Home » Eclipse Projects » DTP » Dependency problem: org.eclipse.datatools.connectivity.sqm.core
Dependency problem: org.eclipse.datatools.connectivity.sqm.core [message #53093] |
Wed, 04 March 2009 08:53 ![Go to next message Go to next message](theme/Solstice/images/down.png) |
Originally posted by: b_apolci.libero.it
I'm trying to update my eclipse installation to eclipse 3.4.2 but I get
the following dependency error:
Cannot complete the request. See the details.
Cannot find a solution satisfying the following requirements
Match[requiredCapability:
org.eclipse.equinox.p2.iu/org.eclipse.datatools.connectivity .sqm.core/[1.0.3.v200809180120,1.0.3.v200809180120]].
Any idea on what is the problem?
My configuration details:
*** Date: mercoledì 4 marzo 2009 09:51:39 Germania
*** Platform Details:
*** System properties:
awt.toolkit=sun.awt.windows.WToolkit
eclipse.buildId=M20080911-1700
eclipse.commands=-os
win32
-ws
win32
-arch
x86
-showsplash
C:\eclipse\eclipse34\\plugins\org.eclipse.platform_3.3.101.v 200809111700\splash.bmp
-launcher
C:\eclipse\eclipse34\eclipse.exe
-name
Eclipse
--launcher.library
C:\eclipse\eclipse34\plugins\org.eclipse.equinox.launcher.wi n32.win32.x86_1.0.101.R34x_v20080731\eclipse_1115.dll
-startup
C:\eclipse\eclipse34\plugins\org.eclipse.equinox.launcher_1. 0.101.R34x_v20080819.jar
-vm C:\java\jdk1.6.0_07
-data
C:\eclipse\wsIDB
-launcher
-vm
C:\Programmi\Java\jre1.6.0_07\bin\client\jvm.dll
eclipse.ee.install.verify=false
eclipse.home.location=file:/C:/eclipse/eclipse34/
eclipse.launcher=C:\eclipse\eclipse34\eclipse.exe
eclipse.p2.data.area=@config.dir/../p2
eclipse.p2.profile=SDKProfile
eclipse.product=org.eclipse.sdk.ide
eclipse.startTime=1236155448031
eclipse.vm=C:\Programmi\Java\jre1.6.0_07\bin\client\jvm.dll
eclipse.vmargs=-Xms200m
-Xmx512m
-XX:MaxPermSize=256m
-Djava.class.path=C:\eclipse\eclipse34\plugins\org.eclipse.e quinox.launcher_1.0.101.R34x_v20080819.jar
file.encoding=Cp1252
file.encoding.pkg=sun.io
file.separator=\
http.proxyHost=proxy.eng.it
http.proxyPort=3128
java.awt.graphicsenv=sun.awt.Win32GraphicsEnvironment
java.awt.printerjob=sun.awt.windows.WPrinterJob
java.class.path=C:\eclipse\eclipse34\plugins\org.eclipse.equ inox.launcher_1.0.101.R34x_v20080819.jar
java.class.version=50.0
java.endorsed.dirs=C:\Programmi\Java\jre1.6.0_07\lib\endorse d
java.ext.dirs=C:\Programmi\Java\jre1.6.0_07\lib\ext;C:\WINDO WS\Sun\Java\lib\ext
java.home=C:\Programmi\Java\jre1.6.0_07
java.io.tmpdir=C:\DOCUME~1\Andrea\IMPOST~1\Temp\
java.library.path=C:\eclipse\eclipse34;.;C:\WINDOWS\Sun\Java \bin;C:\WINDOWS\system32;C:\WINDOWS;C:/Programmi/Java/jre1.6 .0_07/bin/client;C:/Programmi/Java/jre1.6.0_07/bin;C:\Progra mmi\PC
Connectivity
Solution\;C:\oracle\product\10.2.0\db_1\bin;C:\OraHome1\bin; C:\Programmi\Oracle\jre\1.1.7\bin;C:\WINDOWS\system32;C:\WIN DOWS;C:\WINDOWS\System32\Wbem;C:\Programmi\cvsnt;C:\Programm i\IDM
Computer Solutions\UltraEdit-32;C:\Programmi\File
comuni\GTK\2.0\bin;C:\Programmi\Support
Tools\;C:\PROGRA~1\IBM\SQLLIB\BIN;C:\PROGRA~1\IBM\SQLLIB\FUN CTION;C:\PROGRA~1\IBM\SQLLIB\SAMPLES\REPL;C:\Programmi\Quick Time\QTSystem\;C:\Programmi\Graphviz2.20\Bin;C:\Programmi\Co llabNet
Subversion;C:\java\agent_controller\bin;C:\Programmi\IDM Computer
Solutions\UltraCompare;C:\Programmi\CVSNT\;C:\java\apache-ma ven-2.0.9\bin
java.runtime.name=Java(TM) SE Runtime Environment
java.runtime.version=1.6.0_07-b06
java.specification.name=Java Platform API Specification
java.specification.vendor=Sun Microsystems Inc.
java.specification.version=1.6
java.vendor.url=http://java.sun.com/
java.vendor.url.bug=http://java.sun.com/cgi-bin/bugreport.cgi
java.version=1.6.0_07
java.vm.info=mixed mode
java.vm.name=Java HotSpot(TM) Client VM
java.vm.specification.name=Java Virtual Machine Specification
java.vm.specification.vendor=Sun Microsystems Inc.
java.vm.specification.version=1.0
java.vm.vendor=Sun Microsystems Inc.
java.vm.version=10.0-b23
line.separator=
org.apache.commons.logging.Log=org.apache.commons.logging.im pl.SimpleLog
org.apache.commons.logging.simplelog.defaultlog=off
org.apache.commons.logging.simplelog.log.httpclient.wire.hea der=off
org.apache.commons.logging.simplelog.log.org.apache.commons. httpclient=off
org.eclipse.equinox.launcher.splash.location=C:\eclipse\ecli pse34\\plugins\org.eclipse.platform_3.3.101.v200809111700\sp lash.bmp
org.eclipse.equinox.simpleconfigurator.configUrl=file:org.ec lipse.equinox.simpleconfigurator\bundles.info
org.eclipse.update.reconcile=false
org.osgi.framework.executionenvironment=OSGi/Minimum-1.0,OSG i/Minimum-1.1,JRE-1.1,J2SE-1.2,J2SE-1.3,J2SE-1.4,J2SE-1.5,Ja vaSE-1.6
org.osgi.framework.language=it
org.osgi.framework.os.name=WindowsXP
org.osgi.framework.os.version=5.1.0
org.osgi.framework.processor=x86
org.osgi.framework.system.packages=javax.accessibility,javax .activation,javax.activity,javax.annotation,javax.annotation .processing,javax.crypto,javax.crypto.interfaces,javax.crypt o.spec,javax.imageio,javax.imageio.event,javax.imageio.metad ata,javax.imageio.plugins.bmp,javax.imageio.plugins.jpeg,jav ax.imageio.spi,javax.imageio.stream,javax.jws,javax.jws.soap ,javax.lang.model,javax.lang.model.element,javax.lang.model. type,javax.lang.model.util,javax.management,javax.management .loading,javax.management.modelmbean,javax.management.monito r,javax.management.openmbean,javax.management.relation,javax .management.remote,javax.management.remote.rmi,javax.managem ent.timer,javax.naming,javax.naming.directory,javax.naming.e vent,javax.naming.ldap,javax.naming.spi,javax.net,javax.net. ssl,javax.print,javax.print.attribute,javax.print.attribute. standard,javax.print.event,javax.rmi,javax.rmi.CORBA,javax.r mi.ssl,javax.script,javax.security.auth,javax.security.auth. callback,javax.security.auth.
