Home » Archived » Test and Performance Tools Platform (TPTP) » AGR Test Case playback problem with dialog box
Re: AGR Test Case playback problem with dialog box [message #54504 is a reply to message #54449] |
Thu, 23 February 2006 22:11 |
No real name Messages: 404 Registered: July 2009 |
Is the dialog org.eclipse.jface.dialogs.MessageDialog? If so, then it
should be able to record it. I have tested this out before. I know that
dialogs that are of type org.eclipse.swt.widgets.MessageBox won't be
recorded - see the post below:
Hi Stephan,
Yes, you're right. The MessageBox is a native dialog, but MessageDialog
isn't.
You can use a message dialog as follows:
MessageDialog md = new MessageDialog
(HelloWorldPlugin.getDefault().getWorkbench().getActiveWorkb enchWindow().get
Shell(), "Title", null, "Message", MessageDialog.NONE, new String[]{"Yes",
"No"}, 0);
return md.open() == 0;
Unfortunately I can't think of any other workarounds that you can use
without the need to change your code.
Thanks.
"Stephan Lips" <stephan.lips@xxxxxxxx> wrote in message
news:dru1sg$e92$1@xxxxxxxxe.org...
Greetings,
we use using AGR/TPTP 4.1 in Eclipse 3.1. A scenario I am automating
involves a simple confirmation dialog that is invoked by the plugin under
test as follows
MessageBox replicate = new MessageBox(getShell(), SWT.YES | SWT.NO);
replicate.setMessage(REP_MSG_1);
replicate.setText(REP_MSG_2);
return replicate.open() == SWT.YES;
When recording the scenario, AGR fails to recognize the replicate
dialog/record any interaction with it, subsequent test execution fails
with
the message 'Timeout occured [...] This is likely caused by the presence
of an unexpected dialog'.
Is the SWT MessageBox a 'native' dialog as described in the AGR manual,
section 1.2 'Known Limitations and Workarounds', and/or is there any
workaround? I would like to think that simple yes/no confirmation dialogs
such as the one I am looking at are a pretty common occurence and there is
away to make AGR work with it.
Thanks much for any insight!
- Stephan
"Heidi Gumpert" <hgumpert@qnx.com> wrote in message
news:dtki93$ktc$1@utils.eclipse.org...
> Hi All,
> I am encoutering problems when playing back my recorded Test Cases.
> I am going through a wizard in one of our plug-ins and the last dialog box
> asks if you want to build the imported project now. When I record it I
> click yes and I can see the MakeFile evoked and displayed in the console
as
> it builds. When I play it back (in both execution and in quick-run) it
> hangs on that last dialog box. I can still see the project building in
the
> console, but the dialog box remains. I have build-automatically turned
off
> and I know it is a JFace dialog box.
> I have tried this on both TPTP 4.2 (4.2.0-200602220100) with Eclipse 3.2
M5
> and also with TPTP 4.1 with Eclipse 3.2 M4.
> If anyone has any suggestions I would be very grateful!
> Thanks in advance!
> Heidi
Re: AGR Test Case playback problem with dialog box [message #54648 is a reply to message #54504] |
Fri, 24 February 2006 15:35 |
Heidi Gumpert Messages: 13 Registered: July 2009 |
Junior Member |
Hi Ali,
Thanks for helping me out.
The dialog is an "org.eclipse.jface.dialogs.MessageDialog". I also found
another dialog box that is of this type and it also behaves in this manner
during playback. (the one that comes up when you try to close a file that
hasn't been saved yet)
The information is being recorded in the macro. Perhaps the problem lies
within the playback.
Heidi
"Ali Mehregani" <amehrega@ca.ibm.com> wrote in message
news:dtlbut$sl8$1@utils.eclipse.org...
> Hi Stephan,
> isn't.
> "No"}, 0);
> Thanks.
> Greetings,
> test as follows
> with
> dialogs
> is
> - Stephan
>> Hi All,
>> box
> as
> the
> off
> M5
>> Thanks in advance!
>> Heidi
Re: AGR Test Case playback problem with dialog box [message #54911 is a reply to message #54648] |
Fri, 24 February 2006 22:26 |
Good to hear that it's recorded. Can you post your macro to this thread? I
just tested this with Feb 22nd driver and it worked fine when I attempted to
close a *text* file that was marked dirty. It didn't have a problem
invoking the "no" button in the message dialog that prompts the user to
save.
