Home » Archived » XML Schema Definition (XSD) » NLS support for XSD
NLS support for XSD [message #53099] Thu, 23 September 2004 18:06 Go to next message
Joshua Hui is currently offline Joshua HuiFriend
Where can I get more information regarding the NLS support for XSD, such
as how to setup, which files should be involved?
Thanks.
Joshua Hui
Re: NLS support for XSD [message #53155 is a reply to message #53099] Thu, 23 September 2004 22:29 Go to previous messageGo to next message
Joshua,
Since you are an IBMer, you should talk to the IES folks and you should
be getting your builds via IES, which will include the NL. The
translated plugin.properties are also provided in the xsd.resources.jar,
so when running standalone, you shouldn't need anything else. I think
the NL features are available in some public Eclipse place as well, but
I need to track that down still...
Joshua Hui wrote:
> such as how to setup, which files should be involved?
> Thanks.
> Joshua Hui
Re: NLS support for XSD & EMF & SDO [message #53683 is a reply to message #53155] Tue, 28 September 2004 18:31 Go to previous message
Originally posted by: codeslave.ca.ibm.com
If you haven't already seen the zips on the EMF/XSD sites or mentioned
on eclipse.org, here's a link to the NL packs for EMF, SDO, and XSD.
http://download.eclipse.org/tools/emf/scripts/downloads.php# NLS
http://download.eclipse.org/technology/xsd/scripts/downloads .php#NLS
Nick Boldt
Ed Merks wrote:
> Joshua,
> Joshua Hui wrote:
>> Thanks.
>> Joshua Hui
Re: NLS support for XSD [message #591661 is a reply to message #53099] Thu, 23 September 2004 22:29 Go to previous message
Joshua,
Joshua Hui wrote:
> Thanks.
> Joshua Hui
Ed Merks
Re: NLS support for XSD & EMF & SDO [message #591919 is a reply to message #53155] Tue, 28 September 2004 18:31 Go to previous message
Nick Boldt is currently offline Nick BoldtFriend
Nick Boldt
Ed Merks wrote:
> Joshua,
> Joshua Hui wrote:
>> Thanks.
>> Joshua Hui
Previous Topic:removing global elements from XSDSchema
Next Topic:HOWTO: Offline Newsgroup Message Searching (was Re: Is the archive truncate? Archive feature request
Current Time: Tue Jan 28 13:56:39 GMT 2025
Powered by FUDForum. Page generated in 0.21962 seconds
