Home » Eclipse Projects » Mylyn » Mylyn context incorrect after source code branch is merged.
Mylyn context incorrect after source code branch is merged. [message #53116] Thu, 17 July 2008 16:53 Go to next message
We're very interested in using Mylyn, however one concern is how it would
support code that is merged from a branch.
For instance, say we create a Project_A_branch_24 off of Project_A head. In
Eclipse I have both Project_A_branch_24 and Project_A as projects. The
team does a bunch of work on Project_A_branch_24 using Mylyn. This
includes saving the context of the work on bug_2301. In the end we merge
the changes in the branch back into head. Much later someone checks out
Project_A head and wants to know what files were involved with bug_2301.
They access the Mylyn task (via Jira) but all the referenced files are in
Project_A_branch_24.
Is there a way around this?
Jeff
Re: Mylyn context incorrect after source code branch is merged. [message #53216 is a reply to message #53116] Thu, 17 July 2008 17:39 Go to previous messageGo to next message
This bug has some discussion about the problem where the same project is
shared with different names:
201739: [context] support sharing contexts between developers in spite of
the project being named differently in each workspace
https://bugs.eclipse.org/bugs/show_bug.cgi?id=201739
Jeff, it would be great if you could comment on the bug report and add your
specific use-case and requirements.
Steffen
> In
> Jeff
Re: Mylyn context incorrect after source code branch is merged. [message #53421 is a reply to message #53216] Fri, 18 July 2008 10:56 Go to previous message
Steffen,
Thanks, I've added my two cents to the bug report.
If anyone else needs to move Mylyn task contexts from a project representing
a source code branch to one representing the head I'd encourage you to vote
for this bug.
-- Jeff
"Steffen Pingel" <steffen.pingel@tasktop.com> wrote in message
news:g5oe6j$84g$1@build.eclipse.org...
> your
> Steffen
>> In
>> Thanks,
>> Jeff
Re: Mylyn context incorrect after source code branch is merged. [message #591382 is a reply to message #53116] Thu, 17 July 2008 17:39 Go to previous message
Steffen
> In
> Jeff
Re: Mylyn context incorrect after source code branch is merged. [message #591458 is a reply to message #53216] Fri, 18 July 2008 10:56 Go to previous message
Steffen,
for this bug.
-- Jeff
> your
> Steffen
>> In
>> Thanks,
>> Jeff
Previous Topic:Problem with 3.0.1 update
Next Topic:Mylyn 3.0.1 is now available
Current Time: Sat Oct 25 01:05:21 EDT 2025
Powered by FUDForum. Page generated in 0.07303 seconds