kerberos,javax.security.auth.login,javax.security.auth.spi,j avax.security.auth.x500,javax.security.cert,javax.security.s asl,javax.sound.midi,javax.sound.midi.spi,javax.sound.sample d,javax.sound.sampled.spi,javax.sql,javax.sql.rowset,javax.s ql.rowset.serial,javax.sql.rowset.spi,javax.swing,javax.swin g.border,javax.swing.colorchooser,javax.swing.event,javax.sw ing.filechooser,javax.swing.plaf,javax.swing.plaf.basic,java x.swing.plaf.metal,javax.swing.plaf.multi,javax.swing.plaf.s ynth,javax.swing.table,javax.swing.text,javax.swing.text.htm l,javax.swing.text.html.parser,javax.swing.text.rtf,javax.sw ing.tree,javax.swing.undo,javax.tools,javax.transaction,java x.transaction.xa,javax.xml,javax.xml.bind,javax.xml.bind.ann otation,javax.xml.bind.annotation.adapters,javax.xml.bind.at tachment,javax.xml.bind.helpers,javax.xml.bind.util,javax.xm l.crypto,javax.xml.crypto.dom,javax.xml.crypto.dsig,javax.xm l.crypto.dsig.dom,javax.xml.crypto.dsig.keyinfo,javax.xml.cr ypto.dsig.spec,javax.xml.datat
ype,javax.xml.namespace,javax.xml.parsers,javax.xml.soap,jav ax.xml.stream,javax.xml.stream.events,javax.xml.stream.util, javax.xml.transform,javax.xml.transform.dom,javax.xml.transf orm.sax,javax.xml.transform.stax,javax.xml.transform.stream, javax.xml.validation,javax.xml.ws,javax.xml.ws.handler,javax .xml.ws.handler.soap,javax.xml.ws.http,javax.xml.ws.soap,jav ax.xml.ws.spi,javax.xml.xpath,org.ietf.jgss,org.omg.CORBA,or g.omg.CORBA_2_3,org.omg.CORBA_2_3.portable,org.omg.CORBA.Dyn AnyPackage,org.omg.CORBA.ORBPackage,org.omg.CORBA.portable,o rg.omg.CORBA.TypeCodePackage,org.omg.CosNaming,org.omg.CosNa ming.NamingContextExtPackage,org.omg.CosNaming.NamingContext Package,org.omg.Dynamic,org.omg.DynamicAny,org.omg.DynamicAn y.DynAnyFactoryPackage,org.omg.DynamicAny.DynAnyPackage,org. omg.IOP,org.omg.IOP.CodecFactoryPackage,org.omg.IOP.CodecPac kage,org.omg.Messaging,org.omg.PortableInterceptor,org.omg.P ortableInterceptor.ORBInitInfoPackage,org.omg.PortableServer ,org.omg.PortableServer.Curren
tPackage,org.omg.PortableServer.POAManagerPackage,org.omg.Po rtableServer.POAPackage,org.omg.PortableServer.portable,org. omg.PortableServer.ServantLocatorPackage,org.omg.SendingCont ext,org.omg.stub.java.rmi,org.w3c.dom,org.w3c.dom.bootstrap, org.w3c.dom.css,org.w3c.dom.events,org.w3c.dom.html,org.w3c. dom.ls,org.w3c.dom.ranges,org.w3c.dom.stylesheets,org.w3c.do m.traversal,org.w3c.dom.views
,org.xml.sax,org.xml.sax.ext,org.xml.sax.helpers
org.osgi.framework.vendor=Eclipse
org.osgi.framework.version=1.4.0
org.osgi.supports.framework.extension=true
org.osgi.supports.framework.fragment=true
org.osgi.supports.framework.requirebundle=true
os.arch=x86
os.name=Windows XP
os.version=5.1
osgi.arch=x86
osgi.bundles=reference:file:org.eclipse.equinox.simpleconfigurator_1.0.0.v20080604.jar@1:start
osgi.bundles.defaultStartLevel=4
osgi.bundlestore=C:\eclipse\eclipse34\configuration\org.ecli pse.osgi\bundles
osgi.compatibility.bootdelegation=true
osgi.configuration.area=file:/C:/eclipse/eclipse34/configura tion/
osgi.framework=file:/c:/eclipse/eclipse34/plugins/org.eclips e.osgi_3.4.2.R34x_v20080826-1230.jar
osgi.framework.beginningstartlevel=1
osgi.framework.shape=jar
osgi.framework.version=3.4.2.R34x_v20080826-1230
osgi.install.area=file:/C:/eclipse/eclipse34/
osgi.instance.area=file:/C:/eclipse/wsIDB/
osgi.instance.area.default=file:/C:/Documents and Settings/Andrea/workspace/
osgi.launcherIni=eclipse
osgi.launcherPath=.
osgi.logfile=C:\eclipse\wsIDB\.metadata\.log
osgi.manifest.cache=C:\eclipse\eclipse34\configuration\org.e clipse.osgi\manifests
osgi.nl=it_IT
osgi.os=win32
osgi.splashLocation=C:\eclipse\eclipse34\\plugins\org.eclips e.platform_3.3.101.v200809111700\splash.bmp
osgi.splashPath=platform:/base/plugins/org.eclipse.platform
osgi.syspath=c:\eclipse\eclipse34\plugins
osgi.ws=win32
path.separator=;
sun.arch.data.model=32
sun.boot.class.path=C:\Programmi\Java\jre1.6.0_07\lib\resour ces.jar;C:\Programmi\Java\jre1.6.0_07\lib\rt.jar;C:\Programm i\Java\jre1.6.0_07\lib\sunrsasign.jar;C:\Programmi\Java\jre1 .6.0_07\lib\jsse.jar;C:\Programmi\Java\jre1.6.0_07\lib\jce.j ar;C:\Programmi\Java\jre1.6.0_07\lib\charsets.jar;C:\Program mi\Java\jre1.6.0_07\classes
sun.boot.library.path=C:\Programmi\Java\jre1.6.0_07\bin
sun.cpu.endian=little
sun.cpu.isalist=pentium_pro+mmx pentium_pro pentium+mmx pentium i486
i386 i86
sun.desktop=windows
sun.io.unicode.encoding=UnicodeLittle
sun.jnu.encoding=Cp1252
sun.management.compiler=HotSpot Client Compiler
sun.net.client.defaultConnectTimeout=30000
sun.net.client.defaultReadTimeout=30000
sun.os.patch.level=Service Pack 3
user.country=IT
user.dir=C:\eclipse\eclipse34
user.home=C:\Documents and Settings\Andrea
user.language=it
user.name=Andrea
user.timezone=Europe/Berlin
user.variant=
*** Features:
com.mountainminds.eclemma.feature (1.3.2) "EclEmma UI"
com.tasktop.client.lite_feature (1.3.0.v20081106-1400) "Tasktop Client
Plug-in"
com.tasktop.email_feature (1.3.0.v20081106-1400) "Tasktop Client Plug-in"
com.tasktop.google.mail_feature (1.3.0.v20081106-1400) "Tasktop Client
Plug-in"
com.tasktop.imap_feature (1.3.0.v20081106-1400) "Tasktop Client Plug-in"
com.tasktop.reporting.birt_feature_e3.4 (1.0.1) "Tasktop Client Plug-in"
dk.contix.eclipse.hudson (1.0.4) "Hudson Plug-in for Eclipse"
org.eclipse.cvs (1.1.1.r34x_20080902-7C79E8N9nJD4oAW9V1938) "Eclipse CVS
Client"
org.eclipse.datatools.connectivity.feature
(1.6.1.v200809191145-7_7K7_Dn-QY4jNGDlg0YiVa76H) "Data Tools Platform
Connectivity Plug-in"
org.eclipse.datatools.connectivity.oda.designer.feature
(1.6.1.v200809191145-7C67OCYQCD4D-JkHcYh) "DTP ODA Designer UI Framework
Plug-in"
org.eclipse.datatools.connectivity.oda.feature
(1.6.1.v200809191145-7F27PBcMAAwAtKkESVZ) "DTP Open Data Access"
org.eclipse.datatools.doc.user
(1.6.1.v200809191145-37A09oA55S5P_P8CEO24) "Data Tools Platform User
Documentation"
org.eclipse.datatools.enablement.apache.derby.feature
(1.6.1.v200809191145-652AlJAKaLiJyLhdmBEKK) "High-level Sybase
Enablement Plug-in"
org.eclipse.datatools.enablement.feature
(1.6.1.v200809191145-7D8H7C9FSwOBZabCz-MXEZLR8Rnc) "Eclipse Data Tools
Platform Enablement"
org.eclipse.datatools.enablement.hsqldb.feature
(1.6.1.v200809191145-57_1_pF9IQJZIsJcVhBEKK) "Eclipse Data Tools
org.eclipse.datatools.enablement.ibm.feature
(1.6.1.v200809191145-7D43EB7sQS9RbiYgHAa) "Eclipse Data Tools Platform
Enablement"
org.eclipse.datatools.enablement.jdbc.feature
(1.6.1.v200809191145-3-09oA55S5J8JADJJ) "High-level Sybase Enablement
Plug-in"
org.eclipse.datatools.enablement.msft.feature
(1.6.1.v200809191145-442_kE77c7VBQDFNW) "Eclipse Data Tools Platform
Enablement"
org.eclipse.datatools.enablement.mysql.feature
(1.6.1.v200809191145-442_kE77c7TBTBKPQ) "Eclipse Data Tools Platform
Enablement"
org.eclipse.datatools.enablement.oda.designer.feature
(1.6.1.v200809191145-2118s733I3I6C4_6C) "Eclipse Data Tools Platform XML
ODA Designer"
org.eclipse.datatools.enablement.oda.feature
(1.6.1.v200809191145-797P6CYQCD4CvIcEeNW) "Eclipse Data Tools Platform
XML ODA Runtime Driver"
org.eclipse.datatools.enablement.oracle.feature
