Re: How does the extension registry handle multiple versions of the same plugin? [message #53605 is a reply to message #53552] |
Sun, 27 November 2005 15:14 |
Originally posted by: pascal.ibm.canada
Only bundles that are marked as singleton can contribute to the
extension registry. Therefore this problem does not occur.
ted stockwell wrote:
> Hi All,
> I'm trying to figure out how the extension registry handles multiple
> That is, suppose an Eclipse-based application currently has two
> different versions of the same plugin installed and the same extension
> is registered by both plugins. The two extensions are configured
> differently by the two plugins.
> Does Eclipse simply use the extension and configuration from the plugin
> with the highest version number?
> TIA,
> ted stockwell
FUDForum. Page generated in 0.03302 seconds
