Home » Archived » EPF » Task Renaming Error
Task Renaming Error [message #53838] Thu, 02 October 2008 15:37 Go to next message
Mark is currently offline MarkFriend
I attempted to rename a task today in the right pane by changing the Name
portion of the task. I changed it from 'database' to
'database_implementation'. I received an error that said the file could
not be renamed. In the left pane, the name change is reflected. However,
the actual file is not renamed. Any ideas as to why this would be
happening? I have two other people working on the same project as me and
neither of them have this issue. Thanks.
Re: Task Renaming Error [message #53864 is a reply to message #53838] Thu, 02 October 2008 15:39 Go to previous messageGo to next message
Sorry for the double post. The first message didn't show up until just
now. Please respond to the one before. Thanks.
Re: Task Renaming Error [message #54137 is a reply to message #53864] Tue, 21 October 2008 16:10 Go to previous messageGo to next message
Shilpa Toraskar is currently offline Shilpa ToraskarFriend
Member
You can check permission on the file, file could be read-only. I think
task name is stored in plugin.xmi.
Hope it helps
Shilpa
Re: Task Renaming Error [message #54164 is a reply to message #54137] Wed, 22 October 2008 00:04 Go to previous message
Thanks. It ended up being something related to admin rights on the
computer. The problem has been fixed.
Re: Task Renaming Error [message #590673 is a reply to message #53838] Thu, 02 October 2008 15:39 Go to previous message
Re: Task Renaming Error [message #590779 is a reply to message #53864] Tue, 21 October 2008 16:10 Go to previous message
Member
Hope it helps
Shilpa
Re: Task Renaming Error [message #590789 is a reply to message #54137] Wed, 22 October 2008 00:04 Go to previous message
Previous Topic:EPF consumes all memory on Fedora 9
Next Topic:Searchability
Current Time: Thu Dec 26 13:14:22 GMT 2024
Powered by FUDForum. Page generated in 0.03621 seconds
