Install problem on Debian Linux [message #4819] |
Thu, 13 December 2001 12:37  |
Yes I know that Debian is probably not a supported environment, but
I have a rather basic problem which I thought someone might know the
answer to.
Having unziped cdt into the plugin directory, I then changed to
com.ibm.dstore.core and typed "make dev". Nothing happened, it
just hing. So I got inquisitive and tried "make -d dev" and it
got as far as reading the makefile, but no further. I am running
GNU Make 3.79.1 if that makes a difference, and have rebuild
X Free, KDE and the kernel on this box, so it should be set up
right.
Re: SOLVED Re: Install problem on Debian Linux [message #5164 is a reply to message #4958] |
Thu, 13 December 2001 16:01  |
Since our build has a Java version dependency, it would make sense
for us to check the Java version and tell you if it is wrong.
We'll add this to our suggestions list.
Brian Thomson
David Goodenough wrote:
> Fixed it, my fault. I was using the wrong Java (1.1.8) rather than
> 1.3 as it was the default in my path. When I overrode the path it
> worked happily.
FUDForum. Page generated in 0.02342 seconds
