Home » Eclipse Projects » Mylyn » Is there a plan of the internationalization?
Is there a plan of the internationalization? [message #52633] Sat, 12 July 2008 00:54 Go to next message
Hiroyuki is currently offline HiroyukiFriend
Hello all!
The text in the menu and the dialog is displayed in English.
Is there a plan that internationalizes the text in the menu and the dialog?
Hiroyuki
Re: Is there a plan of the internationalization? [message #52660 is a reply to message #52633] Sat, 12 July 2008 15:35 Go to previous messageGo to next message
Originally posted by: zx.code9.com
Hiroyulki Inaba wrote:
> Hello all!
> The text in the menu and the dialog is displayed in English. Is there a
Check out Babel:
http://babel.eclipse.org/babel/
~ Chris
Re: Is there a plan of the internationalization? [message #52716 is a reply to message #52633] Sat, 12 July 2008 16:41 Go to previous messageGo to next message
> Hello all!
https://bugs.eclipse.org/bugs/show_bug.cgi?id=215116
Re: Is there a plan of the internationalization? [message #60386 is a reply to message #52660] Mon, 20 October 2008 14:16 Go to previous messageGo to next message
> Check out Babel:
It is not exist in the Babel.
I was not able to discover mylyn in Babel.
Hiroyuki
Re: Is there a plan of the internationalization? [message #60408 is a reply to message #52660] Mon, 20 October 2008 14:22 Go to previous messageGo to next message
Eugene Kuleshov is currently offline Eugene KuleshovFriend
> Check out Babel:
Chris, before anything would work with Babel, it should have all string
literals externalized in the code. That is not the case with Mylyn.
regards,
Eugene
Re: Is there a plan of the internationalization? [message #60431 is a reply to message #52716] Mon, 20 October 2008 14:23 Go to previous messageGo to next message
The reported article was not what I requested it.
It was a report to Mylyn 2.2.
It was concerning only the bugzilla function.
I am requesting the patch to the entire Mylyn 3.0.
Hiroyuki
Re: Is there a plan of the internationalization? [message #60844 is a reply to message #60431] Wed, 22 October 2008 15:44 Go to previous messageGo to next message
I starting String externalization of Mylyn 3.0.2.
First step: [Completed]
String externalization of plugin.xml and manifest.mf
Target: Mylyn 3.0.2 (SDK, Extras and Incubotor)
Second step: [Now]
String externalization in Java code
(Menu, Dialog, Message, etc)
Time is necessary by there are a lot of numbers of source file.
Hiroyuki
Re: Is there a plan of the internationalization? [message #60849 is a reply to message #60844] Wed, 22 October 2008 19:42 Go to previous message
Steffen Pingel is currently offline Steffen PingelFriend
Hiroyulki, please coordinate on this bug first:
215116: externalize Mylyn UI Strings, Labels, Messages to support
We are very interested in support for internationalizing the code base but
we need to make sure it's in a form suitable for consumption by the
project.
Steffen
> Second step: [Now]
> Thanks
> Hiroyuki
Re: Is there a plan of the internationalization? [message #591160 is a reply to message #52633] Sat, 12 July 2008 15:35 Go to previous message
Chris Aniszczyk is currently offline Chris AniszczykFriend
> Hello all!
Check out Babel:
~ Chris
Re: Is there a plan of the internationalization? [message #591199 is a reply to message #52633] Sat, 12 July 2008 16:41 Go to previous message
George Lindholm is currently offline George LindholmFriend
> Hello all!
Re: Is there a plan of the internationalization? [message #594390 is a reply to message #52660] Mon, 20 October 2008 14:16 Go to previous message
> Check out Babel:
Hiroyuki
Re: Is there a plan of the internationalization? [message #594398 is a reply to message #52660] Mon, 20 October 2008 14:22 Go to previous message
> Check out Babel:
regards,
Eugene
Re: Is there a plan of the internationalization? [message #594404 is a reply to message #52716] Mon, 20 October 2008 14:23 Go to previous message
Hiroyuki
Re: Is there a plan of the internationalization? [message #594480 is a reply to message #60431] Wed, 22 October 2008 15:44 Go to previous message
Second step: [Now]
Hiroyuki
Re: Is there a plan of the internationalization? [message #594490 is a reply to message #60844] Wed, 22 October 2008 19:42 Go to previous message
project.
Steffen
> Second step: [Now]
> Thanks
> Hiroyuki
Previous Topic:Working Set and Mylyn
Next Topic:Connector Documentation
Current Time: Fri Dec 27 01:44:15 GMT 2024
Powered by FUDForum. Page generated in 0.04143 seconds
