Home » Eclipse Projects » DTP » Open Data Access (ODA) API Changes in Galileo
Open Data Access (ODA) API Changes in Galileo [message #52919] Wed, 04 March 2009 08:27 Go to next message
Linda ChanFriend
To all who have implemented an Open Data Access (ODA) data source extension,
please read on...
A number of enhancements have been identified in the ODA framework to
support additional features requested by the community.
Please see the following link that describes these enhancements and proposed
API changes in the org.eclipse.datatools.connectivity.oda bundle version
3.2, for release in DTP 1.7 (Galileo).
http://wiki.eclipse.org/Galileo_DTP_ODA_API_Changes_Spec
New methods will be added to the ODA Java interfaces. This means that
compiling your existing ODA runtime driver implementation with these latest
ODA interfaces would require an upgrade to implement the additional methods.
The ODA framework will provide binary backward compatibility support of an
ODA data source extension, whose source were compiled with a version earlier
than these ODA 3.2 API interfaces. If an ODA extension has not implemented a
new interface method, the ODA Consumer Helper framework will throw an
UnsupportedOperationException on its behalf.
For any comments and feedback, please add them to the project wiki page or
corresponding Bugzilla entry. These API changes are targeted to commit in
CVS later this week for the Galileo M6 milestone.
Linda Chan
DTP ODA Component Lead
Re: Open Data Access (ODA) API Changes in Galileo [message #55581 is a reply to message #52919] Thu, 16 April 2009 13:53 Go to previous messageGo to next message
As far as I can see, BIRT 2.5M6 doesn't yet support the Java Object data
type added with these changes. Will this be implemented in the final
release of BIRT 2.5?
Andreas
Re: Open Data Access (ODA) API Changes in Galileo [message #56022 is a reply to message #55581] Fri, 24 April 2009 22:46 Go to previous message
Linda ChanFriend
Yes, I'm hopeful that at least some support will get added in BIRT 2.5.
How do you intend to use the Java object data type support in BIRT? For
reporting purpose, an object data item would still be converted to a String
for the report output.
Linda
Re: Open Data Access (ODA) API Changes in Galileo [message #595511 is a reply to message #52919] Thu, 16 April 2009 13:53 Go to previous message
Andreas Mayer is currently offline Andreas MayerFriend
Member
Andreas
Re: Open Data Access (ODA) API Changes in Galileo [message #595640 is a reply to message #55581] Fri, 24 April 2009 22:46 Go to previous message
Linda ChanFriend
Linda
Previous Topic:Oracle packages listed in the content provider
Next Topic:How to get dataset filters
Current Time: Wed Jan 15 08:32:52 GMT 2025
Powered by FUDForum. Page generated in 0.02802 seconds
