Home » Archived » Visual Editor (VE) » GridbagLayout problems
GridbagLayout problems [message #54371] |
Wed, 04 August 2004 03:04  |
I am having trouble getting the visual editor to layout components in a
gridbaglayout the way they should. All I want is a grid with 4 components:
2 of equal height on the left, and on the right, one small component
followed by one large component. In ascii:
| comp 1 comp 2
| comp 3
| comp 4
Currently, I have comp1 with grid height 2, comp 2 with grid height 1,
comp 4 with grid height 1, and comp 3 with grid height 2. But no matter
how I adjust sizes, comp 1 and comp 2 are always identically sized, as are
comp 4 and comp 3. Is this something wrong with the VE, or something I
don't understand about GridBagLayout?
Oh, and I also just switched to M2, and I've noticed that you can no
longer double click a label/button to set its text. Is this a bug or a
feature?
Re: GridbagLayout problems [message #54454 is a reply to message #54371] |
Wed, 04 August 2004 10:01   |
Hi Eric,
This is a fairly odd situation. The reason you're not getting the
behavior you're expecting is that there's nothing in the second row to
define its height, so the row has a height of 0. After a little fooling
around I came up with a way to get what I think you want.
Set the constraints of the components as follows:
1: x: 0, y: 0, grid height: 2, weight y: 1, fill: vertical
2: x: 1, y: 0, grid height: 1, weight y: 0, fill: none
3: x: 1, y: 1, grid height: 3, weight y: 1, fill: vertical
4: x: 0, y: 2, grid height: 2, weight y: 1, fill: vertical
Direct editing should still work, but the activation is by selecting
something twice, not double clicking. If you double click it may happen
too quickly for it to register as double selection. (it's supposed to
work the same way you can rename a file in Windows Explorer by double
selecting the file)
Hope this helps,
- Jeff
> | comp 1 comp 2
> | comp 3
> | comp 4
> feature?
Re: GridbagLayout problems [message #54677 is a reply to message #54454] |
Wed, 04 August 2004 20:36  |
Thank you, for both answers. Indeed, all I needed to do was turn the
y-weight of component 2 to 0, and problem solved. In my humble opinion,
this is a bit of a flaw in the design of GridBagLayout, but oh well, can't
have everything you want.
Jeff Myers wrote:
> Hi Eric,
> selecting the file)
> Hope this helps,
> - Jeff
> > | comp 1 comp 2
> > | comp 3
> > | comp 4
> > feature?
Re: GridbagLayout problems [message #596699 is a reply to message #54371] |
Hi Eric,
selecting the file)
Hope this helps,
- Jeff
> | comp 1 comp 2
> | comp 3
> | comp 4
> feature?
Re: GridbagLayout problems [message #596768 is a reply to message #54454] |
Jeff Myers wrote:
> Hi Eric,
> selecting the file)
> Hope this helps,
> - Jeff
> > | comp 1 comp 2
> > | comp 3
> > | comp 4
> > feature?
Current Time: Sat Oct 18 01:26:56 EDT 2025
Powered by FUDForum. Page generated in 0.03801 seconds
