Home » Modeling » EMF "Technology" (Ecore Tools, EMFatic, etc) » OCL and external mehtods
Re: OCL and external mehtods [message #54065 is a reply to message #53794] |
Thu, 28 September 2006 13:25 |
Yes,
You can define a custom Environment (extending AbstractEnvironment or
EcoreEnvironment is advisable) that the parser uses to look up type names
and operation signatures. You can provide fake EOperations as though they
had been defined on your model EClassifiers, and in a corresponding custom
EvaluationEnvironment implement the evaluate(EOperation, int, Object,
Object[]) method to "invoke" your "operation".
The IOCLHelper can be initialized with an EnvironmentFactory that you
provide, which is responsible for creating Environments and
EvaluationEnvironments when the parser needs them.
HTH,
Christian
Chris Lenz wrote:
> would the following thing b possible?
> I want to do the following, I have an ocl expressions which uses a
> method outside of my Ecore model.
> maybe: OutSideHelper.checkName( self.name)
> I there a way to do this.
> Chris
Re: OCL and external mehtods [message #54920 is a reply to message #54419] |
Fri, 29 September 2006 20:16 |
Hi, Chris,
No, sorry, there isn't any programmer's guide documentation for that, yet.
This would be a great comment to add to
https://bugs.eclipse.org/bugs/show_bug.cgi?id=156360.
There is a limited example in the JUnit tests for the parser's support for
UML-isms such as States and Signals (browse the hierarchy of the
Environment interface to find it).
Christian
Chris Lenz wrote:
> Is there somewhere a guide how to work with environments.
> Or examples to work with environments?
> Thanx Chris
> Christian W. Damus schrieb:
>> Yes,
>> they had been defined on your model EClassifiers, and in a corresponding
>> custom EvaluationEnvironment implement the evaluate(EOperation, int,
>> Object, Object[]) method to "invoke" your "operation".
>> HTH,
>> Christian
>>> Chris
Re: OCL and external mehtods [message #55730 is a reply to message #54920] |
Mon, 02 October 2006 16:55 |
Chris Lenz Messages: 214 Registered: July 2009 |
I don't understand, what are states for OCL?? I found something in
OCL-Specification, but I am not sure I understand that.
To add a customized new function to OCLParser, to I have to add a new State?
I have also found lookup Pathname, which looksup the Classifiers.
"Helper.testfunction(self)"
so lookupPathname must have a Helper, is this right??
Chris
> Hi, Chris,
> Cheers,
> Christian
>> Thanx Chris
>>> Yes,
>>> HTH,
>>> Christian
>>>> Chris
Re: OCL and external mehtods [message #56156 is a reply to message #55730] |
Tue, 03 October 2006 14:32 |
OK I saved the problem: here a bit of code
public static class MyEnvironmentFactory extends
AbstractEnvironmentFactory {
public EvaluationEnvironment createEvaluationEnvironment() {
EvaluationEnvironment evalEnv = new EvalEnvironment();
evalEnv.add("help", OCLHelperFactory.eINSTANCE.createHelper());
return evalEnv;
protected Environment createEnvironment(EPackage packageContext) {
return new MyEnvironment(packageContext);
protected EClassifier asEClassifier(Object context) {
return (EClassifier) context;
protected EOperation asEOperation(Object operation) {
return (EOperation) operation;
protected EStructuralFeature asEStructuralFeature(Object property) {
return (EStructuralFeature) property;
public Environment createEnvironment(Environment parent) {
return new MyEnvironment(parent);
private static class MyEnvironment extends EcoreEnvironment {
public MyEnvironment(EPackage packageContext) {
super(packageContext);
init();
private void init() {
Variable vdcl = ExpressionsFactory.eINSTANCE.createVariable();
vdcl.setName("help");
vdcl.setType(TypeUtil.resolveType(this,
OCLHelperPackage.eINSTANCE.getEClassifier("Helper")));
// vdcl.setInitExpression(initExp);
this.addElement("help", vdcl, true);
public MyEnvironment(Environment parent) {
super(parent);
init();
protected void collectStates(EClassifier owner, List pathPrefix,
List states) {
super.collectStates(owner, pathPrefix, states);
public EClassifier lookupPathName(List names) {
if (names.get(0).equals("Helper")) {
return OCLHelperPackage.eINSTANCE.getEClassifier((String)
names.get(0));
return super.lookupPathName(names);
> Chris
>> Hi, Chris,
>> Cheers,
>> Christian
>>> Thanx Chris
>>>> Yes,
>>>> HTH,
>>>> Christian
>>>>> Chris
Re: OCL and external mehtods [message #56457 is a reply to message #55730] |
Wed, 04 October 2006 13:21 |
Hi, Chris,
States are only defined by the CompleteOCL because state machines are a UML
modeling construct, not EMOF. In UML, an OCL constraint can query what
State an instance of a particular Classifier is in (when that Classifier is
a BehavioredClassifier defining (or inheriting) at least one StateMachine.
So, as you indicated in your follow-up, these states have nothing to do with
your problem.
Christian
> State? I have also found lookup Pathname, which looksup the Classifiers.
> Chris
<snip>
Re: OCL and external mehtods [message #56484 is a reply to message #56156] |
Wed, 04 October 2006 13:24 |
Hi, Chris,
That looks good. You'll have an implicitly defined variable named 'help' in
the context of every OCL expression that you parse. That's neat!
This would be a good example to post on the EMFT Wiki page for others to
follow who need to get started with customizing environments. I should see
about getting a faq/example-sharing forum started there.
Christian
> return evalEnv;
> init();
> super(parent);
> init();
> @Override
> List states) {
> @Override
> names.get(0));
<snip>
Re: OCL and external mehtods [message #592528 is a reply to message #53794] |
Yes,
HTH,
Christian
> Chris
Re: OCL and external mehtods [message #592905 is a reply to message #54419] |
Hi, Chris,
Christian
> Thanx Chris
>> Yes,
>> HTH,
>> Christian
>>> Chris
Re: OCL and external mehtods [message #593238 is a reply to message #54920] |
Chris
> Hi, Chris,
> Cheers,
> Christian
>> Thanx Chris
>>> Yes,
>>> HTH,
>>> Christian
>>>> Chris
Re: OCL and external mehtods [message #593453 is a reply to message #55730] |
return evalEnv;
init();
super(parent);
init();
List states) {
names.get(0));
> Chris
>> Hi, Chris,
>> Cheers,
>> Christian
>>> Thanx Chris
>>>> Yes,
>>>> HTH,
>>>> Christian
>>>>> Chris
Re: OCL and external mehtods [message #593592 is a reply to message #55730] |
Hi, Chris,
your problem.
Christian
> Chris
<snip>
Re: OCL and external mehtods [message #593604 is a reply to message #56156] |
Hi, Chris,
Christian
> return evalEnv;
> init();
> super(parent);
> init();
> @Override
> List states) {
> @Override
> names.get(0));
<snip>
Current Time: Sat Sep 14 12:12:56 GMT 2024
Powered by FUDForum. Page generated in 0.04672 seconds
