Home » Eclipse Projects » Equinox » Beginning with OSGi
Beginning with OSGi [message #53389] Tue, 15 November 2005 22:40 Go to next message
Originally posted by: ts.conceicao.uol.com.br
I plan to build an application using OSGi and was looking for an
implementation to work with, then I heard of equinox and decided to try it
out.
I've started reading the R4 spec but I have one question still that
was not entirely clear to me: while developing a bundle for running on
OSGi, do I need to implement the Bundle interface in some kind of "main
class"?
If we develop Bundles on OSGi and there's a Bundle interface the logic
led me to think that it should, but this tutorial doesn't show that:
http://oscar-osgi.sourceforge.net/tutorial/ex2.html
Thiago
Re: Beginning with OSGi [message #53442 is a reply to message #53389] Wed, 16 November 2005 05:37 Go to previous message
Hi Thiago,
> class"?
No you don't have to! The Bundle interface is implemented by the
framework to represent your bundle for others in the application.
All you have to do is implement BundleActivator. There you will be given
a BundleContext instance which gives you access to private callbacks for
the implementation of your bundle.
Bundles that need to know things about other bundles then will see the
Bundle objects for each bundles in the system and not their
BundleContext objects.
> Thiago
This tutorial is completely right!
Didier.
Previous Topic:With 3.2M3, CANNOT export and import the same package
Next Topic:Server-side incubator
Current Time: Fri Nov 07 14:07:26 EST 2025
Powered by FUDForum. Page generated in 0.04649 seconds
