Home » Eclipse Projects » Equinox » Problems on OSX
Problems on OSX [message #54299] Tue, 06 December 2005 15:05 Go to next message
Originally posted by: pete.quantrix.com
Greetings folks,
We are using Equinox with org.eclipse.core.runtime as our plugin
framework. It works beautifully!
We are currently having some troubles with Eclipse 3.1.1 running our
applications on Mac OSX. It appears that the old StartInFirstThread
problem is looming again. In summary, if we define the following
IPlatformRunnable, and wire it up in a new plugin project on OSX, we
consistently get the stack trace in the log file appended below. This
happens with 1.4.2 as well as 1.5 (different message, though).
NOTE: the command line arguments contains -ws carbon even though my
run-config in Eclipse does NOT contain the ws setting (that's how you used
to avoid this problem or one like it).
Does anyone have any hint as to how to make this work properly in 3.1.1?
On top of this, Apple's latest 1.5 release apparently doesn't work with
AWT when launched with the eclipse osgi / core-runtime at all....
Thanks for any suggestions!
pete
peter m. murray
pete--at--quantrix--dot--com
Code:
package test.quaqua;
import javax.swing.JOptionPane;
import javax.swing.SwingUtilities;
import org.eclipse.core.runtime.IPlatformRunnable;
public class Runner implements IPlatformRunnable
public Object run(Object args) throws Exception
SwingUtilities.invokeAndWait(new Runnable()
public void run()
JOptionPane.showConfirmDialog(null, "Hello world!");
return null;
Log file:
!SESSION 2005-12-06 15:00:52.964
eclipse.buildId=unknown
java.version=1.4.2_09
java.vendor=Apple Computer, Inc.
BootLoader constants: OS=macosx, ARCH=ppc, WS=carbon, NL=en_US
Framework arguments: -application TestQuaQua.blah.balh -pdelaunch
Command-line arguments: -application TestQuaQua.blah.balh -data
/Users/pete/runtime-workspace -dev
file:/Users/pete/workspace/.metadata/.plugins/org.eclipse.pd e.core/Test
QuaQua/dev.properties -pdelaunch -os macosx -ws carbon -arch ppc
!ENTRY org.eclipse.osgi 2005-12-06 15:00:53.673
!MESSAGE Application error
!STACK 1
java.lang.InternalError: Can't start the AWT because Java was started on
the first thread. Make sure StartOnFirstThread is not specified in your
application's Info.plist or on the command line
at java.lang.ClassLoader$NativeLibrary.load(Native Method)
at java.lang.ClassLoader.loadLibrary0(ClassLoader.java:1586)
at java.lang.ClassLoader.loadLibrary(ClassLoader.java:1503)
at java.lang.Runtime.loadLibrary0(Runtime.java:788)
at java.lang.System.loadLibrary(System.java:834)
at sun.security.action.LoadLibraryAction.run(LoadLibraryAction. java:50)
at sun.awt.NativeLibLoader.loadLibraries(NativeLibLoader.java:3 8)
at sun.awt.DebugHelper.<clinit>(DebugHelper.java:29)
at java.awt.EventQueue.<clinit>(EventQueue.java:83)
at javax.swing.SwingUtilities.invokeAndWait(SwingUtilities.java :1225)
at test.quaqua.Runner.run(Runner.java:12)
org.eclipse.core.internal.runtime.PlatformActivator$1.run(Pl atformActivator.java:226)
org.eclipse.core.runtime.adaptor.EclipseStarter.run(EclipseS tarter.java:376)
org.eclipse.core.runtime.adaptor.EclipseStarter.run(EclipseS tarter.java:163)
at org.eclipse.core.launcher.Main.invokeFramework(Main.java:334 )
at org.eclipse.core.launcher.Main.basicRun(Main.java:278)
at org.eclipse.core.launcher.Main.run(Main.java:973)
at org.eclipse.core.launcher.Main.main(Main.java:948)
Re: Problems on OSX [message #54718 is a reply to message #54299] Mon, 12 December 2005 18:08 Go to previous message
Originally posted by: jeff_nospam_mcaffer.ca.ibm.com
Peter,
Looks interesting. Can you submit a bug report in the Equinox/Framework
component with the details?
Jeff
"Peter Murray" <pete@quantrix.com> wrote in message
news:fd1558a1c39616e67a1be6ebe69e0742$1@www.eclipse.org...
> Greetings folks,
> Cheers,
> pete
> peter m. murray
> Code:
> public void run()
> return null;
> Log file:
> !STACK 1
> at java.security.AccessController.doPrivileged(Native Method)
> at
java:226)
> at
> at
> at
> at
..java:25)
Previous Topic:Using standalone OSGI bundles in Eclipse
Next Topic:equinox vs. standard Plug-in Project
Current Time: Fri Apr 25 21:19:35 EDT 2025
Powered by FUDForum. Page generated in 0.03113 seconds
