EPF model broken for processes :( [message #53704] |
Wed, 17 September 2008 12:08 |
Kristian Mandrup Messages: 44 Registered: July 2009 |
Member |
Somehow my internal EPF model has become broken. Any way to reapir it?
Each time I create a new process or capability pattern I receive errors
that the references aren't valid.
It has to do with the dilaogue shown, that lets me select a default
configuration. The text shown is correct, but the ID is somehow wrong!?
--- FIX
If I Replace plugin.xmi and library with the latest from CVS history and
then Replace with latest from local history, the error go away!
Seems to be a caching problem!
I guess this is an example of why you it says in the using CVS with EPF
guide, that it is very important you refresh the EPF composers memory
cache!
Why is there not a "clean" function built in to the Composer to do this,
just like doing a clean Java build ;)
FUDForum. Page generated in 0.03214 seconds
