Home » Eclipse Projects » Plugin Development Environment (PDE) » Build Error: ${launcherName}.app\Contents\MacOS not found
Build Error: ${launcherName}.app\Contents\MacOS not found [message #54765] Mon, 13 April 2009 17:55 Go to next message
Dear, All,
In our PDE ant build, there is an error with macosx build. The error
message is: ${launcherName}.app\Contents\MacOS not found.
It happens only with macosx build. The win32, linux-x86, and linux-x86_64
build are fine. Any idea what's going on? The error happens recently. It
used to working greatly.
Thank you so much! Have a nice day!
Best Regards,
Frank
More detailed information:
[java] BUILD FAILED
[java]
C:\plugin-build\build-target-3.4.1\eclipse\plugins\org.eclip se.pde.build_3.4.1.R34x_v20080805\scripts\productBuild\produ ctBuild.xml:30:
The following error occurred while executing this line:
[java]
C:\plugin-build\build-target-3.4.1\eclipse\plugins\org.eclip se.pde.build_3.4.1.R34x_v20080805\scripts\build.xml:91:
[java]
C:\plugin-build\build-target-3.4.1\eclipse\plugins\org.eclip se.pde.build_3.4.1.R34x_v20080805\templates\headless-build\c ustomTargets.xml:12:
[java]
C:\plugin-build\build-target-3.4.1\eclipse\plugins\org.eclip se.pde.build_3.4.1.R34x_v20080805\scripts\productBuild\allEl ements.xml:10:
[java]
C:\plugin-build\build-target-3.4.1\eclipse\plugins\org.eclip se.pde.build_3.4.1.R34x_v20080805\scripts\genericTargets.xml :158:
[java]
C:\plugin-build\workbench.build\assemble.org.eclipse.pde.bui ld.container.feature.all.xml:26:
[java]
C:\plugin-build\workbench.build\assemble.org.eclipse.pde.bui ld.container.feature.all.xml:15:
[java]
C:\plugin-build\build-target-3.4.1\eclipse\plugins\org.eclip se.pde.build_3.4.1.R34x_v20080805\scripts\productBuild\allEl ements.xml:114:
[java]
C:\plugin-build\workbench.build\assemble.org.eclipse.pde.bui ld.container.feature.macosx.carbon.ppc.xml:124:
C:\plugin-build\workbench.build\tmp\AnalystWorkbench\macosx. carbon.ppc\AnalystWorkbench\${launcherName}.app\Contents\Mac OS
not found.
[java] Total time: 46 seconds
Re: Build Error: ${launcherName}.app\Contents\MacOS not found [message #54876 is a reply to message #54765] Tue, 14 April 2009 09:19 Go to previous messageGo to next message
Try setting "Launcher Name" on the "Launching" tab in the .product editor.
Frank Du wrote:
> Dear, All,
> linux-x86_64 build are fine. Any idea what's going on? The error happens
> recently. It used to working greatly.
> Best Regards,
> Frank
> [java] BUILD FAILED
> [java]
> [java]
> [java]
> [java]
> [java]
> [java]
> [java]
> [java]
> [java]
> not found.
Re: Build Error: ${launcherName}.app\Contents\MacOS not found [message #55012 is a reply to message #54876] Tue, 14 April 2009 14:14 Go to previous message
Hi Andrew,
Thanks so much! It fixed the problem. Accidentally I recreated the product
definition and forgot to set the name.
Best Regards,
Frank Du
Re: Build Error: ${launcherName}.app\Contents\MacOS not found [message #595073 is a reply to message #54765] Tue, 14 April 2009 09:19 Go to previous message
Frank Du wrote:
> Dear, All,
> Best Regards,
> Frank
> [java] BUILD FAILED
> [java]
> [java]
> [java]
> [java]
> [java]
> [java]
> [java]
> [java]
> [java]
> not found.
Re: Build Error: ${launcherName}.app\Contents\MacOS not found [message #595127 is a reply to message #54876] Tue, 14 April 2009 14:14 Go to previous message
Hi Andrew,
Best Regards,
Frank Du
Previous Topic:A dependency question
Next Topic:PDE director throws signature exception
Current Time: Wed Apr 16 11:51:50 EDT 2025
Powered by FUDForum. Page generated in 0.02559 seconds
