[HELP] Eclipse & Linux [message #52806] |
Sun, 20 April 2003 15:13  |
Originally posted by: nospam.brandmaier.de
Hi all!
I tried to start Eclipse (linux-gtk 2.0 and linux-gtk 2.1) but it failed!
I only get the splash screen and the following console errors:
java.lang.UnsatisfiedLinkError:
home/user/eclipse/plugins/org.eclipse.swt.gtk_2.1.0/os/linux /x86/libswt-pi-gtk-2133.so:
/usr/lib/libpangoxft-1.0.so.0: undefined symbol: FT_Seek_Stream
Can anyone help please?
Thank you,
Andy
Re: [HELP] Eclipse & Linux [message #52987 is a reply to message #52806] |
Wed, 23 April 2003 06:45  |
Originally posted by: iberthon.freenet.co.uk
In article <b7ujrf$6p3$1@rogue.oti.com>, nospam@brandmaier.de says...
> Hi all!
> Thank you,
> Andy
I had the same problem (running a patched up Debian 'Woody') After
searching the Eclipse and Gnome Bugzilla archives I discovered that it
was caused by incompatible versions of Pango and Freetype (see
http://bugzilla.gnome.org/show_bug.cgi?id=96308)
Looking through my installed packages, it looked like the packaging
system got confused somewhere and held onto old versions of fontconfig,
libfontconfig and libxft2. Once I'd manually sorted out the dependency
problems (think I ended up downgrading libfreetype6 and then applying
the updates individually) Eclipse started working again.
Hope This Helps!
Ian.
Remove 'nospam.please' when replying
Re: [HELP] Eclipse & Linux [message #593121 is a reply to message #52806] |
Mon, 21 April 2003 08:39  |
Hi!
It's me again. I now fetched an older version of the freetype6-library.
It seems that the problem is related to fonts.
Eclipse manages to start now, but there is a strange default font
and it crashes after 1 second leaving the splash screen on the
desktop... *hrmpf*
I get the error:
** ERROR **: file pangofc-fontmap.cI: line 407
(pango_fc_font_map_list_families): assertion failed: (res == FcResultMatch)
aborting...
andy ideas?
thx,
Andy
Re: [HELP] Eclipse & Linux [message #593131 is a reply to message #52859] |
Mon, 21 April 2003 10:18  |
Andreas Brandmaier wrote:
> Hi!
> desktop... *hrmpf*
> I get the error:
> aborting...
> andy ideas?
> thx,
> Andy
Are you using the minimal required version of GTK (2.0.6)? You might
get better visibility posting to eclipse.platform or eclipse.platform.swt.
David
Re: [HELP] Eclipse & Linux [message #593168 is a reply to message #52806] |
> Hi all!
> Thank you,
> Andy
Hope This Helps!
Ian.
FUDForum. Page generated in 0.03109 seconds
