| Home » Modeling » OCL » Possible bug in the AbstractTypeResolver implementation
 Goto Forum:|
| Possible bug in the AbstractTypeResolver implementation [message #52731] | Thu, 13 March 2008 08:11  |  |
| Eclipse User  |  |  |  |  | Hi Christian,
 I think that I have encountered a little bug.
 When a TypeResolver is resolving a collection (and set, bag,etc) type,
 it tries to find the collection in the collectionPackage, and it will
 create the collection, if it is not found.
 When you pass the AnyType T, as the elementType of a collection (and
 set, bag, etc), a new type will be created in the collectionPackage,
 while the unique instance (OCLStandarddLibrary.getCollection()) should
 be returned...
 This simple code  (applied to each kind of collection) would improve the
 implementation, because and unnecessary type is not created (and used by
 expressions) when resolving Collection(T).
 // Documentation copied from the inherited specification
 @SuppressWarnings("unchecked")
 public CollectionType<C, O> resolveCollectionType(
 CollectionKind kind,
 C elementType) {
 OCLStandardLibrary<C> stdlib = getEnvironment().getOCLStandardLibrary();
 if (elementType.equals(stdlib.getT()))
 return (CollectionType<C, O>) stdlib.getCollection();
 CollectionType<C, O> result = findCollectionType(kind, elementType);
 if (result == null) {
 result = createCollectionType(kind, elementType);
 return result;
 If you agree, I could raise a bugzilla with a patch solving this little
 issue.
 Adolfo.
| Re: Possible bug in the AbstractTypeResolver implementation [message #52761 is a reply to message #52731] | Thu, 13 March 2008 09:23   |  |
| Eclipse User  |  |  |  |  | Originally posted by: cdamus.ca.ibm.com
 Hi, Adolfo,
 Absolutely, that looks like a problem worth fixing.
 Just be sure to account for the appropriate CollectionKind.  Your snippet,
 below, appears to return Collection(T) for all collection kinds.
 Thanks!
 Christian
 Adolfo Sánchez-Barbudo Herrera wrote:
 > Hi Christian,
 > be returned...
 > C elementType) {
 > return result;
 > issue.
 > Adolfo.
| Re: Possible bug in the AbstractTypeResolver implementation [message #52788 is a reply to message #52761] | Thu, 13 March 2008 10:50  |  |
 Bug raised:
 https://bugs.eclipse.org/bugs/show_bug.cgi?id=222581
 Commets in-line
 > Hi, Adolfo,
 Your are certainly right. I hadn't realized that this method manages all
 the collections. I have taken into account your comment in the attached
 patch.
 > Thanks!
 It's a pleasure.
 Adolfo.
 > Christian
 >> Hi Christian,
 >> be returned...
 >> C elementType) {
 >> return result;
 >> issue.
 >> Regards,
 >> Adolfo.
 Current Time: Fri Oct 31 04:18:22 EDT 2025
 Powered by FUDForum . Page generated in 0.04017 seconds |
