Home » Archived » EPF » 500 Internal Server Error (epfwiki)
500 Internal Server Error (epfwiki) [message #54780] Wed, 26 November 2008 11:39 Go to next message
I followed the installation steps of epfwiki but when I load the page
epfwiki an error message appears:Status: 500 Internal Server Error
Content-Type: text/html
Can you help me?
Re: 500 Internal Server Error (epfwiki) [message #54833 is a reply to message #54780] Thu, 27 November 2008 05:06 Go to previous messageGo to next message
You should look in the log files for additional information.
The Apache logs probably don't contain more than the 500 error but just
check them to be sure [Your instantRails install dir]\apache\logs
The info we need is most likely in
[YOur instantRails install dir]\EPFWiki\log\production.log
Are you sure you didn't miss a step? The guide is tried and tested by now
I think.
Best Regards,
Onno
Re: 500 Internal Server Error (epfwiki) [message #54914 is a reply to message #54833] Mon, 01 December 2008 05:16 Go to previous messageGo to next message
The problem is in the connection with DataBase.
but I meet another problemme : the installation of UnxUtils.
when I test the command under unzip DOS it does not work.
configure my SMTP [message #54940 is a reply to message #54914] Mon, 15 December 2008 05:42 Go to previous message
How do I configure my SMTP with Telnet to send messages?
Re: 500 Internal Server Error (epfwiki) [message #591042 is a reply to message #54780] Thu, 27 November 2008 05:06 Go to previous message
I think.
Best Regards,
Onno
Re: 500 Internal Server Error (epfwiki) [message #591070 is a reply to message #54833] Mon, 01 December 2008 05:16 Go to previous message
configure my SMTP [message #591078 is a reply to message #54914] Mon, 15 December 2008 05:42 Go to previous message
Previous Topic:Duplicate links in Related Element section (Task and Task Descriptor)
Next Topic:Use of raw content/license
Current Time: Sun Apr 27 01:15:07 EDT 2025
Powered by FUDForum. Page generated in 0.03276 seconds