(1.6.1.v200809191145-442_kE77c7UAOBJML) "Eclipse Data Tools Platform
Enablement"
org.eclipse.datatools.enablement.postgresql.feature
(1.6.1.v200809191145-441_kE77c7R_RCIOP) "Eclipse Data Tools Platform
Enablement"
org.eclipse.datatools.enablement.sap.feature
(1.6.1.v200809191145-440_kE77c7QAQEIQQ) "Eclipse Data Tools Platform
Enablement"
org.eclipse.datatools.enablement.sybase.feature
(1.6.1.v200809191145-7A-5E9IgKLhLGetRuu9) "High-level Sybase Enablement
Plug-in"
org.eclipse.datatools.modelbase.feature
(1.6.2.v200810071455-6-2BcMAAyBWDkEVSb) "Eclipse Data Tools Platform
SQLModel Plug-in"
org.eclipse.datatools.sqldevtools.feature
(1.6.1.v200809191145-7F7d5E8yz-UHrDYUGnc_DXkE39Kp) "Eclipse Data Tools
Platform SQL Tools Common UI Plug-in"
org.eclipse.draw2d (3.4.2.v20090218-1145-3317w311_122502441) "Graphical
Editing Framework Draw2d"
org.eclipse.ecf.core (2.0.1.v20080916-1301) "Eclipse Communication
Framework (ECF)"
org.eclipse.ecf.examples (2.0.1.v20080916-1301) "ECF Collaboration Examples"
org.eclipse.emf (2.4.1.v200808251517) "EMF - Eclipse Modeling Framework"
org.eclipse.emf.codegen (2.4.0.v200808251517) "EMF Code Generation"
org.eclipse.emf.codegen.ecore (2.4.1.v200808251517) "EMF Ecore Code
Generator"
org.eclipse.emf.codegen.ecore.ui (2.4.1.v200808251517) "EMF Ecore Code
Generator UI"
org.eclipse.emf.codegen.ui (2.4.0.v200808251517) "EMF Code Generation UI"
org.eclipse.emf.common (2.4.0.v200808251517) "EMF Common"
org.eclipse.emf.common.ui (2.4.0.v200808251517) "EMF Common UI"
org.eclipse.emf.converter (2.4.1.v200808251517) "EMF Model Converter"
org.eclipse.emf.databinding (1.0.0.v200808251517) "EMF Data Binding"
org.eclipse.emf.databinding.edit (1.0.0.v200808251517) "EMF Edit Data
Binding"
org.eclipse.emf.ecore (2.4.1.v200808251517) "EMF Ecore"
org.eclipse.emf.ecore.edit (2.4.1.v200808251517) "EMF Ecore Edit"
org.eclipse.emf.ecore.editor (2.4.0.v200808251517) "EMF Sample Ecore Editor"
org.eclipse.emf.edit (2.4.1.v200808251517) "EMF Edit"
org.eclipse.emf.edit.ui (2.4.1.v200808251517) "EMF Edit UI"
org.eclipse.emf.mapping (2.4.0.v200808251517) "EMF Mapping"
org.eclipse.emf.mapping.ecore (2.4.0.v200808251517) "EMF Ecore Mapping"
org.eclipse.emf.mapping.ecore.editor (2.4.0.v200808251517) "EMF Ecore
Mapping Editor"
org.eclipse.emf.mapping.ui (2.4.0.v200808251517) "EMF Mapping UI"
org.eclipse.gef (3.4.2.v20090218-1145-67728084A56B4I233613552)
"Graphical Editing Framework GEF"
org.eclipse.help (1.0.1.R34x_v20080827-7r7xEIxEI6Zu5nEqN7M3UBpglaat)
"Help System Base"
org.eclipse.jdt (3.4.1.r341_v20080709-0800-7o7tEAfEF_U5qyUgrb2HAp539P97)
"Eclipse Java Development Tools"
org.eclipse.jst (3.0.2.v200808250510-7U-8r9LJ9cNr7UGsQ02P0aZsUk1o) "J2EE
Standard Tools (JST)"
org.eclipse.jst.ws.axis2tools.feature
(1.0.1.v200807092124-77-E_BCYQCD4CyNjOPRU) "J2EE Standard Tools (JST)"
org.eclipse.mylyn_feature (3.0.5.v20090218-1800-e3x) "Mylyn"
org.eclipse.mylyn.bugzilla_feature (3.0.5.v20090218-1800-e3x) "Mylyn"
org.eclipse.mylyn.context_feature (3.0.5.v20090218-1800-e3x) "Mylyn"
org.eclipse.mylyn.ide_feature (3.0.5.v20090218-1800-e3x) "Mylyn"
org.eclipse.mylyn.java_feature (3.0.5.v20090218-1800-e3x) "Mylyn"
org.eclipse.mylyn.pde_feature (3.0.5.v20090218-1800-e3x) "Mylyn"
org.eclipse.mylyn.team_feature (3.0.5.v20090218-1800-e3x) "Mylyn"
org.eclipse.pde (3.4.1.r341_v20080731-7T7U0E9mlRIuGUYviF_VP) "PDE"
(3.4.1.r341_v20080731-9I96EiDElYevwz-p1bP5z-NlAaP7vtX6Utotqs u) "Eclipse
Platform"
org.eclipse.rcp (3.4.100.r341_v20080814-989JESIEdAciFYfkZZsBfSwQ2341)
"Eclipse RCP"
org.eclipse.sdk
(3.4.1.R34x_v20080827-7O7S78C2J40sK2o_ALcK8tLN_yZSJeg0P-3EtL 4Ra90kv)
"Eclipse Project SDK"
org.eclipse.team.svn (0.7.7.I20090224-1900) "Subversive SVN Team
Provider (Incubation)"
org.eclipse.team.svn.mylyn (0.7.7.I20090224-1900) "Subversive
Integration for the Mylyn Project (Incubation)"
org.eclipse.team.svn.mylyn.source (0.7.7.I20090224-1900) "The sources of
the Subversive Integration for the Mylyn Project (Incubation)"
org.eclipse.team.svn.nl1 (0.7.7.I20090224-1900) "Subversive SVN Team
Provider Localization (Incubation)"
org.eclipse.team.svn.nl1.sources (0.7.7.I20090224-1900) "The sources of
the Subversive Localization (Incubation)"
org.eclipse.team.svn.resource.ignore.rules.jdt (0.7.7.I20090224-1900)
"Subversive JDT Ignore Extensions (Incubation)"
org.eclipse.team.svn.resource.ignore.rules.jdt.source
(0.7.7.I20090224-1900) "The sources of the Subversive JDT Ignore
org.eclipse.team.svn.sources (0.7.7.I20090224-1900) "The sources of the
SVN Team Provider (Incubation)"
org.eclipse.tptp.examples
(4.5.0.v200803191201-7B7_CE87CDJE2D9EFFDD7CF_4) "TPTP Examples"
org.eclipse.tptp.monitoring
(4.4.100.v200805120832-7d7OEINE8McIJXIvZtNAa2) "TPTP Monitoring"
org.eclipse.tptp.monitoring.doc.user
(4.4.0.v200804180100-784CF8s733I3C684B7A) "TPTP Monitoring Project
Documentation"
org.eclipse.tptp.monitoring.examples
(4.3.200.v200803201123-44-7w311916231943) "User examples for the TPTP
Monitoring Tools Plugins"
org.eclipse.tptp.monitoring.instrumentation
(4.3.100.v200805120832-7B79Ag9oA55S5L8H7796) "TPTP Instrumentation
Monitoring "
org.eclipse.tptp.monitoring.la.core
(4.4.100.v200806121215-7B78CE9oA55S5GAA8MAM) "Monitoring Log Analyzer
Core backward compatibility"
org.eclipse.tptp.monitoring.managedagent
(4.4.100.v200805120832-7F7DCF_kE77c7MBH7H_9) "Managed Agent Plugin"
org.eclipse.tptp.monitoring.managedagent.agents
(4.4.100.v200805120832-4307w311916231943) "JMX Managed Agent"
org.eclipse.tptp.monitoring.mx4j.jmx
(4.4.1.v200802291616-3-27w3119133_2562) "MX4J"
org.eclipse.tptp.monitoring.report.birt
(4.5.0.v200806050100-7B7D-9oA55S5L7H686A) "TPTP Business Intelligence
and Reporting Tools (BIRT) Log Reports"
org.eclipse.tptp.platform.analysis
(4.4.100.v200806050100-7F7_EAU_kE77c7U7Q7A77) "TPTP Analysis"
org.eclipse.tptp.platform.analysis.codereview.java
(4.4.200.v200806050100-7877_78s733I3E3C3533) "Java Code Review Plug-in"
org.eclipse.tptp.platform.analysis.engine
(4.3.200.v200806050100-784Ag8s733I3C5_4_59) "TPTP Analysis Engine"
org.eclipse.tptp.platform.core
(4.5.1.v200807310709-8Z8DEpNELRXmprpJQYrC5n) "TPTP Platform"
org.eclipse.tptp.platform.core.doc.user
(4.3.300.v200807310709-7B6EAU9oA55S5LAD6D6J) "TPTP Platform Project
Documentation"
org.eclipse.tptp.platform.doc.user
(4.3.300.v200807310709-7B77EAU8_JKQVTMuLIBdBREPCJ7K) "TPTP Platform
Project Documentation"
org.eclipse.tptp.platform.examples
(4.3.200.v200806121215-42_77w311916231943) "TPTP Platform Examples"
org.eclipse.tptp.platform.instrumentation.ui
(4.2.100.v200805120832-78778Y8s733I3D684549) "TPTP Instrumentation UI Core"
org.eclipse.tptp.platform.integration.pde
(4.4.1.v200806121215-4307w311916231943) "TPTP Platform Integration PDE"
org.eclipse.tptp.platform.jvmti
(4.3.200.v200807310709-7877Ag8s733I3H5_4A75) "TPTP JVMTI Profiler Client"
org.eclipse.tptp.platform.la.core
(4.3.200.v200806121215-42_77w311916342227) "Log Analysis Core backward
compatibility"
org.eclipse.tptp.platform.lta
(4.3.200.v200805201414-783CF8s733I3B674G8A) "TPTP Log and Trace Analyzer"
org.eclipse.tptp.platform.probekit