Place a <command type="wait" time-to-wait="5000"/> just before the
close-workbenchpart command to ensure that the editor is marked dirty. I
should say that there is a little catch if you are testing this with a Java
file. The Eclipse Java editor will only expand the import clause after the
first modify. Repeating the modify command will fix this. This of course
shouldn't be a problem if you are attempting to edit a text file.
Here's the macro for editing a text file and clicking no when prompted to
save:
<macro version="0.1" >
<shell id="org.eclipse.ui.internal.WorkbenchWindow" return-code="-1">
<command type="item-select"
contextId="view/org.eclipse.jdt.ui.PackageExplorer"
widgetId="org.eclipse.swt.widgets.Tree#{{/}}-{{1.0}}">
<item
path=" org.eclipse.swt.widgets.TreeItem#{{/Plugin/test-resources/my file.txt}}
-{{1.0}}"/>
</command>
<command type="focus"
widgetId="org.eclipse.swt.widgets.Composite#1"/>
<command type="default-select"
<item
-{{1.0}}"/>
</command>
<command type="wait"/>
<command type="modify"
contextId="editor/org.eclipse.ui.DefaultTextEditor/myfile.txt "
widgetId="org.eclipse.swt.custom.StyledText#1">
<![CDATA[blah]]>
</command>
<command type="close-workbenchpart" contextId="editor"
widgetId="org.eclipse.ui.DefaultTextEditor/myfile.txt"/>
<shell id="org.eclipse.jface.dialogs.MessageDialog" return-code="1">
<command type="select" contextId="shell"
widgetId="org.eclipse.swt.widgets.Button#{{1}}-{{1.0}}"/>
</shell>
</shell>
</macro>
news:dtn93n$stl$1@utils.eclipse.org...
> Hi Ali,
> Heidi
that
> > Hi Stephan,
> > isn't.
String[]{"Yes",
> > "No"}, 0);
> > Thanks.
> > Greetings,
under
> > test as follows
SWT.NO);
> > with
presence
> > dialogs
> > is
> > - Stephan
> >> Hi All,
> >> box
console
> > as
> > the
> > off
3.2
> > M5
> >> Thanks in advance!
> >> Heidi
Re: AGR Test Case playback problem with dialog box [message #55184 is a reply to message #54911] |
Mon, 27 February 2006 16:45 |
Junior Member |
This is my macro for testing the MessageDialog. It does not have any
dependencies, so it should run it as is.
I asked my co-worker to test this macro, and he was also not able to select
the "No" in the save MessageDialog box.
Thanks so much!
Heidi
<command type="select" contextId="menus"
widgetId=" org.eclipse.ui.actions.NewWizardMenu#{{&File-&am p;New	Alt+Shift+N-P&roject...}}-{{0.8}}{{0|0 |0}}-{{0.6}}{{true}}-{{0.1}}{{5}}-{{0.1}}{{first}}-{{0.2}}{{ separator}}-{{0.2}} ">
<parent widgetId="file"/>
<parent widgetId="new"/>
</command>
<shell id="org.eclipse.jface.wizard.WizardDialog" return-code="0">
contextId="wizard-page/newWizardSelectionPage"
widgetId="org.eclipse.swt.widgets.Tree#1">
<item
path=" org.eclipse.swt.widgets.TreeItem#{{org.eclipse.pde.ui.NewPro jectWizard}}-{{1.0}} "/>
</command>
widgetId="org.eclipse.swt.widgets.Tree#1"/>
<command type="select" contextId="wizard"
widgetId="org.eclipse.swt.widgets.Button#{{15}}-{{1.0}}"/>
<command type="modify" contextId="wizard-page/main"
widgetId="org.eclipse.swt.widgets.Text#1">
<![CDATA[test]]>
</command>
widgetId="org.eclipse.swt.widgets.Button#{{16}}-{{1.0}}"/>
<shell id="org.eclipse.jface.dialogs.MessageDialogWithToggle"
return-code="2">
widgetId="org.eclipse.swt.widgets.Button#{{2}}-{{1.0}}"/>
</shell>
</shell>
contextId="editor/org.eclipse.pde.ui.manifestEditor/MANIFEST.MF "
widgetId="org.eclipse.swt.widgets.Text#5">
<![CDATA[gdgd]]>
</command>
widgetId=" org.eclipse.jface.action.ActionContributionItem#{{&F ile-&Close	Ctrl+W}}-{{0.8}}{{0|3}}-{{0.6}}{{ false}}-{{0.1}}{{31}}-{{0.1}}{{separator}}-{{0.2}}{{C&am p;lose
All	Ctrl+Shift+W}}-{{0.2}}">
</command>
widgetId="org.eclipse.pde.ui.manifestEditor/MANIFEST.MF"/>
</shell>
</shell>
</macro>
news:dto17p$nal$1@utils.eclipse.org...
