relative library paths to jars outside of plugins [message #52765] |
Wed, 09 November 2005 16:28 ![Go to next message Go to next message](theme/Solstice/images/down.png) |
Originally posted by: david_dean.comcast.net
Specifying a relative path for <library>, as with "whatever.jar" in the
plugin.xml snippet below, allows the plugin to include a jar which isn't
in the plugin. This seems like it would be a bug, or is there a
legitimate reason that this is allowed?
David
<?xml version="1.0" encoding="UTF-8" ?>
<?eclipse version="3.0"?>
<plugin id="com.acme.foo" name="%pluginName" version="0.0.1"
provider-name="%pluginProvider">
<runtime>
<library name="../../../../lib/whatever.jar">
<export name="*" />
</library>
</runtime>
</plugin>
-- also posted on "platform"
Re: relative library paths to jars outside of plugins [message #53305 is a reply to message #52765] |
Wed, 16 November 2005 02:07 ![Go to previous message Go to previous message](theme/Solstice/images/up.png) ![Go to next message Go to next message](theme/Solstice/images/down.png) |
Originally posted by: jeff_nospam_mcaffer.ca.ibm.com
Hmmm, does seem like a bug but more generally the plugin.xml approach to
plugin definition is now (in 3.2) deprecated in favour of using manifest.mf.
3.1 included an experimental mechanism using external: URLs and system
properties/env vars to define classpath entries from outside the specifiying
bundle.
Jeff
"David Dean" <david_dean@comcast.net> wrote in message
news:dkt83e$pvh$1@news.eclipse.org...
> David
> <runtime>
> <export name="*" />
> </library>
> </runtime>
> </plugin>
Re: relative library paths to jars outside of plugins [message #53786 is a reply to message #53305] |
Wed, 30 November 2005 17:56 ![Go to previous message Go to previous message](theme/Solstice/images/up.png) ![Go to next message Go to next message](theme/Solstice/images/down.png) |
Jeff,
Thanks for the response. I do realize that this usage is deprecated, but
what I'm really trying to determine is whether this behavior is
intentional or a bug. If 3.1 has an equivalent mechanism then this
implies that it is a "feature" to allow plugins/bundles to reference
external jars (or other resources).
This is surprising to me since it seems to break the packaging model of
a plugin/bundle, specifically:
- it is apparently ok for a plugin/bundle to rely on the structure of a
file system outside itself
- a plugin/bundle could be updated, either intentionally or by accident,
by changing files that are outside the plugin/bundle, unbeknownst to the
eclipse update mechanisms.
I am involved in a project where this behavior is being exploited and
I'm trying to figure out whether that is ok or not.
-David
> bundle.
> Jeff
>>Thanks,
>>David
>> <runtime>
>> <export name="*" />
>> </library>
>> </runtime>
>> </plugin>
Re: relative library paths to jars outside of plugins [message #53992 is a reply to message #53786] |
Fri, 02 December 2005 01:55 ![Go to previous message Go to previous message](theme/Solstice/images/up.png) |
Hey David,
3.1 indeed has this feature but it is very much in the *experimental* realm.
It is included because several people in the community had usecases where
they had JARs in the file system that they could not move yet wanted those
JARs to be integrated into Equinox as bundles. The simplest approach was to
let them reference the external JARs from the Bundle-ClassPath of their
bundle.
This does not make it recommended or supported. The tooling does not
support it and you have to go to some hoops to get it to work. We were
going to add some poison gas and spike traps but the lawyers would not let
us.
Jeff
news:438DE7BB.30308@comcast.net...
> Jeff,
> -David
manifest.mf.
specifiying
> > bundle.
> > Jeff
> >>Thanks,
> >>David
> >> <runtime>
> >> <export name="*" />
> >> </library>
> >> </runtime>
> >> </plugin>
FUDForum. Page generated in 0.04005 seconds