(4.3.300.v200807310709-7F5EII_kE77c7WCG7UCJ) "TPTP ProbeKit"
org.eclipse.tptp.platform.probekit.doc.user
(4.3.200.v200802291616-41_77w311916231943) "Probekit User Documentation"
org.eclipse.tptp.platform.profile.server
(4.3.200.v200807310709-7F79E8P_kE77c7XDH7T_Q) "TPTP Profile on Server"
org.eclipse.tptp.platform.report
(4.2.200.v200805120832-7B5Dq9oA55S5K9B7F_H) "TPTP Charting Service"
org.eclipse.tptp.platform.report.birt
(4.3.300.v200807310709-7877_88s733I3F4C3B65) "TPTP Business Intelligence
and Reporting Tools (BIRT) Reporting Infrastructure"
org.eclipse.tptp.platform.samples
(4.3.200.v200805120832-7B4E9x9oA55S5G9H5LA9) "TPTP Platform Samples"
org.eclipse.tptp.platform.statistical.report.birt
and Reporting Tools (BIRT) Statistical Reports"
org.eclipse.tptp.platform.statistical.ui
(4.1.400.v200805120832-783Ag8s733I3_6A3B65) "TPTP Statistical UI"
org.eclipse.tptp.platform.trace
(4.3.300.v200807310709-7J7EEC5AgI99m9cGQ_WFL) "TPTP Platform Trace"
org.eclipse.tptp.test (4.3.301.v200807310709-7J7DEC6AgI99m9kDWAWHP)
"TPTP Test Framework"
org.eclipse.tptp.test.doc.user
(4.3.300.v200807310709-42_77w31191842181_) "TPTP Test Tools User
Documentation"
org.eclipse.tptp.test.recorders.url
(4.5.1.v200807310709-787908s733I3E763H6D) "TPTP URL Recorder"
org.eclipse.tptp.test.report.birt
(4.4.1.v200807310709-7B7D09oA55S5M_D6D6J) "TPTP Business Intelligence
and Reporting Tools (BIRT) Test Reports"
org.eclipse.tptp.test.runtime
(4.3.300.v200807310709-7F7_EDd7SndHmrSPQ2rBXou4z0FT) "TPTP Test Framework"
org.eclipse.tptp.test.samples (4.2.100.v200805120832-418Y7w311916421211)
"TPTP Test Framework and Tools Samples"
org.eclipse.tptp.test.tools
(4.3.300.v200807310709-7J7JAj_5cMYjYU0bJowWlJUSVSG) "TPTP Test Tools"
org.eclipse.tptp.test.tools.junit
(4.5.1.v200807310709-7F7GCG_kE77c7bAO8MBF) "TPTP JUnit Plug-in Test Tools"
org.eclipse.tptp.trace (4.2.200.v200807310709-781EC58s733I3E763H6D)
"TPTP Trace"
org.eclipse.tptp.trace.arm (4.2.100.v200805120832-782_78s733I3_6D3B65)
"TPTP ARM Monitoring "
org.eclipse.tptp.trace.report.birt
and Reporting Tools (BIRT) Trace Reports"
org.eclipse.wst (3.0.2.v200808250510-7A-8f8QqVJLTFUkFahb1QIq2z0t8) "Web
Standard Tools (WST)"
org.eclipse.wst.ws_wsdl14.feature
(1.4.0.v200802280619-13-7w311917141518) "Web Standard Tools (WST)"
org.eclipse.wst.ws_wsdl15.feature
(1.5.1.v200802280619-1407w311917141519) "Web Standard Tools (WST)"
org.eclipse.xsd (2.4.1.v200808251517) "XSD - XML Schema Definition Model"
org.eclipse.xsd.ecore.converter (2.4.0.v200808251517) "XSD Ecore Converter"
org.eclipse.xsd.edit (2.4.0.v200808251517) "XSD Edit"
org.eclipse.xsd.editor (2.4.0.v200808251517) "XSD Sample Editor"
org.eclipse.xsd.mapping (2.4.0.v200808251517) "XSD Mapping"
org.eclipse.xsd.mapping.editor (2.4.0.v200808251517) "XSD Mapping Editor"
org.polarion.eclipse.team.svn.connector (2.1.0.I20090213-1500)
"Subversive SVN Connectors"
org.polarion.eclipse.team.svn.connector.javahl15 (2.1.0.I20090213-1500)
"Subversive SVN 1.5 JavaHL Connector"
org.polarion.eclipse.team.svn.connector.javahl15.win32
(2.1.0.I20090213-1500) "JavaHL 1.5.4 Win32 Binaries"
org.polarion.eclipse.team.svn.connector.svnkit15 (2.1.0.I20090213-1500)
"Subversive SVN 1.5 SVN Kit Connector"
sf.eclipse.javacc.feature (1.5.13) "JavaCC Plug-in"
sf.eclipse.javacc.help.feature (1.5.0) "JavaCC plug-in Help"
*** Plug-in Registry:
ch.ethz.iks.r_osgi.remote (1.0.0.RC2_v20080916-1301) "R_OSGi Remote
Service" [Active]
ch.ethz.iks.slp (1.0.0.RC4_v200806091030) "jSLP" [Active]
com.ibm.icu (3.8.1.v20080530) "International Components for Unicode for
Java (ICU4J)" [Active]
com.jcraft.jsch (0.1.37.v200803061811) "JSch" [Resolved]
com.lowagie.itext (1.5.4.v20080228) "Lowagie Itext" [Resolved]
com.mountainminds.eclemma.core (1.3.2) "EclEmma Core" [Starting]
com.mountainminds.eclemma.doc (1.3.2) "EclEmma Documentation" [Resolved]
com.mountainminds.eclemma.ui (1.3.2) "EclEmma UI" [Starting]
com.sun.syndication (0.9.0.v200803061811) "Rss and atOM utilitiEs
(ROME)" [Resolved]
com.tasktop.client (1.3.0.v20081106-1400) "Tasktop Client Plug-in" [Active]
com.tasktop.client.install.p2 (1.3.0.v20081106-1400) "Tasktop P2
Installer" [Resolved]
com.tasktop.client.lite (1.3.0.v20081106-1400) "Tasktop Lite Plug-in"
[Active]
com.tasktop.doc.ui (1.3.0.v20081106-1400) "Tasktop Documentation
Plug-in" [Starting]
com.tasktop.email.core (1.3.0.v20081106-1400) "Email Core Plug-in" [Active]
com.tasktop.email.ui (1.3.0.v20081106-1400) "Email Ui Plug-in" [Active]
com.tasktop.google.desktop (1.3.0.v20081106-1400) "Google Desktop
Plug-in" [Starting]
com.tasktop.google.mail.core (1.3.0.v20081106-1400) "Gmail Core Plug-in"
[Active]
com.tasktop.google.mail.ui (1.3.0.v20081106-1400) "Gmail Ui Plug-in"
[Active]
com.tasktop.imap.core (1.3.0.v20081106-1400) "Imap Core Plug-in" [Active]
com.tasktop.imap.ui (1.3.0.v20081106-1400) "Imap Ui Plug-in" [Active]
com.tasktop.reporting.core (1.3.0.v20081106-1400) "Reporting Core
Plug-in" [Starting]
com.tasktop.reporting.dash (1.3.0.v20081106-1400) "Tasktop Reporting
Dash Plug-in" [Starting]
dk.contix.eclipse.hudson (1.0.4) "Hudson Plug-in for Eclipse" [Starting]
javax.activation (1.1.0.v200806101325) "Apache Geronimo Activation
Plug-in" [Resolved]
javax.mail (1.4.0.v200804091730) "Javax Mail Plug-in" [Resolved]
javax.servlet (2.4.0.v200806031604) "Servlet API Bundle" [Resolved]
javax.servlet (2.5.0.v200806031605) "Servlet API Bundle" [Resolved]
javax.servlet.jsp (2.0.0.v200806031607) "Java Server Pages API Bundle"
[Resolved]
javax.wsdl (1.4.0.v200806030407) "WSDL4J" [Resolved]
javax.wsdl (1.5.1.v200806030408) "WSDL4J" [Resolved]
javax.xml (1.3.4.v200806030440) "JAXP XML" [Resolved]
javax.xml.bind (2.0.0.v20080604-1500) "JAXB" [Resolved]
javax.xml.rpc (1.1.0.v200806030420) "JAX-RPC" [Resolved]
javax.xml.soap (1.2.0.v200806030421) "SAAJ" [Resolved]
net.sf.wickedshell (2.0.4) "Wicked Shell Plug-in" [Starting]
net.sf.wickedshell.domain (2.0.4) "Wicked Shell Domain Plug-in" [Starting]
net.sf.wickedshell.jdt (2.0.4) "Wicked Shell JDT support Plug-in" [Resolved]
net.sf.wickedshell.resources (2.0.4) "Wicked Shell Resources support
Plug-in" [Resolved]
net.sf.wickedshell.shell (2.0.4) "Wicked Shell custom shells Plug-in"
[Resolved]
net.sf.wickedshell.ui (2.0.4) "Wicked Shell UI Plug-in" [Resolved]
net.sourceforge.lpg.lpgjavaruntime (1.1.0.v200803061910) "SourceForge
LPG" [Resolved]
org.apache.ant (1.7.0.v200803061910) "Apache Ant" [Resolved]
org.apache.axis (1.4.0.v200807230600) "Apache Web Services" [Resolved]
org.apache.batik.bridge (1.6.0.v200805290154) "Apache Batik
Bridge/GVT/Scripting" [Resolved]
org.apache.batik.css (1.6.0.v200805290154) "Apache Batik CSS" [Resolved]
org.apache.batik.dom (1.6.0.v200805290154) "Apache Batik DOM" [Resolved]
org.apache.batik.dom.svg (1.6.0.v200805290154) "Apache Batik SVG DOM"
[Resolved]
org.apache.batik.ext.awt (1.6.0.v200805290154) "Apache Batik AWT
Utilities" [Resolved]
org.apache.batik.extension (1.6.0.v200805290154) "Apache Batik
Extension" [Resolved]
org.apache.batik.parser (1.6.0.v200805290154) "Apache Batik Parser"
[Resolved]