> I
> to
> save.
> Java
> the
> save:
> <item
> -{{1.0}}"/>
> </command>
> <item
> -{{1.0}}"/>
> </command>
> <![CDATA[blah]]>
> </command>
> </shell>
> </shell>
> </macro>
>> Hi Ali,
>> manner
>> Heidi
> that
>> > Hi Stephan,
>> > MessageDialog
>> > isn't.
> String[]{"Yes",
>> > "No"}, 0);
>> > Thanks.
>> > Greetings,
> under
>> > test as follows
> SWT.NO);
>> > with
> presence
>> > manual,
>> > dialogs
>> > there
>> > is
>> > - Stephan
>> >> Hi All,
>> >> box
>> >> I
> console
>> > as
>> >> it
>> >> in
>> > the
>> >> turned
>> > off
> 3.2
>> > M5
>> >> Thanks in advance!
>> >> Heidi
Re: AGR Test Case playback problem with dialog box [message #55591 is a reply to message #55184] |
Tue, 28 February 2006 20:01 |
The problem is caused because the recorder not only records your File >
Close selection, but it also records a close-workbenchpart command.
Here's a version of your macro that will work:
Shift+N-P&roject...}}-{{0.8}}{{0|0|0}}-{{0.6}}{{true }}-{{0.1}}{{5}}-{{0.
1}}{{first}}-{{0.2}}{{separator}}-{{0.2}}">
</command>
<item
}}-{{1.0}}"/>
</command>
<![CDATA[test]]>
</command>
return-code="2">
</shell>
</shell>
<![CDATA[gdgd]]>
</command>
<command type="wait" time-to-wait="1000"/>
lose	Ctrl+W}}-{{0.8}}{{0|3}}-{{0.6}}{{false}}-{{0.1} }{{31}}-{{0.1}}{{sep
arator}}-{{0.2}}{{C&lose All	Ctrl+Shift+W}}-{{0.2}}">
</command>
</shell>
</shell>
</macro>
I have re-opened defect https://bugs.eclipse.org/bugs/show_bug.cgi?id=110810
to try and fix this.
news:dtvab4$r8u$1@utils.eclipse.org...
select
> Thanks so much!
> Heidi
> </command>
> <item
}}-{{1.0}}"/>
> </command>
> <![CDATA[test]]>
> </command>
> return-code="2">
> </shell>
> </shell>
> <![CDATA[gdgd]]>
> </command>
> </command>
> </shell>
> </shell>
> </macro>
thread?
> > I
attempted
> > to
> > save.
I
> > Java
> > the
course
to
> > save:
> > <item
> > -{{1.0}}"/>
> > </command>
> > <item
> > -{{1.0}}"/>
> > </command>
> > <![CDATA[blah]]>
> > </command>
return-code="1">
> > </shell>
> > </shell>
> > </macro>
> >> Hi Ali,
found
> >> manner
that
lies
> >> Heidi
it
> > that
> >> > Hi Stephan,
> >> > MessageDialog
> >> > isn't.
> > String[]{"Yes",
> >> > "No"}, 0);
> >> > Thanks.
> >> > Greetings,
automating
> > under
> >> > test as follows
> > SWT.NO);
fails
> >> > with
> > presence
> >> > manual,
> >> > dialogs
> >> > there
> >> > is
> >> > - Stephan
> >> >> Hi All,
dialog
> >> >> box
it
> >> >> I
> > console
> >> > as
> >> >> it
> >> >> in
> >> > the
> >> >> turned
> >> > off
> > 3.2
> >> > M5
> >> >> Thanks in advance!
> >> >> Heidi
Re: AGR Test Case playback problem with dialog box [message #55891 is a reply to message #55591] |
Wed, 01 March 2006 15:00 |
Junior Member |
Hi Ali
Thanks for the fix. That macro works now! :D
However, that was not the problem in my macro. I was able to fix it though.
