Home » Eclipse Projects » GEF » NoClassDefFoundError: org/eclipse/gef/internal/FlagSupport
NoClassDefFoundError: org/eclipse/gef/internal/FlagSupport [message #53844] Sun, 12 January 2003 11:45 Go to next message
Hi!
I got a really strange error. I am writing a plugin using GEF and have made
a copy of SelectEditPartTracker to use as a starting point for a modified
version of it. I call the class AssociationLabelTracker.
First i test my class before doing any changes to the copy (other than
renaming it and its constructor). I add this to my EditPart:
public DragTracker getDragTracker(Request req) {
return new AssociationLabelTracker(this);
But when using it i get (in the runtime-workspace/.metatdata/.log):
!ENTRY org.eclipse.ui 4 4 jan 12, 2003 17:12:36.62
!MESSAGE Unhandled exception caught in event loop.
!ENTRY org.eclipse.ui 4 0 jan 12, 2003 17:12:36.62
!MESSAGE org/eclipse/gef/internal/FlagSupport
!STACK 0
java.lang.NoClassDefFoundError: org/eclipse/gef/internal/FlagSupport
se.applied.schmod.AssociationLabelTracker.resetFlags(Associa tionLabelTracker
..java:117)
at org.eclipse.gef.tools.AbstractTool.activate(AbstractTool.jav a:203)
org.eclipse.gef.tools.SelectionTool.setDragTracker(Selection Tool.java:391)
org.eclipse.gef.tools.SelectionTool.handleButtonDown(Selecti onTool.java:133)
at org.eclipse.gef.tools.AbstractTool.mouseDown(AbstractTool.ja va:674)
at org.eclipse.gef.tools.SelectionTool.mouseDown(SelectionTool. java:328)
It works fine if i return the original SelectEditPartTracker in the
getDragTracker above.
What is so special with FlagSupport? Could it be some class loader problem?
Reards,
Dag Rende
Re: NoClassDefFoundError: org/eclipse/gef/internal/FlagSupport [message #53869 is a reply to message #53844] Sun, 12 January 2003 12:37 Go to previous messageGo to next message
Originally posted by: chyliko.dev.disnet.cz
I suppose this concerns class loaders and the well-known Eclipse programming guidelines.
Classes in packages whose name contains "internal" are not meant to be used/referenced by other plugins and therefore sometimes do not get exported by the plugin classloader at runtime.
Unfortunatelly, Eclipse doesn't reflect this restrictions (e.g. only part of a plugin jar exported) during compilation, so everything compiles fine, but fails at runtime.
What you need to do is to copy class FlagSupport to somewhere where you can access it (if you need it), or maybe request making this class public in GEF.
Ondrej
Re: NoClassDefFoundError: org/eclipse/gef/internal/FlagSupport [message #53889 is a reply to message #53869] Sun, 12 January 2003 12:49 Go to previous messageGo to next message
Thank you Ondrej!
Okej GEF guys, are some classes in GEF designed to not be inheritable?
I assume this is a mistake.
Dag
"Ondrej Chylik" <chyliko@dev.disnet.cz> skrev i meddelandet
news:avs85f$22f$1@rogue.oti.com...
guidelines.
fails at runtime.
GEF.
Ondrej
Re: NoClassDefFoundError: org/eclipse/gef/internal/FlagSupport [message #54013 is a reply to message #53889] Sun, 12 January 2003 14:19 Go to previous messageGo to next message
Couldn't you just subclass SelectEditPartTracker and override the necessary methods to customize it
to your needs?
Dag Rende wrote:
> Thank you Ondrej!
> Dag
> guidelines.
> fails at runtime.
> GEF.
> Ondrej
Re: NoClassDefFoundError: org/eclipse/gef/internal/FlagSupport [message #54174 is a reply to message #54013] Mon, 13 January 2003 07:33 Go to previous message
No, it will not work if I need to check the value of flag by getFlag. A
framework that is heavily based on inheriting must of course let me call the
methods I inherit.
/Dag
"Eric Bordeau" <ebordeau@us.ibm.com> skrev i meddelandet
news:avse6b$vi7$1@rogue.oti.com...
> to your needs?
> Dag Rende wrote:
> > Thank you Ondrej!
> > Regards,
> > Dag
programming
> > guidelines.
exported
part of
but
> > fails at runtime.
can
> > GEF.
> > Regards,
> > Ondrej
Previous Topic:Testers needed for Php-Uml-Editor...
Next Topic:Editor Overview back?
Current Time: Fri Oct 17 02:57:39 EDT 2025
Powered by FUDForum. Page generated in 0.04311 seconds
