Re: Can't see what's wrong [message #54336 is a reply to message #54308] |
Fri, 10 April 2009 07:09 |
Ankur Sharma Messages: 84 Registered: July 2009 |
Member |
Eric Jain wrote:
> After adding some dependencies ("Imported Packages") to a plug-in
> project, the project is no longer building (no class files generated
> when I do "Project" > "Clean..." and there is an error icon on the
> project in the Package Explorer). Quite possible that there is a problem
> with one of the dependencies, but I can't find any indication of what
> the exact error is, either in the Problems View or Error Log, in the
> manifest editor, or in the project property pages. And doing Validate
> Plug-ins in the launch configuration doesn't return an error, either...
> Where else can I look?
Does the project build if you remove those "imported packages". If yes, once remove them, do a clean rebuild. And then add the dependency again. If there an error something SHOULD come up in problems view. If not, open a bug report.
hth,
Ankur..
Re: Can't see what's wrong [message #594872 is a reply to message #54308] |
Member |
hth,
Ankur..
FUDForum. Page generated in 0.04692 seconds
