Home » Modeling » EMF "Technology" (Ecore Tools, EMFatic, etc) » OCL Query Plugins Required
OCL Query Plugins Required [message #53613] |
Wed, 27 September 2006 09:33  |
I am trying to write an OCL query using the EMF Query tutorial , I am not
able find the class IOclQueryHelper and QueryHelper .
I have added the following plugins to my plugin dependencies ,
org.eclipse.emf.query
org.eclipse.emf.query.ocl
org.eclipse.emf.ocl
Are there any more plugins need to be added ?
Kamesh
Re: OCL Query Plugins Required [message #53947 is a reply to message #53874] |
Thu, 28 September 2006 09:16   |
Hi, Kamesh,
The IOCLHelper and Query interfaces in the EMFT OCL project are only
coincidentally similar in name to those that you were referred to by the
EMFT Query tutorial (and which do not exist). These are in no way a
replacement for that other API.
Regarding the NoClassDefFoundError on the RuleAction: are you running your
example below in an Eclipse instance? If not, the you will have to extract
the lpgjavaruntime.jar file from the emft-ocl-SDK-1.0.1.jar file (or
whatever version you are using) and put it on your classpath. This is the
LALR Parser Generator library that EMFT OCL uses for parsing OCL
expressions. We have a bug open to provide stand-alone builds of EMFT OCL
as EMF does for EMF, XSD, and SDO.
Once you have that straightened out, there may also be a few problems in
your snippet, below (comments in-line).
HTH,
Christian
Kamesh Sampath wrote:
> Chris,
> My IOCLHelper is resolved, thanks for help. as you had said i just
> updated my plugins to 1.0.1 .
> By the way am just learning to use EMF OCL , so if there is any syntical
> problem please do execuse me . I just want to set the environment for
> running the OCL and slowly start learing the other OCL stuff.
> I am running the following code snipper from my *.tests plugin's
> XYZExample.java
> Code Snippet of what am doing ?
> // EMFT query
> Map extents = new HashMap();
> Set fbs = new HashSet();
> extents.put(
StrutsconfigPackage.eINSTANCE.getFormBeanType(),
> fbs);
This is good, but I don't see any FormBeanTypes being added to the 'fbs'
set, so your extent is empty.
> String expr = "FormBeans.allInstances()->collect(a :
> FormBeanType | a.name)-> asSet()";
The 'allInstances()' operation must be applied to the name of the
EClassifier, which from the StrutsconfigPackage above looks like it would
be 'FormBeanType', not 'FormBeans'.
> Query query = QueryFactory.eINSTANCE.createQuery(expr,
> StrutsconfigPackage.eINSTANCE.getFormBeanType());
> query.setExtentMap(extents);
> Collection result = query.evaluate(root.getFormBeans()
> .getFormBeans());
In this case, because the expression invokes a static operation, I think you
may actually not need a context element (null would do). Otherwise, the
expected input to the Query.evaluate() method is just a form-bean object,
not a collection. It looks like this collection should be your "extent" in
the extent-map. :-)
> but when i create a and run the OCL expression am getting the following
> error ,
> Exception in thread "main" java.lang.NoClassDefFoundError:
> lpg/lpgjavaruntime/RuleAction
> at java.lang.ClassLoader.defineClass1(Native Method)
> at java.lang.ClassLoader.defineClass(Unknown Source)
> at java.security.SecureClassLoader.defineClass(Unknown Source)
> at java.net.URLClassLoader.defineClass(Unknown Source)
> at java.net.URLClassLoader.access$100(Unknown Source)
> at java.net.URLClassLoader$1.run(Unknown Source)
> at java.security.AccessController.doPrivileged(Native Method)
> at java.net.URLClassLoader.findClass(Unknown Source)
> at java.lang.ClassLoader.loadClass(Unknown Source)
> at sun.misc.Launcher$AppClassLoader.loadClass(Unknown Source)
> at java.lang.ClassLoader.loadClassInternal(Unknown Source)
> at
org.eclipse.emf.ocl.expressions.util.ExpressionsUtil.createP arser(ExpressionsUtil.java:680)
> at
org.eclipse.emf.ocl.expressions.util.ExpressionsUtil.createP arser(ExpressionsUtil.java:663)
> at
org.eclipse.emf.ocl.expressions.util.ExpressionsUtil.createQ uery(ExpressionsUtil.java:177)
> at
org.eclipse.emf.ocl.expressions.util.ExpressionsUtil.createQ uery(ExpressionsUtil.java:156)
> at
> org.eclipse.emf.ocl.query.impl.QueryUtil.makeOCLQuery(QueryU til.java:66)
> at
org.eclipse.emf.ocl.query.impl.QueryFactoryImpl.createQuery( QueryFactoryImpl.java:127)
> at
in.org.shakti.strutsconfig.tests.StrutsconfigExample.main(St rutsconfigExample.java:169)
> Your help in this regard is highly appericated ..