org.apache.batik.pdf (1.6.0.v200806031500) "Apache Batik PDF" [Resolved]
org.apache.batik.svggen (1.6.0.v200805290154) "Apache Batik SVG
Generation" [Resolved]
org.apache.batik.swing (1.6.0.v200805290154) "Apache Batik Swing" [Resolved]
org.apache.batik.transcoder (1.6.0.v200805290154) "Apache Batik
Transcoder" [Resolved]
org.apache.batik.util (1.6.0.v200805290154) "Apache Batik Utilities"
[Resolved]
org.apache.batik.util.gui (1.6.0.v200805290154) "Apache Batik GUI
org.apache.batik.xml (1.6.0.v200805290154) "Apache Batik XML" [Resolved]
org.apache.cactus (1.7.2.v200805140145) "Cactus Resource Plug-in" [Starting]
org.apache.commons.codec (1.3.0.v20080530-1600) "Apache Commons Codec
Plug-in" [Resolved]
org.apache.commons.collections (3.2.0) "Apache Commons Collections
Plug-in" [Resolved]
org.apache.commons.discovery (0.2.0.v200806030120) "Jakarta-Commons
Discovery" [Resolved]
org.apache.commons.el (1.0.0.v200806031608) "Apache Commons JSP 2.0
Expression Language Interpreter" [Resolved]
org.apache.commons.httpclient (3.1.0.v20080605-1935) "Apache Commons
Httpclient" [Resolved]
org.apache.commons.lang (2.3.0.v200803061910) "Apache Jakarta Commons
Lang" [Resolved]
org.apache.commons.logging (1.0.4.v20080605-1930) "Apache Commons
Logging Plug-in" [Resolved]
org.apache.commons.logging (1.1.1.v20080605-1935) "Apache Commons
org.apache.jasper (5.5.17.v200806031609) "Apache Jasper 2 Plug-in"
[Resolved]
org.apache.log4j (1.2.13.v200806030600) "Apache Jakarta log4j Plug-in"
[Resolved]
org.apache.lucene (1.9.1.v20080530-1600) "Apache Lucene" [Resolved]
org.apache.lucene.analysis (1.9.1.v20080530-1600) "Apache Lucene
Analysis" [Resolved]
org.apache.ws.commons.util (1.0.0.v20080530-1550) "WS Commons Util
Plug-in" [Resolved]
org.apache.wsil4j (1.0.0.v200806040330) "WSIL4J" [Resolved]
org.apache.xerces (2.9.0.v200805270400) "Apache Xerces-J" [Resolved]
org.apache.xml.resolver (1.2.0.v200806030312) "Apache XmlResolver"
[Resolved]
org.apache.xml.serializer (2.7.1.v200806030322) "Apache XML Commons
Serializer" [Resolved]
org.apache.xmlbeans (2.3.1) "Apache XML Beans Plug-in" [Resolved]
org.apache.xmlrpc (3.0.0.v20080530-1550) "Apache XML-RPC Plug-in" [Resolved]
org.eclipse.ant.core (3.2.0.v20080529) "Ant Build Tool Core" [Starting]
org.eclipse.ant.ui (3.3.0.v20080529) "Ant UI" [Starting]
org.eclipse.birt.chart.device.extension (2.3.1.v20080905) "BIRT Chart
Device Extension(s)" [Starting]
org.eclipse.birt.chart.device.svg (2.3.1.v20080905) "BIRT Chart Device
SVG Extension" [Starting]
org.eclipse.birt.chart.device.swt (2.3.1.v20080731) "BIRT Chart Device
SWT Extension" [Starting]
org.eclipse.birt.chart.engine (2.3.1.v20080905) "BIRT Chart Engine"
[Starting]
org.eclipse.birt.chart.engine.extension (2.3.1.v20080821) "BIRT Chart
Engine Extension" [Starting]
org.eclipse.birt.core (2.3.1.v20080912) "BIRT Core Package" [Starting]
org.eclipse.birt.data (2.3.2.r232_v20090211) "BIRT Data Engine" [Starting]
org.eclipse.birt.data.aggregation (2.3.2.r232_v20090211) "Build-in
Aggregation Plug-in" [Starting]
org.eclipse.birt.report.data.adapter (2.3.2.r232_v20090211) "BIRT Data
Adapter" [Starting]
org.eclipse.birt.report.data.oda.xml (2.3.2.r232_v20090211) "BIRT
ODA-XML Driver" [Starting]
org.eclipse.birt.report.engine (2.3.2.r232_20090217) "BIRT Engine"
[Starting]
org.eclipse.birt.report.engine.fonts (2.3.2.r232_20090202) "BIRT Engine
fonts" [Resolved]
org.eclipse.birt.report.model (2.3.2.r232_20090115) "BIRT Model" [Starting]
org.eclipse.compare (3.4.0.I20080604) "Compare Support" [Active]
org.eclipse.core.boot (3.1.100.v20080218) "Core Boot" [Starting]
org.eclipse.core.commands (3.4.0.I20080509-2000) "Commands" [Resolved]
org.eclipse.core.contenttype (3.3.0.v20080604-1400) "Eclipse Content
Mechanism" [Active]
org.eclipse.core.databinding (1.1.1.M20080827-0800b) "JFace Data
Binding" [Active]
org.eclipse.core.databinding.beans (1.1.1.M20080827-0800a) "JFace Data
Binding for JavaBeans" [Resolved]
org.eclipse.core.expressions (3.4.0.v20080603-2000) "Expression
Language" [Active]
org.eclipse.core.filebuffers (3.4.0.v20080603-2000) "File Buffers" [Active]
org.eclipse.core.filesystem (1.2.0.v20080604-1400) "Core File Systems"
[Active]
org.eclipse.core.filesystem.win32.x86 (1.1.0.v20080604-1400) "Core File
System for Windows" [Resolved]
org.eclipse.core.jobs (3.4.0.v20080512) "Eclipse Jobs Mechanism" [Active]
org.eclipse.core.net (1.1.0.I20080604) "Internet Connection Management"
[Active]
org.eclipse.core.net.win32.x86 (1.0.0.I20080521) "Proxy for Windows"
[Resolved]
org.eclipse.core.resources (3.4.1.R34x_v20080902) "Core Resource
Management" [Active]
org.eclipse.core.resources.compatibility (3.4.0.v20080604-1400) "Core
Resource Management Compatibility Fragment" [Resolved]
org.eclipse.core.resources.win32.x86 (3.4.0.v20071204) "Core Resource
Management Win32 Fragment" [Resolved]
org.eclipse.core.runtime (3.4.0.v20080512) "Core Runtime" [Active]
org.eclipse.core.runtime.compatibility (3.2.0.v20071008) "Core Runtime
Plug-in Compatibility" [Active]
org.eclipse.core.runtime.compatibility.auth (3.2.100.v20070502)
"Authorization Compatibility Plug-in" [Active]
org.eclipse.core.runtime.compatibility.registry (3.2.200.v20080610)
"Eclipse Registry Compatibility Fragment" [Resolved]
org.eclipse.core.variables (3.2.100.v20080529-1300) "Core Variables"
[Active]
org.eclipse.cvs (1.0.100.v20080603) "Eclipse CVS Client" [Starting]
org.eclipse.datatools.connectivity (1.1.1.v200809180120) "Data Tools
Platform Connectivity Plug-in" [Starting]
org.eclipse.datatools.connectivity.apache.derby (1.0.1.v200807150030)
"Eclipse Data Tools Platform Derby Plug-in" [Starting]
org.eclipse.datatools.connectivity.apache.derby.dbdefinition
(1.0.0.v200805152355) "Eclipse Data Tools Platform Apache Derby Database
Definition" [Starting]
org.eclipse.datatools.connectivity.apache.derby.ui (1.0.1.v200807010433)
"Eclipse Data Tools Platform Apache Derby UI Plug-in" [Starting]
org.eclipse.datatools.connectivity.console.profile (1.0.0.v200805231345)
"DTP Connection Profiles Storage File Editor Plug-in" [Starting]
org.eclipse.datatools.connectivity.db.generic (1.0.0.v200805152355)
"Eclipse Data Tools Platform Generic DB Connectivity Plug-in" [Starting]
org.eclipse.datatools.connectivity.db.generic.ui (1.0.1.v200805152355)
"Eclipse Data Tools Platform Generic DB UI Plug-in" [Starting]
org.eclipse.datatools.connectivity.dbdefinition.genericJDBC
(1.0.0.v200805152355) "Eclipse Data Tools Platform DBDefinition Generic
JDBC Plug-in" [Starting]
org.eclipse.datatools.connectivity.oda (3.1.3.v200808270255) "DTP Open
Data Access" [Starting]
org.eclipse.datatools.connectivity.oda.consumer (3.1.3.v200808270255)
"DTP ODA Consumer Helper Component Plug-in" [Starting]
org.eclipse.datatools.connectivity.oda.design (3.0.7.v200807231215) "DTP
ODA Design Session Model" [Starting]
org.eclipse.datatools.connectivity.oda.design.ui (3.0.7.v200808051050)
"DTP ODA Designer UI Framework Plug-in" [Starting]
org.eclipse.datatools.connectivity.oda.flatfile (3.0.7.v200808261835)
"Eclipse Data Tools Platform Flat File ODA Runtime Driver" [Starting]
