Re: Trac connector for Trac 0.11 [message #54777 is a reply to message #53954] |
Wed, 30 July 2008 17:46 ![Go to previous message Go to previous message](theme/Solstice/images/up.png) ![Go to next message Go to next message](theme/Solstice/images/down.png) |
Originally posted by: antoni_mylka.poczta.onet.pl
Does this mean that Trac 0.11 installations without XML-RPC
(login/xmlrpc doesn't work) are not supported at all?
Antoni Mylka
antoni_mylka@poczta.onet.pl
David Thorne pisze:
> -----BEGIN PGP SIGNED MESSAGE-----
> Hash: SHA1
> Hi Steffen,
> Bizarre but on starting Apache today with machine bootup all appeared
> well - I suspect it was a case of the problem being me forgetting to
> restart after the Trac plugin was installed.
> Thanks for the advice about /login/xmlrpc though :) I can now more
> easily test everything is working through firefox.
> Dave
> Steffen Pingel wrote:
> |> I think this is more my Apache setup than Mylyn BUT the authentication
> |> doesn't seem to work with the settings I provide (They are definitely
> |> right) When I start tracd with the necessary details the xmlrpc plugin
> |> works... (tracd --env-parent-dir /path/to/my/trac/parent-env --port 8000
> |> ) could this be related to the problem indicated at
> |> http://tjulo.blogspot.com/2007/03/problems-with-md5-and-modp ython.html?
> |> (php4-mhash and libmhash2) I couldn't see any problems with this in
> |> the Bugzilla but wasn't sure if it had already been reported and didn't
> |> wish to duplicate bug reports! (I know how tedious they are)
> | The XML-RPC plug-in relies on the webserver for authentication. You can
> | verify that in a web browser if you go to
> | http://my.trac.repository/login/xmlrpc .
> | I am not aware that problems with this setup have been reported before.
> | Please file a new bug report and provide details about the configuration.
> | Steffen
Re: Trac connector for Trac 0.11 [message #591992 is a reply to message #53954] |
Wed, 30 July 2008 17:46 ![Go to previous message Go to previous message](theme/Solstice/images/up.png) |
Antoni Mylka
David Thorne pisze:
> Hash: SHA1
> Hi Steffen,
> Dave
> | Steffen
FUDForum. Page generated in 0.04357 seconds
