Not getting Chart Designer [message #53670] |
Tue, 05 July 2005 21:32 ![Go to next message Go to next message](theme/Solstice/images/down.png) |
Originally posted by: sumesh.bhagat.dwango.com
I am using eclipse 3.1 and I have all the BIRT plug-ins in my plug-in
folder.
When I am trying to design a report with chart , i get error
"The extension name "null" of element "Chart" is not found".
I don't get the chart designer ot the chart on the report to edit it.
Any help will be higlly appreciated.
Thanks in advance.
Re: Not getting Chart Designer [message #53696 is a reply to message #53670] |
Tue, 05 July 2005 22:11 ![Go to previous message Go to previous message](theme/Solstice/images/up.png) ![Go to next message Go to next message](theme/Solstice/images/down.png) |
Originally posted by: none.none.com
BIRT 1.0 does not support Eclipse 3.1. BIRT release 1.0.1 will work with
Eclipse 3.1. Please check the install instructions for BIRT 1.0 here:
http://www.eclipse.org/birt/index.php?page=build/install.htm l
David
"Sumesh" <sumesh.bhagat@dwango.com> wrote in message
news:92455ccad434b3068718f08006fa301f$1@www.eclipse.org...
>folder.
> When I am trying to design a report with chart , i get error "The
> Thanks in advance.
Re: Not getting Chart Designer [message #53774 is a reply to message #53696] |
Wed, 06 July 2005 00:12 ![Go to previous message Go to previous message](theme/Solstice/images/up.png) ![Go to next message Go to next message](theme/Solstice/images/down.png) |
Hi David
Thanks for the reponse.
I reverted back eclipse to 3.0.2.
Still no luck. I am not able to see the chart designer. When I look into
the plugins installed in eclipse via help menu, I can see all the chart
plugins are there. But I can't see any chart on the report or in the
insert menu also I don't see chart.Also its not there in property editor.
Thanks for your help.
Re: Not getting Chart Designer [message #54222 is a reply to message #53774] |
Wed, 06 July 2005 08:28 ![Go to previous message Go to previous message](theme/Solstice/images/up.png) ![Go to next message Go to next message](theme/Solstice/images/down.png) |
It seems like something has not been installed properly. Please double check
the install instructions at:
Maybe you missed the EMF plugin. Or maybe the chart plugin is disabled
(check help->software updates->manage configuration: click on the no parking
sign to see which plugins are disabled).
David
news:1d6ddefde2b4c6604b400fa55d87eb8f$1@www.eclipse.org...
> Hi David
Re: Not getting Chart Designer [message #55018 is a reply to message #54222] |
Fri, 08 July 2005 00:16 ![Go to previous message Go to previous message](theme/Solstice/images/up.png) ![Go to next message Go to next message](theme/Solstice/images/down.png) |
Hi David
I reverted eclipse back to 3.0.1 and installed EMF.
Now I am able to get the chart designer and it works.
But I am having problem with property editor. It doen't open.
Also when I create style , I can't change the font.
Here is the stack trace from .log.
!ENTRY org.eclipse.core.runtime 4 2 Jul 07, 2005 17:14:39.483
!MESSAGE Problems occurred when invoking code from plug-in:
"org.eclipse.core.runtime".
