CDO / Net4J socket connector [message #53480] |
Wed, 27 September 2006 08:01 |
Originally posted by: yannick.lizzi.silogic.fr
Hi all,
I want to develop a CDO/Net4J client that connects to a CDO/Net4J
server. When the client application starts, it doesn't know the server
host and port.
So comparing to the CDO examples, I have to customize the
ActiveSocketConnector programmatically (not via Spring) by setting host
and port, while the CDO client starts.
How can I do this?
I tried to set host and port before the resourceManager.start() by the
following code:
ActiveSocketConnector conn = (ActiveSocketConnector)
resourceManager.getChannel().getConnector();
conn.setHost(host);
conn.setPort(port);
The problem is that the connector have already started to connect with
the information taken from client.properties.
I also tried to comment the connector bean in client.xml and create it
programmatically with the following code:
ActiveSocketConnectorImpl connector = new ActiveSocketConnectorImpl();
connector.setHost(host);
connector.setPort(port);
connector.setProtocolManager(clientContainer.getBean("protocolManager "));
connector.setSelectorManager(clientContainer.getBean("selectorManager "));
connector.setBufferPool(clientContainer.getBean("bufferPool "));
resourceManager.setConnector(connector);
But in this case, I get a NoControlProtocolException when creating the
resource.
So what's the right way?
Yannick Lizzi
Re: CDO / Net4J socket connector [message #53533 is a reply to message #53480] |
Wed, 27 September 2006 12:26 |
Originally posted by: stepper.sympedia.de
Yannick,
Open the file /org.eclipse.emf.cdo.examples.client/META-INF/client.xml
and change the following:
<bean id="connector" class="org.eclipse.net4j.socket.impl.ActiveSocketConnectorImpl ">
<property name="bufferPool">
<ref bean="bufferPool"/>
</property>
<property name="protocolManager">
<ref bean="protocolManager"/>
</property>
<property name="selectorManager">
<ref bean="selectorManager"/>
</property>
<!-- REMOVED
<property name="host">
<value>${connector.host}</value>
</property>
<property name="port">
<value>${connector.port}</value>
</property>
<property name="autoStart"> <!-- ADDED -->
<value>false</value>
</property> -->
</bean>
This creates a Connector that is not automatically started when the container is started.
But don't forget to start it manually (ExampleClientPlugin) prior to service calls:
private static ActiveSocketConnector cachedConnector;
public static Connector getConnector()
if (cachedConnector == null)
cachedConnector = (ActiveSocketConnector) getClientContainer().getBean("connector");
cachedConnector.setHost("net4j.acme.com");
cachedConnector.setPort(12345);
try
cachedConnector.start();
catch (Exception ex)
ex.printStackTrace();
cachedConnector = null;
return cachedConnector;
I hope this helps.
Cheers
/Eike
Yannick Lizzi schrieb:
> Hi all,
> host and port.
> How can I do this?
> following code:
> conn.setHost(host);
> conn.setPort(port);
> resource.
> Thanks
> Yannick Lizzi
Re: CDO / Net4J socket connector [message #53640 is a reply to message #53533] |
Wed, 27 September 2006 15:49 |
Eike
Thanks it works.
Yannick
> Yannick,
> </property>
> </property>
> </property>
> <!-- REMOVED
> </property>
> </property>
> </property> -->
> </bean>
> service calls:
> try
> I hope this helps.
> Cheers
> /Eike
>> Hi all,
>> host and port.
>> host and port, while the CDO client starts.
>> How can I do this?
>> following code:
>> conn.setHost(host);
>> conn.setPort(port);
>> resource.
>> Thanks
>> Yannick Lizzi
Re: CDO / Net4J socket connector [message #592300 is a reply to message #53480] |
Yannick,
</property>
</property>
</property>
<!-- REMOVED
</property>
</property>
</property> -->
</bean>
try
I hope this helps.
Cheers
/Eike
> Hi all,
> host and port.
> How can I do this?
> following code:
> conn.setHost(host);
> conn.setPort(port);
> resource.
> Thanks
> Yannick Lizzi
Cheers
/Eike
http://www.esc-net.de
Re: CDO / Net4J socket connector [message #592358 is a reply to message #53533] |
Eike
Thanks it works.
Yannick
> Yannick,
> </property>
> </property>
> </property>
> <!-- REMOVED
> </property>
> </property>
> </property> -->
> </bean>
> service calls:
> try
> I hope this helps.
> Cheers
> /Eike
>> Hi all,
>> host and port.
>> How can I do this?
>> following code:
>> conn.setHost(host);
>> conn.setPort(port);
>> resource.
>> Thanks
>> Yannick Lizzi
FUDForum. Page generated in 0.03087 seconds
