Home » Modeling » TMF (Xtext) » Unicode literals in Xtext grammar
Re: Unicode literals in Xtext grammar [message #55062 is a reply to message #54734] |
Fri, 03 July 2009 01:41 ![Go to previous message Go to previous message](theme/Solstice/images/up.png) ![Go to next message Go to next message](theme/Solstice/images/down.png) |
Peter Becker![Friend of Eclipse Friend](/donate/web-api/friends_decorator.php?email=peter%40peterbecker.de) Messages: 4 Registered: July 2009 |
Junior Member |
Hello Sebastian,
thanks for that hint, but I am a bit confused. As far as I understand a
value converter is equivalent to a production rule in the grammar. If that
is correct, I would have to write a value converter per unicode character or
range referenced, wouldn't I? As far as I can tell there is no way to
parametrize the converter.
With the BIG_DECIMAL example, the BIG_DECIMAL rule means "any big decimal".
But what I would need is "a unicode character between $1 and $2" -- I would
need to pass the two values defining the range. Or define a separate converter
per range.
I might just skip the unicode ranges for now -- I'm just using OWL2
Functional Syntax as a test case anyway, no real need for unicode just yet.
I assume you have escaped unicode literals on a feature request somewhere?
Or should I file something?
Peter
Sebastian Zarnekow wrote:
> Hi Peter,
> the 0.7.0 release of Xtext has no out-of-the-box support for escaped
> unicode signs in a string literal.
> You may want to override the value convert to handle unicode gracefully.
> See here:
> http://www.eclipse.org/Xtext/documentation/0_7_0/xtext.html# valueconverter
> Sebastian
> Am 02.07.2009 7:55 Uhr, schrieb Peter Becker:
>> Hello,
>> newbie question: how do I express unicode literals in an Xtext grammar?
>> What I want to do is to map some W3C recommendations into Xtext and they
>> contain production rules such as this one:
>> PN_CHARS_BASE ::= [A-Z] | [a-z] | [#x00C0-#x00D6] | [#x00D8-#x00F6] |
>> [#x00F8-#x02FF] | [#x0370-#x037D] | [#x037F-#x1FFF] | [#x200C-#x200D] |
>> [#x2070-#x218F] | [#x2C00-#x2FEF] | [#x3001-#xD7FF] | [#xF900-#xFDCF] |
>> [#xFDF0-#xFFFD] | [#x10000-#xEFFFF]
>> ( http://www.w3.org/TR/2008/REC-rdf-sparql-query-20080115/#rPN _CHARS_BASE)
>> I expected to be able to use the Java literal notation as in
>> "('\u00C0'..'\u00d6')" for the third clause, but that doesn't seem to
>> work.
>> BTW: is there some reference documentation that I am missing (e.g. the
>> grammar for Xtext grammars)?
>> Regards,
>> Peter
Re: Unicode literals in Xtext grammar [message #55113 is a reply to message #55062] |
Fri, 03 July 2009 06:45 ![Go to previous message Go to previous message](theme/Solstice/images/up.png) |
Sebastian Zarnekow![Friend of Eclipse Friend](/donate/web-api/friends_decorator.php?email=sebastian.zarnekow%40gmail.com) Messages: 3118 Registered: July 2009 |
Hi Peter,
sorry, I got you initial post wrong.
Even if value converters are a way to go, if you want to use unicode
characters in your own dsl, they cannot help with the grammar language.
You may want subscribe yourself this one here
https://bugs.eclipse.org/bugs/show_bug.cgi?id=280659 , so you'll be
notified when it's done.
Sebastian
Am 03.07.2009 3:41 Uhr, schrieb Peter Becker:
> Hello Sebastian,
> per range.
> Peter
>> Hi Peter,
>> See here:
>> Regards,
>> Sebastian
>>> Hello,
>>> work.
>>> Regards,
>>> Peter
Current Time: Mon Jul 22 05:32:27 GMT 2024
Powered by FUDForum. Page generated in 0.04364 seconds