!STACK 0
org.eclipse.swt.SWTException: Widget is disposed
at org.eclipse.swt.SWT.error(SWT.java:2691)
at org.eclipse.swt.SWT.error(SWT.java:2616)
at org.eclipse.swt.SWT.error(SWT.java:2587)
at org.eclipse.swt.widgets.Widget.error(Widget.java:546)
at org.eclipse.swt.widgets.Widget.checkWidget(Widget.java:296)
at org.eclipse.swt.widgets.Control.setVisible(Control.java:2595 )
at org.eclipse.swt.widgets.TabItem.releaseChild(TabItem.java:18 0)
at org.eclipse.swt.widgets.Widget.dispose(Widget.java:480)
org.eclipse.birt.report.designer.ui.views.attributes.Default PageGenerator.createTabItems(DefaultPageGenerator.java:43)
org.eclipse.birt.report.designer.ui.views.attributes.Categor yPageGenerator.createTabItems(CategoryPageGenerator.java:218 )
org.eclipse.birt.report.designer.ui.views.attributes.Atrribu tesBuilder.createPages(AtrributesBuilder.java:66)
org.eclipse.birt.report.designer.ui.views.attributes.Attribu teView.resetTabFolder(AttributeView.java:229)
org.eclipse.birt.report.designer.ui.views.attributes.Attribu teView.selectionChanged(AttributeView.java:342)
org.eclipse.ui.internal.AbstractSelectionService$3.run(Abstr actSelectionService.java:153)
org.eclipse.core.internal.runtime.InternalPlatform.run(Inter nalPlatform.java:616)
at org.eclipse.core.runtime.Platform.run(Platform.java:747)
org.eclipse.ui.internal.AbstractSelectionService.fireSelecti on(AbstractSelectionService.java:151)
org.eclipse.ui.internal.AbstractSelectionService$1.selection Changed(AbstractSelectionService.java:66)
org.eclipse.ui.part.MultiPageSelectionProvider$1.run(MultiPa geSelectionProvider.java:70)
org.eclipse.ui.part.MultiPageSelectionProvider.fireSelection Changed(MultiPageSelectionProvider.java:68)
org.eclipse.ui.part.MultiPageEditorSite.handleSelectionChang ed(MultiPageEditorSite.java:299)
org.eclipse.ui.part.MultiPageEditorSite$1.selectionChanged(M ultiPageEditorSite.java:247)
org.eclipse.gef.ui.parts.AbstractEditPartViewer.fireSelectio nChanged(AbstractEditPartViewer.java:240)
org.eclipse.birt.report.designer.internal.ui.editors.parts.D eferredGraphicalViewer.access$001(DeferredGraphicalViewer.ja va:58)
org.eclipse.birt.report.designer.internal.ui.editors.parts.D eferredGraphicalViewer$1.run(DeferredGraphicalViewer.java:30 4)
at org.eclipse.swt.widgets.RunnableLock.run(RunnableLock.java:3 5)
org.eclipse.swt.widgets.Synchronizer.runAsyncMessages(Synchr onizer.java:106)
org.eclipse.swt.widgets.Display.runAsyncMessages(Display.jav a:2754)
org.eclipse.swt.widgets.Display.readAndDispatch(Display.java :2537)
org.eclipse.ui.internal.Workbench.runEventLoop(Workbench.jav a:1377)
at org.eclipse.ui.internal.Workbench.runUI(Workbench.java:1348)
org.eclipse.ui.internal.Workbench.createAndRunWorkbench(Work bench.java:254)
org.eclipse.ui.PlatformUI.createAndRunWorkbench(PlatformUI.j ava:141)
org.eclipse.ui.internal.ide.IDEApplication.run(IDEApplicatio n.java:96)
org.eclipse.core.internal.runtime.PlatformActivator$1.run(Pl atformActivator.java:335)
org.eclipse.core.runtime.adaptor.EclipseStarter.run(EclipseS tarter.java:273)
org.eclipse.core.runtime.adaptor.EclipseStarter.run(EclipseS tarter.java:129)
at org.eclipse.core.launcher.Main.basicRun(Main.java:185)
at org.eclipse.core.launcher.Main.run(Main.java:704)
at org.eclipse.core.launcher.Main.main(Main.java:688)
Re: Not getting Chart Designer [message #55824 is a reply to message #55018] |
Mon, 11 July 2005 08:11 ![Go to previous message Go to previous message](theme/Solstice/images/up.png) ![Go to next message Go to next message](theme/Solstice/images/down.png) |
It seems there is still something in your environment that is causing the
issue, this normally works fine.
Are you running Eclipse under Linux or Windows? If you use Linux, please
provide some details about which version you are using.
Did you make a fresh install or did you override your Eclipse file back to
3.0.1? If you did override, I suggest to create a new workspace, and if it
still doesn't work, to do a fresh install in a empty directory. Some files
of the older version might still be used.
David
news:202fb46afb0ef037843c31fed8fbc770$1@www.eclipse.org...
> Hi David
> !STACK 0
> at
> at
> at
> at
> at
> at
> at
> at
> at
> at
> at
> at
> at
> at
> at
> at
> at
> at
> at
> at
> at
> at
> at
> at
> at
> at
> at
> at
> at
> at
> at
> at
> at
> at
FUDForum. Page generated in 0.03631 seconds
