Custom Java Project Wizard [message #438] |
Sun, 20 April 2003 03:48 |
Originally posted by: ewoojava.hotmail.com
I am trying to create a project wizard for creating Custom Java Project
Wizard that will automatically include serveral build paths. What is the
class should I be used to extend from?
Re: Custom Java Project Wizard [message #5001 is a reply to message #628] |
Wed, 23 April 2003 02:06 |
Martin Aeschlimann wrote:
> You have to create your own wizard but you can reuse the
> 'WizardNewProjectCreationPage'.
> In org.eclipse.jdt.ui.tests (in the eclipse CVS repository) look for the
> example class 'MyProjectCreationWizard'.
> In 'updatePage' you would modify
> 'fJavaPage.init(jproject, null, null, false);'
> to define the build path you want by default.
> Martin
> Note that this discussion should go to eclipse.tools.jdt
FUDForum. Page generated in 0.24136 seconds
