TargetMetaFeature [message #53936] |
Fri, 22 September 2006 13:38 ![Go to next message Go to next message](theme/Solstice/images/down.png) |
Originally posted by: matthias.thiel.atip.de
I'm trying to generate a plugin (or the source code of it) from an XSD file
by using the tutorial.
I generated the gmftool, gmfgraph, gmfmap and gmfgen files, but the
eclipse environment tells me that the targetMetaFeature in the gmfgen file
is missing (in links->modelFacet).
I would like to add it, but currently I have no understanding of the
gmfgen file and what a targetMetaFeature is, so I want to ask, if anyone
could explain it or if there is a documentation about the semantic of
these XML tags ?
Thanks in advance,
Matthias Thiel
Re: TargetMetaFeature [message #54058 is a reply to message #53936] |
Fri, 22 September 2006 14:34 ![Go to previous message Go to previous message](theme/Solstice/images/up.png) ![Go to next message Go to next message](theme/Solstice/images/down.png) |
Artem Tikhomirov![Friend of Eclipse Friend](/donate/web-api/friends_decorator.php?email=tikhomirov.artem%40gmail.com) Messages: 222 Registered: July 2009 |
There's no need to modify .gmfgen, the problem should be in the .gmfmap's
LinkMapping. Check that appropriate LinkMapping (you can tell this by domain
element) specifies correct Link Meta Feature ("Target Feature") - the one
that is set when the link gets its target.
Artem
"Matthias Thiel" <matthias.thiel@atip.de> wrote in message
news:bf0cdade34398db5d9a4b6bab8445d80$1@www.eclipse.org...
> Hello,
> file
> these XML tags ?
> Thanks in advance,
> Matthias Thiel
Re: TargetMetaFeature [message #54123 is a reply to message #54058] |
Fri, 22 September 2006 15:07 ![Go to previous message Go to previous message](theme/Solstice/images/up.png) ![Go to next message Go to next message](theme/Solstice/images/down.png) |
Thank you for the fast answer.
I could resolve this problem, but now I get InvocationTargetExceptions
when trying to generate the diagram code:
!SUBENTRY 1 org.eclipse.gmf.common 4 0 2006-09-22 17:00:16.503
!MESSAGE InvocationTargetException
!STACK 0
org.eclipse.emf.codegen.jet.JETException: InvocationTargetException
org.eclipse.emf.codegen.jet.JETEmitter.generate(JETEmitter.j ava:394)
org.eclipse.emf.codegen.jet.JETEmitter.generate(JETEmitter.j ava:367)
org.eclipse.gmf.internal.common.codegen.JETEmitterAdapter.ge nerate(JETEmitterAdapter.java:35)
org.eclipse.gmf.internal.common.codegen.GeneratorBase.doGene rateJavaClass(GeneratorBase.java:325)
org.eclipse.gmf.codegen.util.Generator.internalGenerateJavaC lass(Generator.java:940)
org.eclipse.gmf.codegen.util.Generator.generateNodeGraphical NodeEditP
olicy(Generator.java:463)
org.eclipse.gmf.codegen.util.Generator.generateNode(Generato r.java:231)
org.eclipse.gmf.codegen.util.Generator.customRun(Generator.j ava:116)
org.eclipse.gmf.internal.common.codegen.GeneratorBase.doRun( GeneratorBase.java:408)
org.eclipse.gmf.internal.common.codegen.GeneratorBase.run(Ge neratorBase.java:69)
org.eclipse.gmf.internal.codegen.popup.actions.ExecuteTempla tesAction.run(ExecuteTemplatesAction.java:120)
org.eclipse.jface.operation.ModalContext$ModalContextThread. run(ModalContext.java:113)
Caused by: java.lang.reflect.InvocationTargetException
at sun.reflect.GeneratedMethodAccessor67.invoke(Unknown Source)
org.eclipse.emf.codegen.jet.JETEmitter.generate(JETEmitter.j ava:386)
... 11 more
Caused by: java.lang.NullPointerException
org.eclipse.gmf.codegen.templates.policies.NodeGraphicalNode EditPolicyGenerator.generate(NodeGraphicalNodeEditPolicyGene rator.java:89)
... 15 more
Do you have an idea ?
regards,
Matthias
> domain element) specifies correct Link Meta Feature ("Target Feature") -
> the one that is set when the link gets its target.
> Artem
>> Hello,
>> file
>> file is missing (in links->modelFacet).
>> these XML tags ?
>> Thanks in advance,
>> Matthias Thiel
Re: TargetMetaFeature [message #54278 is a reply to message #54123] |
Fri, 22 September 2006 16:31 ![Go to previous message Go to previous message](theme/Solstice/images/up.png) |
There's smth wrong with one of GenNodes, I suppose. Perhaps, missing or
incomplete ModelFacet. This should not happen if validation for your models
says OK.
Artem
news:ef0u7j$srm$1@utils.eclipse.org...
> !STACK 0
> at
> at
> at
> at
> at
> at
> at
> at
> at
> at
> at
> at
> at
> at
> ... 11 more
> at
> ... 15 more
> regards,
> Matthias
>> Artem
>>> Hello,
>>> file
>>> these XML tags ?
>>> Thanks in advance,
>>> Matthias Thiel
FUDForum. Page generated in 0.03131 seconds
