Home » Archived » EPF » Display of version info?
Display of version info? [message #54333] Thu, 06 November 2008 15:53 Go to next message
Gerhard Schneider is currently offline Gerhard SchneiderFriend
Hi folks,
although there is a field "version" where we automatically put the SVN
info in, it would be nice to have that version info available for display
in the published site.
How can I do that? Is there a "legal" way to do it, or do I have to
manipulate the inner circle of EPF xsl files? And if so, how?
Thanks a lot in advance,
Gerhard
Re: Display of version info? [message #54522 is a reply to message #54333] Wed, 12 November 2008 11:04 Go to previous messageGo to next message
Gemma Bowers is currently offline Gemma BowersFriend
Hi Gerhard,
I'm not sure if this is exactly what you want, but I was looking for
something similar to show some standard information at the bottom of each
page of my published model
http://www.eclipse.org/newsportal/article.php?id=1210&gr oup=eclipse.technology.epf#1210
("OpenUP 'footer' information" post).
Perhaps this is a way that you could publish a version number?
Re: Display of version info? [message #54603 is a reply to message #54522] Wed, 19 November 2008 11:46 Go to previous messageGo to next message
Well, unfortunately not. The copyright is an "official" function of the
EPFC, as there is a field and button to select it and to display it for
publishing.
What I'm looking for is the possibility to display the information of
fields in the published version, that exist (i.e., Author, Modification
Date, Version), but that is (currently) not visible after publishing.
I assume that this is actually possible by modifying some of the XSL
sheets in some way, but which sheets and what way exactly?
Re: Display of version info? [message #55050 is a reply to message #54603] Thu, 01 January 2009 21:48 Go to previous message
jan masaryk is currently offline jan masarykFriend
Member
I think Gerhard means info about a element, not a model.
Btw.: This function is helpful for us as well.
take care,
jan masaryk
> publishing.
Re: Display of version info? [message #590935 is a reply to message #54333] Wed, 12 November 2008 11:04 Go to previous message
Hi Gerhard,
Re: Display of version info? [message #590964 is a reply to message #54522] Wed, 19 November 2008 11:46 Go to previous message
publishing.
Re: Display of version info? [message #591117 is a reply to message #54603] Thu, 01 January 2009 21:48 Go to previous message
Member
take care,
jan masaryk
> publishing.
Previous Topic:XSL Documentation?
Next Topic:Model Meta-Doc?
Current Time: Thu Dec 26 13:25:31 GMT 2024
Powered by FUDForum. Page generated in 0.03626 seconds
