Home » Language IDEs » AspectJ » How to determine the aspectj-rt version?
Re: How to determine the aspectj-rt version? [message #54005 is a reply to message #53914] |
Mon, 27 June 2005 20:33 |
Originally posted by: mchapman.uk.ibm.com
On Mon, 27 Jun 2005 13:36:12 -0700, Barry Kaplan wrote:
> Andrew sent me a script that upgrades ajdt with the latest aspectj
> compiler (I'm testing some compiler fixes). It would be helpful if I
> could determine the version aspectj version included in the ajdt dev
> releases so I know if I have to run the script. Is this information
> available anywhere?
Hi Barry,
I don't think that information makes it into the AJDT build itself, but
the latest ajdt dev build will contain the latest version of the ajde
plugin, so you can look up when this was last updated in CVS, i.e.:
http://dev.eclipse.org/viewcvs/indextech.cgi/org.eclipse.ajd t/AJDT_src/org.aspectj.ajde/ajde.jar
which shows ajde.jar was updated on Mon Jun 20.
Matt.
Re: How to determine the aspectj-rt version? [message #54020 is a reply to message #54014] |
Tue, 28 June 2005 08:09 |
On Mon, 27 Jun 2005 14:20:34 -0700, Barry Kaplan wrote:
> Are we talking about the same thing? I'm looking for the
> aspectj-runtime/compiler version.
> -barry
I think so. The AspectJ compiler gets packaged up into the
org.aspectj.ajde plugin for use with AJDT. This is currently a manual
process - Andy takes an AspectJ build, creates the ajde.jar etc files
which make up the org.aspectj.ajde plugin, and checks that into AJDT. This
is why there isn't really a precise version number associated with the
level of AspectJ in AJDT, other than the version numbers in CVS. So as
long as you're using the latest AJDT dev build, you can find the CVS
version of AspectJ / ajde that it contains using the link in my previous
post. Then from the date of this you should be able to see whether you
need to run the script.
Hope that helps,
Matt.
Current Time: Sat Oct 19 11:47:59 GMT 2024
Powered by FUDForum. Page generated in 0.05069 seconds
