Re: erratic behaviour re. obsolete project references [message #54923 is a reply to message #54652] |
Tue, 12 July 2005 09:46 ![Go to previous message Go to previous message](theme/Solstice/images/up.png) |
Originally posted by: mchapman.uk.ibm.com
Hi Macheal,
This is clearly a bug. Please can you raise this in bugzilla, with the
exact steps required to reproduce.
Matt.
On Fri, 08 Jul 2005 01:07:04 +0200, Michael Moser wrote:
> I had the strange case here, that - whenever I rebuilt my project - AJDT
> popped up an error telling me
> AspectJ error:
> Error creating marker
> reason:
> Reource /<other_project>/..../<SomeFile>.java does not exist.
> I indeed previously had "imported" (i.e. referenced) that
> <other_project> from my now aspectized current project, but - to improve
> the behaviour of the aspect visualizer - in the meantime I now "linked"
> the source of <other_project> into my current project (according to the
> "Using linked source folders" chapter in the online help), so that
> <other_project> should nowhere be referenced any more in the current
> project.
> But that error kept reappearing each time when I did a rebuild! In the
> end I desperately deleted the <other_project> from eclipse (of course
> without deleting its content...) and only after that the error popup had
> finally gone.
> So - apparently - AspectJ keeps around some old reference to a
> previously referenced project, even after removing it from the
> build-path and obviously that reference even survives (several!) "Build
> clean"s.
> Michael
Matt Chapman
AJDT Development, http://www.eclipse.org/ajdt
Re: erratic behaviour re. obsolete project references [message #589403 is a reply to message #54652] |
Matt Chapman![Friend of Eclipse Friend](/donate/web-api/friends_decorator.php?email=mpchapman%40gmail.com) Messages: 429 Registered: July 2009 |
Hi Macheal,
Matt.
> AspectJ error:
> reason:
> project.
> finally gone.
> clean"s.
> Michael
Matt Chapman
FUDForum. Page generated in 0.02965 seconds