Here was my macro running through a wizard of one of my company's plug-ins:
widgetId=" org.eclipse.jface.action.ActionContributionItem#{{&P roject-Build
Auto&matically}}-{{0.8}}{{5|7}}-{{0.6}}{{false}}-{{0 .1}}{{12}}-{{0.1}}{{Clea&n...}}-{{0.2}}{{separator}} -{{0.2}} "
selection="false">
<parent widgetId="project"/>
</command>
widgetId=" org.eclipse.jface.action.ActionContributionItem#{{&F ile-&Import...}}-{{0.8}}{{0|20}}-{{0.6}}{{true}}-{{0 .1}}{{31}}-{{0.1}}{{separator}}-{{0.2}}{{Exp&ort...} }-{{0.2}} ">
</command>
<command type="item-expand"
contextId="wizard-page/importExportPage"
widgetId="org.eclipse.swt.widgets.Tree#1" value="false">
<item
path=" org.eclipse.swt.widgets.TreeItem#{{org.eclipse.ui.Other}}-{{ 1.0}} "/>
</command>
<item
</command>
widgetId="org.eclipse.swt.widgets.Tree#1" value="true">
<item
</command>
<item
path=" org.eclipse.swt.widgets.TreeItem#{{com.qnx.tools.ide.package s.BSPImportWizard}}-{{1.0}} "/>
</command>
<command type="item-select" contextId="wizard-page/Packages"
widgetId="org.eclipse.swt.widgets.Table#1">
<item path="com.qnx.tools.ide.packages.core.PackageContainer0"/>
</command>
<command type="modify" contextId="wizard-page/WorkingSet"
widgetId="org.eclipse.swt.widgets.Text#2">
<![CDATA[C:/TPTPM5a/workspace]]>
</command>
</shell>
***</shell>
***<shell id="org.eclipse.ui.internal.WorkbenchWindow" return-code="-1">
<shell id="org.eclipse.jface.dialogs.MessageDialog" return-code="0">
widgetId="org.eclipse.swt.widgets.Button#{{0}}-{{1.0}}"/>
</shell>
</shell>
</macro>
I removed the two lines indicated with "***", and it worked. I don't know
if there is or has been any issues with recording and playing back TestCases
that go through a similar wizard. Hopefully this can help someone running
into a similar problem.
Thanks for all the help Ali!
Heidi
news:du2a7d$fum$1@utils.eclipse.org...
> </command>
> <item
> }}-{{1.0}}"/>
> </command>
> <![CDATA[test]]>
> </command>
> return-code="2">
> </shell>
> </shell>
> <![CDATA[gdgd]]>
> </command>
> </command>
> </shell>
> </shell>
> </macro>
> select
>> Thanks so much!
>> Heidi
>> </command>
>> <item
> }}-{{1.0}}"/>
>> </command>
>> <![CDATA[test]]>
>> </command>
>> return-code="2">
>> </shell>
>> </shell>
>> <![CDATA[gdgd]]>
>> </command>
>> </command>
>> return-code="1">
>> </shell>
>> </shell>
>> </macro>
> thread?
>> > I
> attempted
>> > to
>> > save.
> I
>> > Java
>> > the
> course
> to
>> > save:
>> > <item
>> > -{{1.0}}"/>
>> > </command>
>> > <item
>> > -{{1.0}}"/>
>> > </command>
>> > <![CDATA[blah]]>
>> > </command>
> return-code="1">
>> > </shell>
>> > </shell>
>> > </macro>
>> >> Hi Ali,
> found
>> >> manner
> that
> lies
>> >> Heidi
> it
>> > that
>> >> > Hi Stephan,
>> >> > MessageDialog
>> >> > isn't.
>> > String[]{"Yes",
>> >> > "No"}, 0);
>> >> > use
>> >> > Thanks.
>> >> > Greetings,
> automating
>> > under
>> >> > test as follows
>> > SWT.NO);
> fails
>> >> > with
>> > presence
>> >> > manual,
>> >> > any
>> >> > dialogs
>> >> > there
>> >> > is
>> >> > - Stephan
>> >> >> Hi All,
> dialog
>> >> >> box
> it
>> >> >> I
>> > console
>> >> > as
>> >> >> quick-run)
>> >> >> it
>> >> >> building
>> >> >> in
>> >> > the
>> >> >> turned
>> >> > off
>> >> >> Eclipse
>> > 3.2
>> >> > M5
>> >> >> Thanks in advance!
>> >> >> Heidi
Current Time: Sat Jul 27 16:22:35 GMT 2024
Powered by FUDForum. Page generated in 0.04815 seconds
