Home » Language IDEs » Java Development Tools (JDT) » Breakpoints, Remote Debugging and Projects
Breakpoints, Remote Debugging and Projects [message #53298] Mon, 09 June 2003 11:21 Go to next message
Originally posted by: colm.nospam.divilly.nospam.eontec.com
I have noticed a quirk in Eclipse whereby it does not seem possible to
set breakpoints in code located in a dependent project.
If I have project A that calls a method in project B (project A's build path
refers to project B) and I am connecting to an app server using remote
debugging, any breakpoints I set in project B are ignored ( they don't have
the little blue triangle on them ).
Has anybody else noticed this, and are there any workarounds ?
Re: Breakpoints, Remote Debugging and Projects [message #53438 is a reply to message #53298] Mon, 09 June 2003 14:36 Go to previous message
Originally posted by: jared-eclipse.mn.rr.com
Please file a bug report with a detailed test case (the smaller, the better)
and we'll take a look.
- Jared
news.eclipse.org wrote:
> path refers to project B) and I am connecting to an app server using
> remote debugging, any breakpoints I set in project B are ignored ( they
> don't have the little blue triangle on them ).
Previous Topic:Eclipse eval - thanks for the input
Next Topic:How to use Eclipse debugger to step through/debug VM initialization?
Current Time: Sat Sep 13 23:11:26 EDT 2025
Powered by FUDForum. Page generated in 0.34152 seconds
