Home » Language IDEs » AspectJ » Wait till september for Eclipse 3.1
Wait till september for Eclipse 3.1 [message #54284] Fri, 01 July 2005 13:15 Go to next message
David  Pérez is currently offline David PérezFriend
Do I have to wait till the end of september, for being able to use AJDT
from Eclipse 3.1?
Is there any workaround?
JADT 1.2 complains if I try to use it from Eclipse 3.1.
Re: Wait till september for Eclipse 3.1 [message #54310 is a reply to message #54284] Fri, 01 July 2005 14:18 Go to previous messageGo to next message
Originally posted by: hawkinsh.uk.ibm.com
No, there is a version of AJDT which works with Eclipse 3.1. You will need
to use a different URL for the update site. For more details see the AJDT
download page:
http://www.eclipse.org/ajdt/downloads/
Thanks, Helen
Re: Wait till september for Eclipse 3.1 [message #54337 is a reply to message #54284] Fri, 01 July 2005 14:23 Go to previous messageGo to next message
Originally posted by: mchapman.uk.ibm.com
> from Eclipse 3.1?
You do have to wait til September for a release version of AspectJ 5 and
AJDT 1.3. But you can use AJDT on Eclipse 3.1 today, by picking up the
latest development build, from here:
http://www.eclipse.org/ajdt/downloads/#dev
These builds contain everything from AJDT 1.2, plus a little extra, as we
develop towards upcoming releases 1.2.1 for Eclipse 3.0 and 1.3 for
Eclipse 3.1. Of course they are classified as development build, not
release builds, because they are not as well tested as release builds. But
they are fairly widely used, and we have an ever-expanding test suite
which is run against each build.
Matt.
Matt Chapman
AJDT Development, http://www.eclipse.org/ajdt
Re: Wait till september for Eclipse 3.1 [message #54364 is a reply to message #54337] Mon, 04 July 2005 06:56 Go to previous messageGo to next message
Thanks, this is good news. :-)
Re: Wait till september for Eclipse 3.1 [message #54388 is a reply to message #54337] Mon, 04 July 2005 08:08 Go to previous messageGo to next message
>>from Eclipse 3.1?
> Matt.
Matt,
I thought AJDT 1.2.1 would be the official release for Eclipse 3.1 but
you sound like we have to wait until AJDT 1.3. Is that correct ?
Re: Wait till september for Eclipse 3.1 [message #54410 is a reply to message #54388] Mon, 04 July 2005 08:40 Go to previous message
On Mon, 04 Jul 2005 10:08:34 +0200, Sébastien Alonzo wrote:
> Matt,
Sébastien,
The AJDT 1.2 release stream is to be for Eclipse 3.0 only. The current
development builds do have 1.2.1.xxxx build IDs, for both Eclipse 3.0 and
3.1, but before we can get to a release version for Eclipse 3.1, we need
to branch the codebase in order to make some 3.1-specific changes. So AJDT
1.2.1 will be for Eclipse 3.0, and AJDT 1.3 will be for Eclipse 3.1. In
addition, AJDT 1.3 will also be the official release for AspectJ 5, and we
plan to release as soon after the AspectJ 5 release as possible - hence
the September date.
Matt.
Matt Chapman
Re: Wait till september for Eclipse 3.1 [message #589134 is a reply to message #54284] Fri, 01 July 2005 14:18 Go to previous message
download page:
Thanks, Helen
Re: Wait till september for Eclipse 3.1 [message #589144 is a reply to message #54284] Fri, 01 July 2005 14:23 Go to previous message
Matt Chapman is currently offline Matt ChapmanFriend
> from Eclipse 3.1?
Matt.
Matt Chapman
Re: Wait till september for Eclipse 3.1 [message #589151 is a reply to message #54337] Mon, 04 July 2005 06:56 Go to previous message
Re: Wait till september for Eclipse 3.1 [message #589160 is a reply to message #54337] Mon, 04 July 2005 08:08 Go to previous message
>>from Eclipse 3.1?
> Matt.
Matt,
Re: Wait till september for Eclipse 3.1 [message #589171 is a reply to message #54388] Mon, 04 July 2005 08:40 Go to previous message
> Matt,
Sébastien,
the September date.
Matt.
Matt Chapman
Previous Topic:Wait till september for Eclipse 3.1
Next Topic:Question to AJDT developers: reusing JTD plugin.
Current Time: Sat Nov 09 03:24:24 GMT 2024
Powered by FUDForum. Page generated in 0.03500 seconds
