Home » Eclipse Projects » Plugin Development Environment (PDE) » Strange dependency cycle error
Strange dependency cycle error [message #53662] |
Mon, 06 April 2009 14:28 ![Go to next message Go to next message](theme/Solstice/images/down.png) |
When trying to export our RCP, we're getting a dependency cycle error,
saying PluginD > PluginU > PluginD.
The odd thing is, we can't find any dependency from PluginU to PluginD.
I've got the plugin dependency visualizer and it doesn't find any such
path; I've examined each of PluginU's dependencies and can't find any
that depend on PluginD.
I can not reference any of PluginD's classes from code in PluginU.
If I open the Plug-in Dependencies view, root it at PluginD, and set it
to show dependent plugins, it does list PluginU, but there is definitely
no reference to PluginD in PluginU's manifest.
Any hints on how to track down the source of this seemingly phantom
dependency cycle?
TIA,
Eric
Re: Strange dependency cycle error [message #53688 is a reply to message #53662] |
Mon, 06 April 2009 14:29 ![Go to previous message Go to previous message](theme/Solstice/images/up.png) ![Go to next message Go to next message](theme/Solstice/images/down.png) |
Stefan ![Friend of Eclipse Friend](/donate/web-api/friends_decorator.php?email=stefan.roeck%40googlemail.com) Messages: 316 Registered: July 2009 |
Maybe PluginD is a fragment for PluginC? Just a wild guess...
Stefan.
> dependency cycle?
> TIA,
> Eric
Re: Strange dependency cycle error [message #53713 is a reply to message #53662] |
Mon, 06 April 2009 14:46 ![Go to previous message Go to previous message](theme/Solstice/images/up.png) ![Go to next message Go to next message](theme/Solstice/images/down.png) |
> dependency cycle?
Another data point: Using the "Look for cycles in the dependency graph"
link on the Dependencies tab does not find any (tried for both plugins).
Eric
Re: Strange dependency cycle error [message #53736 is a reply to message #53688] |
Mon, 06 April 2009 14:47 ![Go to previous message Go to previous message](theme/Solstice/images/up.png) ![Go to next message Go to next message](theme/Solstice/images/down.png) |
Thanks, but neither of these is a fragment or hosts any fragments.
>> PluginD. I've got the plugin dependency visualizer and it doesn't find
>> any such path; I've examined each of PluginU's dependencies and can't
>> find any that depend on PluginD.
>> it to show dependent plugins, it does list PluginU, but there is
>> definitely no reference to PluginD in PluginU's manifest.
>> dependency cycle?
>> TIA,
>> Eric
Re: Strange dependency cycle error [message #53818 is a reply to message #53713] |
Mon, 06 April 2009 15:36 ![Go to previous message Go to previous message](theme/Solstice/images/up.png) ![Go to next message Go to next message](theme/Solstice/images/down.png) |
Andrew Niefer![Friend of Eclipse Friend](/donate/web-api/friends_decorator.php?email=aniefer%40gmail.com) Messages: 990 Registered: July 2009 |
Does perhaps PluginU depend on some other PluginZ which is re-exporting
packages from PluginD. (And PluginU also imports the packages it exports).
If you are brave and really stuck, you can try running the export under
a debugger to see how build reached the cycle.
1) In a different workspace, import org.eclipse.pde.build
2) Set a breakpoint in ClasspathComputer3_0.getClasspath when the
BundleDescription#getSymbolicName is PluginU
3) Launch a self-hosted debug instance, you can point the workspace at
your normal workspace
4) Export the product, step through the classpath resolution
Cycles are detected in addPrerequisites, you'll be interested in the
recursive loop between addPrerequisites and addPluginAndPrerequisites.
The call to PDEState.getDependentBundles is how we get the dependencies.
-Andrew
>> dependency cycle?
