset
>> //CODE///
>> String s = "";
>> while(it.hasNext())
>> //CODE END///
>> nodes attributes (where each item I am iterating over is a node with
>> a collection of attributes). All casts I have tried thus far have
>> failed , this should be something really silly easy but I am failing
>> at this currently.
>> access the attributes specified in the xml.
>> Thanks
>> Johan
<html>
<head>
</head>
Johan,<br>
<br>
This article will likely help:<a
href=" http://www.theserverside.com/tt/articles/article.tss?l=Bindi ngXMLJava"><br>
</a>
<blockquote><a
href=" http://www.theserverside.com/tt/articles/article.tss?l=Bindi ngXMLJava"> http://www.theserverside.com/tt/articles/article.tss?l=Bindi ngXMLJava</a><br>
</blockquote>
interface then, and process with the feature map for the attributes...<br>
<br>
XML details, like the namespace of the feature...<br>
<br>
<br>
Johannes Nel wrote:
<blockquote cite="mid:gk483n$otq$1@build.eclipse.org" type="cite">I
pretty please.
<br>
<br>
Johannes Nel wrote:
<br>
<blockquote type="cite">HI All
<br>
<br>
stage.
<br>
the nodeset
<br>
//CODE///
<br>
<br>
<br>
<br>
String s = "";
<br>
while(it.hasNext())
<br>
<br>
<br>
//CODE END///
<br>
, this should be something really silly easy but I am failing at this
currently.
<br>
<br>
<br>
<br>
<br>
Johan
<br>
</blockquote>
</blockquote>
</body>
</html>
--------------020205070407000900030105--
Ed Merks
Re: JET, custom XPAth function and iterating through the nodes which get passed in. [message #54909 is a reply to message #54883] |
Thu, 08 January 2009 16:27 ![Go to previous message Go to previous message](theme/Solstice/images/up.png) ![Go to next message Go to next message](theme/Solstice/images/down.png) |
my naviety with java shows now, but I cannot seem to find the Anytype,
what package do i need to include?
I currently have emf, emf.codegen emf.codegen.ecore and jet (other what
I would see in a normal plugin project)
Ed Merks wrote:
> Johan,
>> Johannes Nel wrote:
>>> HI All
>>> stage.
>>> through the nodeset
>>> //CODE///
>>> String s = "";
>>> while(it.hasNext())
>>> //CODE END///
>>> at this currently.
>>> Thanks
>>> Johan
Re: JET, custom XPAth function and iterating through the nodes which get passed in. [message #55150 is a reply to message #54883] |
Mon, 12 January 2009 14:43 ![Go to previous message Go to previous message](theme/Solstice/images/up.png) ![Go to next message Go to next message](theme/Solstice/images/down.png) |
Paul Elder![Friend of Eclipse Friend](/donate/web-api/friends_decorator.php?email=pelder%40ca.ibm.com) Messages: 849 Registered: July 2009 |
------=_NextPart_000_001A_01C9749A.36DB5820
charset="iso-8859-1"
Johannes (& Ed):
It is almost certainly an AnyType object. But before you go down that =
road, let me make a couple of alternative suggestions:
Alternative 1 (This requires JET 0.9.0 or later)
Change JET's model loader to XML DOM. That way, what you'll receive in =
your function is org.w3c.dom.Node and sub-types. To do this,
Open your JET transforms plugin.xml, go the the Extensions tab. Expand =
and select the '(transform') element, and enter 'org.eclipse.jet.xml' =
(without the quotes) in the modelLoader field.
Alternative 2
Use the JET XPath engine to navigate the node-set. The best example of =
doing this is the sort() function that was introduced in JET 0.9. Here's =
a link to the source:
http://dev.eclipse.org/viewcvs/index.cgi/org.eclipse.m2t/org .eclipse.jet/=
plugins/org.eclipse.jet/src/org/eclipse/jet/internal/xpath/f unctions/extr=
as/SortFunction.java?revision=3D1.1&root=3DModeling_Proj ect&view=3Dmarkup=
Alternative 3
Explain what you'd like to do in your function. Maybe we can figure out =
a way to do this via something less complex. Or maybe, this is something =
that requires some enhancement to JET.
Paul
<HTML><HEAD>
<META content=3D"MSHTML 6.00.2900.3492" name=3DGENERATOR>
<STYLE></STYLE>
</HEAD>
<DIV><FONT face=3DArial size=3D2>Johannes (& Ed):</FONT></DIV>
<DIV><FONT face=3DArial size=3D2></FONT> </DIV>
<DIV><FONT face=3DArial size=3D2>It is almost certainly an AnyType =
object. But=20
before you go down that road, let me make a couple of alternative=20
suggestions:</FONT></DIV>
<DIV><FONT face=3DArial size=3D2>Alternative 1 (This requires JET 0.9.0 =
or=20
later)</FONT></DIV>
<DIV><FONT face=3DArial size=3D2>-----------------</FONT></DIV>
<DIV><FONT face=3DArial size=3D2>Change JET's model loader to XML DOM. =
That way,=20
what you'll receive in your function is org.w3c.dom.Node and sub-types. =
To do=20
this,</FONT></DIV>
<DIV><FONT face=3DArial size=3D2>Open your JET transforms plugin.xml, go =
the the=20
Extensions tab. Expand and select the '(transform') element, and enter=20
'org.eclipse.jet.xml' (without the quotes) in the modelLoader=20
field.</FONT></DIV>
<DIV><FONT face=3DArial size=3D2>Alternative 2</FONT></DIV>
<DIV><FONT face=3DArial size=3D2>------------------</FONT></DIV>
<DIV><FONT face=3DArial size=3D2>Use the JET XPath engine to navigate =
the node-set.=20
The best example of doing this is the sort() function that was =
introduced in JET=20
0.9. Here's a link to the source:</FONT></DIV>
<DIV><FONT face=3DArial size=3D2><A=20
href=3D" http://dev.eclipse.org/viewcvs/index.cgi/org.eclipse.m2t/org .ecli=
pse.jet/plugins/org.eclipse.jet/src/org/eclipse/jet/internal /xpath/functi=
ons/extras/SortFunction.java?revision=3D1.1&root=3DM odeling_Project&a=
mp;view=3Dmarkup">http://dev.eclipse.org/viewcvs/index.cgi/org.eclipse.m2=
t/org.eclipse.jet/plugins/org.eclipse.jet/src/org/eclipse/je t/internal/xp=
ath/functions/extras/SortFunction.java?revision=3D1.1&am p;root=3DModeling=
_Project&view=3Dmarkup</A></FONT></DIV>
<DIV><FONT face=3DArial size=3D2>Alternative 3</FONT></DIV>
<DIV><FONT face=3DArial size=3D2>Explain what you'd like to do in your =
function.=20
Maybe we can figure out a way to do this via something less complex. Or =
maybe,=20
this is something that requires some enhancement to JET.</FONT></DIV>
<DIV><FONT face=3DArial size=3D2>Paul</FONT></DIV></BODY></HTML>
------=_NextPart_000_001A_01C9749A.36DB5820--
Current Time: Fri Aug 16 17:22:37 GMT 2024
Powered by FUDForum. Page generated in 0.04239 seconds