> Thank you.
> Kamesh
> Chris Lenz wrote:
>> import org.eclipse.emf.ocl.helper.HelperUtil;
>> import org.eclipse.emf.ocl.helper.IOCLHelper;
>> they are in org.eclipse.emf.ocl maybe you have an older version.
>> Whar class is not found??
>> Chris
>> Kamesh Sampath schrieb:
>>> Can anyone help me please . I am struck .
>>> I am also getting a NoClassDefFound Error when i I run my OCL Expression
>>> I guess it will be better to add few lines to EMF document or tutorials
>>> on the plugins required us before executing the examples .
>>> Kamesh
>>>> not able find the class IOclQueryHelper and QueryHelper .
>>>> org.eclipse.emf.ocl
>>>> Kamesh
Re: OCL Query Plugins Required [message #54115 is a reply to message #53935] |
Thu, 28 September 2006 09:35  |
Hi Christian,
I will raise the bug for the same in the bugzilla .
Thanks.
Kamesh
Christian W. Damus wrote:
> Hi, Kamesh,
> I forgot to mention that these are the only plug-ins required for querying
> with OCL using the EMF Query API.
> Cheers,
> Christian
>> org.eclipse.emf.ocl
>> Kamesh
Kamesh Sampath
Re: OCL Query Plugins Required [message #592430 is a reply to message #53613] |
Thu, 28 September 2006 08:00  |
I am also getting a NoClassDefFound Error when i I run my OCL Expression .
Kamesh
> org.eclipse.emf.ocl
> Kamesh
Kamesh Sampath
Re: OCL Query Plugins Required [message #592439 is a reply to message #53823] |
Thu, 28 September 2006 08:31  |
Chris
> Kamesh
>> org.eclipse.emf.ocl
>> Kamesh
Re: OCL Query Plugins Required [message #592447 is a reply to message #53850] |
Thu, 28 September 2006 08:37  |
Chris,
XYZExample.java
// EMFT query
extents.put(
fbs);
.getFormBeans());
error ,
Thank you.
Kamesh
> Chris
>> Kamesh
>>> org.eclipse.emf.ocl
>>> Kamesh
Kamesh Sampath
Re: OCL Query Plugins Required [message #592469 is a reply to message #53613] |
Thu, 28 September 2006 09:04  |
Hi, Kamesh,
The references to IOclQueryHelper and QueryHelper types in the tutorial are
in error. These were an older incarnation of the query API; they never did
exist in the org.eclipse.emf.query* APIs.
Would you mind raising a bug for this?
The discussion of the SELECT and OclCOnstraintCondition APIs in the
"Advanced Querying" section of the tutorial is more accurate.
HTH,
Christian
> org.eclipse.emf.ocl
> Kamesh
Re: OCL Query Plugins Required [message #592482 is a reply to message #53613] |
Thu, 28 September 2006 09:05  |
Hi, Kamesh,
Christian
> org.eclipse.emf.ocl
> Kamesh
Re: OCL Query Plugins Required [message #592493 is a reply to message #53874] |
Hi, Kamesh,
HTH,
Christian
> Chris,
> XYZExample.java
> // EMFT query
> extents.put(
> fbs);
> .getFormBeans());
the extent-map. :-)
> error ,
> at
> at
> at
> at
> at
> at
> at
> Thank you.
> Kamesh
>> Chris
>>> Kamesh
>>>> org.eclipse.emf.ocl
>>>> Kamesh
Re: OCL Query Plugins Required [message #592549 is a reply to message #53935] |
Hi Christian,
Thanks.
Kamesh
> Hi, Kamesh,
> Cheers,
> Christian
>> org.eclipse.emf.ocl
>> Kamesh
Kamesh Sampath
Current Time: Fri Apr 25 21:29:46 EDT 2025
Powered by FUDForum. Page generated in 0.03960 seconds