> Eric
Re: Strange dependency cycle error [message #53891 is a reply to message #53736] |
Mon, 06 April 2009 18:26 ![Go to previous message Go to previous message](theme/Solstice/images/up.png) ![Go to next message Go to next message](theme/Solstice/images/down.png) |
I spoke too soon; I had forgotten that our unit tests are located in
fragments (and since they don't have a fragment.xml, only a manifest.mf,
I didn't find them when I looked).
Turns out that one of the unit test fragments is hosted by PluginU, and
a new test had recently been added that depends on PluginD. Hence the cycle.
Looks like this is a bug or gap in functionality in the Dependency
Visualization, which I'll report. But does anyone else think that PDE
should do something to alert you to this problem before an export is
attempted and in a more useful way?
Eric
>>> dependency cycle?
>>> TIA,
>>> Eric
Re: Strange dependency cycle error [message #54048 is a reply to message #53891] |
Tue, 07 April 2009 07:35 ![Go to previous message Go to previous message](theme/Solstice/images/up.png) ![Go to next message Go to next message](theme/Solstice/images/down.png) |
Eric,
that's why, fragments where my first thought. Actually, I fixed a bug in
Dependency Visualizer concerning fragments some days ago - however, if
it still persists with current CVS head, please reopen 270864.
Stefan.
> cycle.
> Eric
Re: Strange dependency cycle error [message #54098 is a reply to message #54048] |
Tue, 07 April 2009 16:03 ![Go to previous message Go to previous message](theme/Solstice/images/up.png) ![Go to next message Go to next message](theme/Solstice/images/down.png) |
On 4/7/2009 3:35 AM, Stefan Roeck wrote:
> Eric,
I'm using version 0.1.0.20071004 that I installed from
http://download.eclipse.org/eclipse/pde/incubator/visualizat ion/site
So I won't be seeing any recent changes. Since we're on the topic, is
there any plan to do a new build of the visualizer and make it available
on the update site?
>> manifest.mf, I didn't find them when I looked).
>> and a new test had recently been added that depends on PluginD. Hence
>> the cycle.
>> Eric
Re: Strange dependency cycle error [message #594660 is a reply to message #53662] |
Mon, 06 April 2009 14:29 ![Go to previous message Go to previous message](theme/Solstice/images/up.png) |
Stefan.
> dependency cycle?
> TIA,
> Eric
Re: Strange dependency cycle error [message #594684 is a reply to message #53688] |
Mon, 06 April 2009 14:47 ![Go to previous message Go to previous message](theme/Solstice/images/up.png) |
Eric Rizzo![Friend of Eclipse Friend](/donate/web-api/friends_decorator.php?email=eclipse-bugs%40rizzoweb.com) Messages: 3070 Registered: July 2009 |
>> dependency cycle?
>> TIA,
>> Eric
Re: Strange dependency cycle error [message #594706 is a reply to message #53713] |
Mon, 06 April 2009 15:36 ![Go to previous message Go to previous message](theme/Solstice/images/up.png) |
-Andrew
>> dependency cycle?
> Eric
Re: Strange dependency cycle error [message #594728 is a reply to message #53736] |
Mon, 06 April 2009 18:26 ![Go to previous message Go to previous message](theme/Solstice/images/up.png) |
Eric
>>> dependency cycle?
>>> TIA,
>>> Eric
Re: Strange dependency cycle error [message #594764 is a reply to message #53891] |
Tue, 07 April 2009 07:35 ![Go to previous message Go to previous message](theme/Solstice/images/up.png) |
Eric,
Stefan.
> cycle.
> Eric
Re: Strange dependency cycle error [message #594780 is a reply to message #54048] |
Tue, 07 April 2009 16:03 ![Go to previous message Go to previous message](theme/Solstice/images/up.png) |
> Eric,
on the update site?
>> the cycle.
>> Eric
Current Time: Fri Aug 16 16:17:59 GMT 2024
Powered by FUDForum. Page generated in 0.06228 seconds
