CVS keyword substitution within eclipse [message #53851] |
Tue, 13 May 2003 13:01 |
Originally posted by: dlipp.gmx.net
Hi all,
when trying to use the cvs keyword substitution within eclipse I
experience serious problems: for me it looks like the problem is the way
eclipse behaves when replacing i.e. a labeled version of a certain project
with the "head" content and vice versa.
Here's what I do:
- Add a keyword substitution tag to any file in a project under cvs
version control: i.e. $Name$
- tell eclipse what keyword substition mode to use for this ASCII resource
(i.e. -kkv).
- commit the above file to cvs what will create a new revision.
- label the whole project
- choose to replace the loaded project with this new labeled version
-> the $Name$ tag should now be extended (or replaced) by the tag name.
As far as I found out, this will only work properly when you delete the
whole project and then directly load the revision from the repository!!!
As long as you just select to replace the head contents with the labeled
version content and vice versa it seams like the eclipse cvs client checks
what revision of the file is needed, finds out that it is the same in both
cases and so will do nothing. So you'll easily get a situation where
you've loaded the file from head but the $Name$ tag gets expanded to
$Name: myTag$ or you've loaded the tag: myTag but in the file you'll only
get $Name: $ (as if you were in the head).
I did not find any bug report or comments on this issues so I wonder how
you guys can handle the keyword substitution (other than not using it at
all ;-)).
Any help appreciated
Dan
Re: CVS keyword substitution within eclipse [message #53877 is a reply to message #53851] |
Tue, 13 May 2003 15:20 |
Originally posted by: bob.news.gmx.net
To me it looks like you found a bug. Go to
https://bugs.eclipse.org/bugs/enter_bug.cgi and file it against Platform /
VCM if it's not
present already.
robert
"Daniel Lipp" <dlipp@gmx.net> schrieb im Newsbeitrag
news:b9qqal$odf$1@rogue.oti.com...
> Hi all,
project
> Here's what I do:
resource
> (i.e. -kkv).
checks
both
only
> all ;-)).
> Dan
FUDForum. Page generated in 0.02702 seconds
