Home » Archived » EPF » EPF 1.5 with subclipse plugin
EPF 1.5 with subclipse plugin [message #53217] Tue, 02 September 2008 18:26 Go to next message
Isabela is currently offline IsabelaFriend
I was using EPF 1.2.0.4 without problems.
Now with EPF 1.5 I checked out a new project with Subclipse, but in the
Authoring view the Method Plug-in of my project is not opening in the
Library View. (my method plug-in was created in the previous version of
EPF)
I already tried to 'Close Project' and 'Open Project' in the Navigator
View, but the Method Plug-in is not opening...
I am using the following versions:
EPF 1.5.0
Subclipse Plugin Site 1.4.3
Subversion 1.4.6
Thanks!
Re: EPF 1.5 with subclipse plugin [message #53273 is a reply to message #53217] Wed, 03 September 2008 16:19 Go to previous messageGo to next message
Originally posted by: storaskar.xx.xxx.xxx
Have you upgraded your plugins to 1.5. If not, that could be the issue.
Checkout all your plugins in EPF 1.2.0.4, First upgrade to EPF 1.5, When
you start 1.5 with those plugins in your workspace, EPF should prompt you
to upgrade. Once upgrade successful, I think you will have to check in
those plugins again to subclipse. Let me know whether that does the trick.
Shilpa
Re: EPF 1.5 with subclipse plugin [message #53785 is a reply to message #53273] Thu, 02 October 2008 13:34 Go to previous message
I solved the problem changing the following lines of the file library.xmi:
(After that close and open the project again - and everything will work as
before)
In EPF version 1.2.0.4:
xmlns:org.eclipse.epf.uma="http://www.eclipse.org/epf/uma/1.0.4/uma.ecore"
xmlns:epf="http://www.eclipse.org/epf" epf:version="1.2.0">
[Changed] In EPF version 1.5:
xmlns:org.eclipse.epf.uma="http://www.eclipse.org/epf/uma/1.0.5/uma.ecore"
xmlns:epf="http://www.eclipse.org/epf" epf:version="1.5.0">
Re: EPF 1.5 with subclipse plugin [message #590369 is a reply to message #53217] Wed, 03 September 2008 16:19 Go to previous message
Shilpa Toraskar is currently offline Shilpa ToraskarFriend
Shilpa
Re: EPF 1.5 with subclipse plugin [message #590650 is a reply to message #53273] Thu, 02 October 2008 13:34 Go to previous message
before)
Previous Topic:How do you spell OpenUP?
Next Topic:Error on Task Rename
Current Time: Tue Jan 28 14:02:14 GMT 2025
Powered by FUDForum. Page generated in 0.04045 seconds