org.eclipse.datatools.connectivity.oda.flatfile.ui (3.0.7.v200808130628)
"Eclipse Data Tools Platform Flat File ODA Designer" [Starting]
org.eclipse.datatools.connectivity.oda.profile (3.0.6.v200805152355)
"DTP ODA Connection Profile Framework Plug-in" [Starting]
org.eclipse.datatools.connectivity.oda.template.ui (3.0.6.v200805152355)
"DTP ODA New Plug-in Template Wizard" [Starting]
org.eclipse.datatools.connectivity.sqm.core (1.0.3.v200809180120)
"Eclipse Data Tools Platform SQM Core Plug-in" [Starting]
org.eclipse.datatools.connectivity.sqm.core.ui (1.1.1.v200808140022)
"Eclipse Data Tools Platform SQM UI Plug-in" [Starting]
org.eclipse.datatools.connectivity.sqm.server.ui (1.1.1.v200808300421)
"Eclipse Data Tools Platform Server UI Plug-in" [Starting]
org.eclipse.datatools.connectivity.ui (1.1.2.v200809150616) "Data Tools
Platform Connectivity UI Plug-in" [Starting]
org.eclipse.datatools.connectivity.ui.dse (1.1.1.v200807230727) "Eclipse
Data Tools Platform Data Source Explorer Plug-in" [Starting]
org.eclipse.datatools.doc.user (1.6.1.v20080828133713) "Data Tools
Platform User Documentation" [Resolved]
org.eclipse.datatools.enablement.finfo (1.5.1.v200805152355) "Eclipse
Data Tools Platform Enablement" [Starting]
org.eclipse.datatools.enablement.hsqldb (1.0.0.v200805152355) "Eclipse
Data Tools Platform HSQLDB Enablement Plug-in" [Starting]
org.eclipse.datatools.enablement.hsqldb.dbdefinition
(1.0.0.v200805152355) "Eclipse Data Tools Platform HSQLDB Database
Definition Enablement Plug-in" [Starting]
org.eclipse.datatools.enablement.hsqldb.ui (1.0.0.v200807220100)
"Eclipse Data Tools Platform HSQLDB UI Enablement Plug-in" [Starting]
org.eclipse.datatools.enablement.ibm.db2.iseries (1.0.0.v200805152355)
"Eclipse Data Tools Platform IBM DB2 UDB iSeries Plug-in" [Starting]
org.eclipse.datatools.enablement.ibm.db2.iseries.dbdefinitio n
(1.0.0.v200806100223) "DB2 UDB iSeries Database Definition Plug-in"
[Starting]
org.eclipse.datatools.enablement.ibm.db2.iseries.ui
(1.0.0.v200805160737) "Eclipse Data Tools Platform IBM DB2 UDB UI
org.eclipse.datatools.enablement.ibm.db2.luw (1.0.0.v200805152355)
"Eclipse Data Tools Platform IBM DB2 UDB LUW Plug-in" [Starting]
org.eclipse.datatools.enablement.ibm.db2.luw.dbdefinition
(1.0.0.v200805152355) "Eclipse Data Tools Platform DB2 UDB Database
Definition Plug-in" [Starting]
org.eclipse.datatools.enablement.ibm.db2.luw.ui (1.0.1.v200806260315)
"Eclipse Data Tools Platform IBM DB2 UDB LUW UI Plug-in" [Starting]
org.eclipse.datatools.enablement.ibm.db2.zseries (1.0.0.v200805152355)
"Eclipse Data Tools Platform IBM DB2 UDB zSeries Plug-in" [Starting]
org.eclipse.datatools.enablement.ibm.db2.zseries.dbdefinitio n
(1.0.0.v200805152355) "DB2 UDB Database Definition Plug-in" [Starting]
org.eclipse.datatools.enablement.ibm.db2.zseries.ui
(1.0.0.v200805160737) "Eclipse Data Tools Platform IBM DB2 UDB zSeries
org.eclipse.datatools.enablement.ibm.informix (1.0.0.v200805152355)
"Eclipse Data Tools Platform Informix Plug-in" [Starting]
org.eclipse.datatools.enablement.ibm.informix.dbdefinition
(1.0.1.v200807170829) "Eclipse Data Tools Platform Informix Database
org.eclipse.datatools.enablement.ibm.informix.ui (1.0.1.v200806260315)
"Eclipse Data Tools Platform Informix UI Plug-in" [Starting]
org.eclipse.datatools.enablement.ibm.ui (1.0.0.v200806271414) "Eclipse
Data Tools Platform IBM UI Plug-in" [Starting]
org.eclipse.datatools.enablement.jdt.classpath (1.0.1.v200805152355)
"Data Tools Platform Connectivity JDT Extension Plug-in" [Starting]
org.eclipse.datatools.enablement.msft.sqlserver (1.0.1.v200807181158)
"Eclipse Data Tools Platform Microsoft SQL Server Plug-in" [Starting]
org.eclipse.datatools.enablement.msft.sqlserver.dbdefinition
(1.0.0.v200805152355) "Eclipse Data Tools Platform SQL Server Database
org.eclipse.datatools.enablement.msft.sqlserver.ui (1.0.1.v200808222228)
"Eclipse Data Tools Platform Microsoft SQL Server UI Plug-in" [Starting]
org.eclipse.datatools.enablement.mysql (1.0.1.v200808261158) "Eclipse
Data Tools Platform MySQL Enablement Plug-in" [Starting]
org.eclipse.datatools.enablement.mysql.dbdefinition
(1.0.1.v200805170742) "Eclipse Data Tools Platform MySQL Database
org.eclipse.datatools.enablement.mysql.ui (1.0.0.v200805152355) "Eclipse
Data Tools Platform MySQL UI Plug-in" [Starting]
org.eclipse.datatools.enablement.oda.ws (1.1.1.v200808211640) "Eclipse
Data Tools Platform Web Services ODA Runtime Driver" [Starting]
org.eclipse.datatools.enablement.oda.ws.ui (1.1.1.v200808271112)
"Eclipse Data Tools Platform Web Services ODA Designer" [Starting]
org.eclipse.datatools.enablement.oda.xml (1.1.1.v200808261409) "Eclipse
Data Tools Platform XML ODA Runtime Driver" [Starting]
org.eclipse.datatools.enablement.oda.xml.ui (1.1.1.v200808130628)
"Eclipse Data Tools Platform XML ODA Designer" [Starting]
org.eclipse.datatools.enablement.oracle (1.0.0.v200805152355) "Eclipse
Data Tools Platform Oracle Plug-in" [Starting]
org.eclipse.datatools.enablement.oracle.dbdefinition
(1.0.1.v200808021450) "Eclipse Data Tools Platform Oracle Database
org.eclipse.datatools.enablement.oracle.ui (1.0.1.v200806260315)
"Eclipse Data Tools Platform Oracle UI Plug-in" [Starting]
org.eclipse.datatools.enablement.postgresql (1.0.1.v200805152355)
"PostgreSQL Connection Profile and Driver Template Plug-in" [Starting]
org.eclipse.datatools.enablement.postgresql.dbdefinition
(1.0.0.v200805152355) "PostgreSQL DB Definition" [Starting]
org.eclipse.datatools.enablement.postgresql.ui (1.0.0.v200806060334)
"PostgreSQL Connection Profile and Driver Template UI Plug-in" [Starting]
org.eclipse.datatools.enablement.sap.maxdb (1.0.0.v200805152355)
"Eclipse Data Tools Platform MaxDB Enablement Plug-in" [Starting]
org.eclipse.datatools.enablement.sap.maxdb.dbdefinition
(1.0.0.v200805152355) "Eclipse Data Tools Platform MaxDB Definition
Plug-in" [Starting]
org.eclipse.datatools.enablement.sap.maxdb.ui (1.0.0.v200805152355)
"Eclipse Data Tools Platform MaxDB UI Plug-in" [Starting]
org.eclipse.datatools.enablement.sybase (1.0.1.v200805310538)
"High-level Sybase Enablement Plug-in" [Starting]
org.eclipse.datatools.enablement.sybase.asa (1.0.1.v200805310538)
"Sybase ASA Plug-in" [Starting]
org.eclipse.datatools.enablement.sybase.asa.dbdefinition
(1.0.0.v200805240040) "Eclipse Data Tools Platform Sybase ASA Database
org.eclipse.datatools.enablement.sybase.asa.models (1.0.0.v200805152355)
"Sybase ASA SQL Model" [Starting]
org.eclipse.datatools.enablement.sybase.asa.ui (1.0.1.v200805310538)
"Sybase ASA Connection Profile UI Plug-in" [Starting]
org.eclipse.datatools.enablement.sybase.ase (1.0.1.v200807010411)
"JDBC/Sybase ASE Connection Profile Plug-in" [Starting]
org.eclipse.datatools.enablement.sybase.ase.dbdefinition
(1.0.0.v200805240040) "Eclipse Data Tools Platform Sybase ASE Database
org.eclipse.datatools.enablement.sybase.ase.models (1.0.1.v200805152355)
"Sybase ASE Model Plug-in" [Starting]
org.eclipse.datatools.enablement.sybase.ase.ui (1.0.1.v200806260315)
"ASE Enablement UI Plug-in" [Starting]
org.eclipse.datatools.enablement.sybase.models (1.0.0.v200805152355)
