Re: Agent Controller and Java 1.5/5.0 [message #52908 is a reply to message #52854] |
Mon, 06 February 2006 15:26 |
Originally posted by: nmehrega.ca.ibm.com
Although TPTP doesn't officially support JDK 1.5, I've personally tested
the profiler with JDK 1.5 and didn't find any problems. Now the test
cases obviously don't cover every single use case, but I don't really
suspect you'll find any problems using the profiler with JDK 1.5.
Navid Mehregani
Re: Agent Controller and Java 1.5/5.0 [message #52959 is a reply to message #52934] |
Mon, 06 February 2006 17:25 |
Originally posted by: jkp1974a.cox.net
Hello all ->
Thanks for your replials.
Ideally, I would like to be able to profile with the following 1.5/5.0
constructs/features:
1. Collections (Sort, etc...)
2. ArrayList/HashMap (with type parameters)
[3. for/in loop]
I am trying to profile web services. Thus, my current setup:
Windows XP SP2
Java 1.5.0_06 (5.0)
WTP 1.0 (all-in-one)
I was going to try to use TPTP 4.1; should I try the TPTP 4.2M4 release
(per Andreas's link)?
Thanks again for everyone's responses so far. If I figure something out
(or an answer to the conflicting info), I'll try to post.
Ken
Re: Agent Controller and Java 1.5/5.0 [message #52984 is a reply to message #52908] |
Mon, 06 February 2006 18:19 |
> Navid Mehregani
Is there a good link/docs on the Profiler? I was looking the other day
and came up pretty much empty handed.
Re: Agent Controller and Java 1.5/5.0 [message #53137 is a reply to message #52984] |
Tue, 07 February 2006 15:40 |
Mark,
On the TPTP website, click on Documents -> under User Guides &
Demonstrations, there is a document called "An Introduction in Profiling
Java Applications (v3.2.0)" and there is also a video called: "Demo:
Profiling an application".
Navid Mehregani
Re: Agent Controller and Java 1.5/5.0 [message #53162 is a reply to message #53137] |
Tue, 07 February 2006 16:29 |
> Mark,
> Navid Mehregani
Thanks a million. I was in the wrong place.
FUDForum. Page generated in 0.03482 seconds