"Sybase Model Plug-in" [Starting]
org.eclipse.datatools.enablement.sybase.ui (1.0.0.v200808221518) "Sybase
org.eclipse.datatools.help (1.5.0.v200805152355) "Data Tools Platform
Help Utilities" [Resolved]
org.eclipse.datatools.modelbase.dbdefinition (1.0.1.v200901090853)
"Eclipse Data Tools Platform DBDefinition Model" [Starting]
org.eclipse.datatools.modelbase.derby (1.0.0.v200805152355) "Derby
Plug-in" [Starting]
org.eclipse.datatools.modelbase.sql (1.0.1.v200812031125) "Eclipse Data
Tools Platform SQLModel Plug-in" [Starting]
org.eclipse.datatools.modelbase.sql.edit (1.0.0.v200805152355) "Eclipse
Data Tools Platform SQLModel Edit Plug-in" [Starting]
org.eclipse.datatools.modelbase.sql.query (1.0.1.v200901241145) "Eclipse
Data Tools Platform SQL Query Model Plugin" [Starting]
org.eclipse.datatools.modelbase.sql.query.edit (1.0.0.v200806070329)
"SQL Query Edit Support Plugin" [Starting]
org.eclipse.datatools.modelbase.sql.xml.query (1.0.0.v200807080500)
"Eclipse Data Tools Platform SQL XML Query Model Plugin" [Starting]
org.eclipse.datatools.oda.cshelp (1.1.0.v200808280228) "DTP ODA
Context-sensitive Help" [Starting]
org.eclipse.datatools.sqltools.common.ui (1.0.0.v200807211830) "Eclipse
Data Tools Platform SQL Tools Common UI Plug-in" [Starting]
org.eclipse.datatools.sqltools.db.derby (1.0.0.v200805152355) "Eclipse
Data Tools Platform Derby SQL Tools Plug-in" [Starting]
org.eclipse.datatools.sqltools.db.generic (1.0.0.v200808140643) "Eclipse
Data Tools Platform SQL Tools Generic Database Plug-in" [Starting]
org.eclipse.datatools.sqltools.ddlgen.ui (1.0.0.v200808140615) "Eclipse
Data Tools Platform FE UI Plug-in" [Starting]
org.eclipse.datatools.sqltools.debugger.core (1.0.0.v200808140615)
"Eclipse Data Tools Platform SQL Debugger Framework" [Starting]
org.eclipse.datatools.sqltools.editor.core (1.0.0.v200808271350)
"Eclipse Data Tools Platform SQL Editor Core Plug-in" [Starting]
org.eclipse.datatools.sqltools.parsers.sql (1.0.1.v200808140615)
"Eclipse Data Tools Platform SQL Parser Plugin" [Starting]
org.eclipse.datatools.sqltools.parsers.sql.lexer (1.0.1.v200808080530)
"Eclipse Data Tools Platform Lexer Plug-in" [Starting]
org.eclipse.datatools.sqltools.parsers.sql.query (1.0.1.v200808140615)
"Eclipse Data Tools Platform SQL Query Parser Plugin" [Starting]
org.eclipse.datatools.sqltools.parsers.sql.xml.query
(1.0.0.v200808140615) "Eclipse Data Tools Platform SQL XML Query Parser
Plugin" [Starting]
org.eclipse.datatools.sqltools.plan (1.0.0.v200807211830) "Eclipse Data
Tools Platform SQL Execution Plan View Plug-in" [Starting]
org.eclipse.datatools.sqltools.result (1.0.0.v200808271350) "Eclipse
Data Tools Platform SQL Results View Plug-in" [Starting]
org.eclipse.datatools.sqltools.routineeditor (1.0.0.v200807211830)
"Eclipse Data Tools Platform SQL Tools Routine Editor Plug-in" [Starting]
org.eclipse.datatools.sqltools.sql (1.0.0.v200808140615) "Eclipse Data
Tools Platform SQL Core Plug-in" [Starting]
org.eclipse.datatools.sqltools.sqlbuilder (1.0.0.v200808271350) "SQL
Builder" [Starting]
org.eclipse.datatools.sqltools.sqleditor (1.0.0.v200808271350) "Eclipse
Data Tools Platform SQL Editor" [Starting]
org.eclipse.datatools.sqltools.sqlscrapbook (1.0.0.v200808271350)
"Eclipse Data Tools Platform Sqlscrapbook Plug-in" [Starting]
org.eclipse.datatools.sqltools.tablewizard (1.0.0.v200808140615)
"Eclipse Data Tools Platform Database Table Creation Plug-in" [Starting]
org.eclipse.debug.core (3.4.0.v20080612) "Debug Core" [Active]
org.eclipse.debug.ui (3.4.1.v20080811_r341) "Debug UI" [Starting]
org.eclipse.draw2d (3.4.2.v20090114-1330) "Graphical Editing Framework
Draw2d" [Starting]
org.eclipse.ecf (2.0.0.v20080611-1715) "Eclipse Communication Framework
(ECF)" [Active]
org.eclipse.ecf.core.source (2.0.1.v20080916-1301) "ECF Core Source"
[Resolved]
org.eclipse.ecf.datashare (1.3.0.v20080916-1301) "ECF DataShare API"
[Resolved]
org.eclipse.ecf.discovery (2.0.0.v20080916-1301) "ECF Discovery API"
[Active]
org.eclipse.ecf.discovery.ui (2.0.0.v20080916-1301) "ECF Discovery UI"
[Starting]
org.eclipse.ecf.doc (1.3.0.v20080916-1301) "ECF Documentation" [Starting]
org.eclipse.ecf.docshare (2.0.0.v20080916-1301) "ECF DocShare Plugin"
[Active]
org.eclipse.ecf.example.clients (1.3.0.v20080916-1301) "ECF Clients
Example" [Resolved]
org.eclipse.ecf.example.collab (1.3.0.v20080916-1301) "ECF Collaboration
Examples" [Starting]
org.eclipse.ecf.example.collab.editor (1.0.200.v20080916-1301) "ECF
Shared Editor Example" [Starting]
org.eclipse.ecf.examples.remoteservices.client (1.0.100.v20080916-1301)
"ECF RemoteServices Example Client" [Starting]
org.eclipse.ecf.examples.remoteservices.common (1.0.100.v20080916-1301)
"ECF RemoteServices Example Common" [Starting]
org.eclipse.ecf.examples.remoteservices.server (1.0.100.v20080916-1301)
"ECF RemoteServices Example Server" [Starting]
org.eclipse.ecf.examples.source (2.0.1.v20080916-1301) "ECF Examples
Source" [Resolved]
org.eclipse.ecf.examples.updatesite.client (1.0.100.v20080916-1301) "ECF
Updatesite Example Client" [Starting]
org.eclipse.ecf.examples.updatesite.server (1.0.100.v20080916-1301) "ECF
Updatesite Example Server" [Starting]
org.eclipse.ecf.filetransfer (2.0.0.v20080611-1715) "ECF Filetransfer
API" [Active]
org.eclipse.ecf.filetransfer.ui (1.4.0.v20080916-1301) "ECF File
Transfer UI" [Starting]
org.eclipse.ecf.identity (2.0.0.v20080611-1715) "ECF Identity API" [Active]
org.eclipse.ecf.presence (1.3.0.v20080916-1301) "ECF Presence API"
[Starting]
org.eclipse.ecf.presence.bot (1.2.0.v20080916-1301) "ECF Presence Bot
API" [Starting]
org.eclipse.ecf.presence.collab.ui (1.2.0.v20080916-1301) "ECF Presence
Collaboration UI" [Active]
org.eclipse.ecf.presence.ui (1.2.0.v20080916-1301) "ECF Presence UI"
[Starting]
org.eclipse.ecf.protocol.bittorrent (0.3.0) "ECF BitTorrent Protocol
Implementation" [Resolved]
org.eclipse.ecf.protocol.msn (1.2.0.v20080916-1301) "ECF MSN Protocol
org.eclipse.ecf.provider (1.3.0.v20080916-1301) "ECF Provider API" [Active]
org.eclipse.ecf.provider.bittorrent (0.3.0.v20080916-1301) "ECF
Bittorrent Provider" [Active]
org.eclipse.ecf.provider.bittorrent.ui (0.2.0.v20080916-1301) "ECF
Bitorrent Provider UI" [Starting]
org.eclipse.ecf.provider.datashare (1.3.0.v20080916-1301) "ECF Datashare
Provider" [Starting]
org.eclipse.ecf.provider.discovery (2.0.0.v20080916-1301) "ECF Discovery
Provider" [Active]
org.eclipse.ecf.provider.filetransfer (2.0.0.v20080611-1715) "ECF
Filetransfer Provider" [Active]
org.eclipse.ecf.provider.filetransfer.efs (1.5.0.v20080916-1301) "ECF
EFS Provider" [Active]
org.eclipse.ecf.provider.filetransfer.scp (2.0.0.v20080916-1301) "ECF
SCP Filetransfer Provider" [Active]
org.eclipse.ecf.provider.filetransfer.ssl (1.0.0.v20080611-1715) "ECF
Filetransfer Provider" [Resolved]
org.eclipse.ecf.provider.irc (1.3.0.v20080916-1301) "ECF IRC Provider"
[Active]
org.eclipse.ecf.provider.irc.ui (1.3.0.v20080916-1301) "ECF IRC UI"
[Starting]
org.eclipse.ecf.provider.jmdns (2.0.0.v20080916-1301) "ECF Discovery
Provider" [Active]
org.eclipse.ecf.provider.jslp (2.0.0.v20080916-1301) "ECF SLP Discovery
Provider" [Active]
org.eclipse.ecf.provider.msn (1.2.0.v20080916-1301) "ECF MSN Provider"
[Active]
org.eclipse.ecf.provider.msn.ui (1.3.0.v20080916-1301) "ECF MSN Provider
UI" [Starting]
org.eclipse.ecf.provider.r_osgi (2.0.0.v20080916-1301) "ECF R-OSGi
Remoteservice Provider" [Active]
org.eclipse.ecf.provider.remoteservice (1.3.0.v20080916-1301) "ECF
Remoteservice Provider" [Starting]
org.eclipse.ecf.provider.ui (1.3.0.v20080916-1301) "ECF Provider UI"
[Starting]
org.eclipse.ecf.provider.xmpp (2.0.100.v20080916-1301) "ECF XMPP
Provider" [Active]
org.eclipse.ecf.provider.xmpp.ui (2.0.0.v20080916-1301) "ECF XMPP
org.eclipse.ecf.remoteservice (2.0.0.v20080916-1301) "ECF Remoteservice
API" [Starting]
org.eclipse.ecf.remoteservice.ui (2.0.0.v20080916-1301) "ECF Remote
Services UI" [Starting]
org.eclipse.ecf.server (1.3.0.v20080916-1301) "ECF Server API" [Starting]
org.eclipse.ecf.server.generic (1.2.0.v20080916-1301) "ECF Generic
Server" [Starting]
org.eclipse.ecf.sharedobject (1.3.0.v20080916-1301) "ECF Sharedobject
API" [Active]
org.eclipse.ecf.ssl (1.0.0.v20080611-1715) "Eclipse Communication
Framework (ECF)" [Resolved]
org.eclipse.ecf.telephony.call (1.2.0.v20080916-1301) "ECF Telephony
Call API" [Starting]
org.eclipse.ecf.telephony.call.ui (1.2.0.v20080916-1301) "ECF Call UI"
[Starting]
org.eclipse.ecf.ui (2.0.0.v20080916-1301) "ECF UI" [Starting]
org.eclipse.emf (2.4.0.v200808251517) "EMF - Eclipse Modeling Framework"
[Starting]
org.eclipse.emf.ant (2.4.0.v200808251517) "EMF Ant Tasks" [Starting]
[Starting]
Generator" [Starting]
Generator UI" [Starting]
UI" [Starting]
org.eclipse.emf.common (2.4.0.v200808251517) "EMF Common" [Active]
org.eclipse.emf.common.ui (2.4.0.v200808251517) "EMF Common UI" [Starting]
org.eclipse.emf.converter (2.4.0.v200808251517) "EMF Model Converter"
[Starting]
[Starting]
Binding" [Starting]
org.eclipse.emf.ecore (2.4.1.v200808251517) "EMF Ecore" [Active]
org.eclipse.emf.ecore.change (2.4.0.v200808251517) "EMF Change Model"
[Starting]
org.eclipse.emf.ecore.change.edit (2.4.0.v200808251517) "EMF Change
Edit" [Starting]
org.eclipse.emf.ecore.edit (2.4.1.v200808251517) "EMF Ecore Edit" [Starting]
Editor" [Starting]
org.eclipse.emf.ecore.xmi (2.4.1.v200808251517) "EMF XML/XMI
Persistence" [Active]
org.eclipse.emf.edit (2.4.1.v200808251517) "EMF Edit" [Starting]
org.eclipse.emf.edit.ui (2.4.1.v200808251517) "EMF Edit UI" [Starting]
org.eclipse.emf.exporter (2.4.0.v200808251517) "EMF Model Exporter"
[Starting]
org.eclipse.emf.importer (2.4.1.v200808251517) "EMF Model Importer"
[Starting]
org.eclipse.emf.importer.ecore (2.4.0.v200808251517) "EMF Ecore
Importer" [Starting]
org.eclipse.emf.importer.java (2.4.1.v200808251517) "EMF Annotated Java
org.eclipse.emf.importer.rose (2.4.0.v200808251517) "EMF Rose Importer"
[Starting]
org.eclipse.emf.mapping (2.4.0.v200808251517) "EMF Mapping" [Starting]
[Starting]
Mapping Editor" [Starting]
org.eclipse.emf.mapping.ecore2ecore (2.4.0.v200808251517) "EMF Ecore to
Ecore Mapping" [Starting]
org.eclipse.emf.mapping.ecore2ecore.editor (2.4.0.v200808251517) "EMF
Ecore to Ecore Mapping Editor" [Starting]
org.eclipse.emf.mapping.ecore2xml (2.4.0.v200808251517) "EMF Ecore to
XML Mapping" [Starting]
org.eclipse.emf.mapping.ecore2xml.ui (2.4.0.v200808251517) "EMF Ecore to
XML Mapping Editor" [Starting]
org.eclipse.emf.mapping.ui (2.4.0.v200808251517) "EMF Mapping UI" [Starting]
org.eclipse.emf.mapping.xsd2ecore (2.4.0.v200808251517) "XSD to Ecore
Mapping" [Starting]
org.eclipse.emf.mapping.xsd2ecore.editor (2.4.0.v200808251517) "XSD to
org.eclipse.equinox.app (1.1.0.v20080421-2006) "Equinox Application
Container" [Active]
org.eclipse.equinox.common (3.4.0.v20080421-2006) "Common Eclipse
Runtime" [Active]
org.eclipse.equinox.frameworkadmin (1.0.2.R34x_v20080910) "Equinox
Framework Admin" [Active]
org.eclipse.equinox.frameworkadmin.equinox (1.0.2.R34x_v20080911)
"Equinox Framework Admin for Equinox" [Active]
org.eclipse.equinox.http.jetty (1.1.0.v20080425) "Jetty Http Service"
[Starting]
org.eclipse.equinox.http.registry (1.0.100.v20080427-0830) "Http Service
Registry Extensions" [Resolved]
org.eclipse.equinox.http.servlet (1.0.100.v20080427-0830) "Http Services
Servlet" [Starting]
org.eclipse.equinox.jsp.jasper (1.0.100.v20080427-0830) "Jasper Jsp
Support Bundle"
Re: Dependency problem: org.eclipse.datatools.connectivity.sqm.core [message #53265 is a reply to message #53093] |
Thu, 05 March 2009 14:50 ![Go to previous message Go to previous message](theme/Solstice/images/up.png) ![Go to next message Go to next message](theme/Solstice/images/down.png) |
Originally posted by: brianf.sybase.com
This may be due to a problem we discovered earlier in the week with feature
definition version numbers not behaving correctly in the DTP 1.6.2 release.
As soon as I have more details or a possible solution, I'll pass it along.
Sorry for the delay
--Fitz
"Andrea Polci" <b_apolci@libero.it> wrote in message
news:golfht$aqb$1@build.eclipse.org...
> *** Date: mercoled
Re: Dependency problem: org.eclipse.datatools.connectivity.sqm.core [message #53749 is a reply to message #53265] |
Fri, 13 March 2009 14:47 ![Go to previous message Go to previous message](theme/Solstice/images/up.png) ![Go to next message Go to next message](theme/Solstice/images/down.png) |
Hey Andrea...
Have you been able to get around this? One possibility is to simply download
the DTP 1.6.2 zip and expand it into the dropins folder.
The issue I thought it was might not actually be the culprit.
--Fitz
"Brian Fitzpatrick" <brianf@sybase.com> wrote in message
news:goootu$9as$1@build.eclipse.org...
> feature definition version numbers not behaving correctly in the DTP 1.6.2
> release. As soon as I have more details or a possible solution, I'll pass
> it along.
> Sorry for the delay
> --Fitz
>> *** Date: mercoled
Re: Dependency problem: org.eclipse.datatools.connectivity.sqm.core [message #53835 is a reply to message #53749] |
Mon, 16 March 2009 09:44 ![Go to previous message Go to previous message](theme/Solstice/images/up.png) ![Go to next message Go to next message](theme/Solstice/images/down.png) |
Brian Fitzpatrick ha scritto:
> Hey Andrea...
Just tried this but it didn't made any difference.
I think I'll make a new installation from scratch.
Andrea
Re: Dependency problem: org.eclipse.datatools.connectivity.sqm.core [message #56215 is a reply to message #53835] |
Fri, 01 May 2009 21:27 ![Go to previous message Go to previous message](theme/Solstice/images/up.png) |
Hi again...
We're trying to narrow down a reproducible scenario to try and figure out
what's going on. We've started to collect details here:
http://wiki.eclipse.org/DTP_1.6.2_Update_Manager_Issues
Please let us know if you find out anything else and we'll continue to bang
on this.
Thanks.
--Fitz
news:gpl71c$hia$1@build.eclipse.org...
>> Hey Andrea...
>> download the DTP 1.6.2 zip and expand it into the dropins folder.
> Andrea
Current Time: Sat Aug 10 07:42:15 GMT 2024
Powered by FUDForum. Page generated in 0.04802 seconds
