Launching Eclipse [message #52501] |
Fri, 15 April 2005 16:46 ![Go to next message Go to next message](theme/Solstice/images/down.png) |
Originally posted by: patty.deming.ngc.com
I've run Eclipse before, but when I try to launch today I get a startup
error with the following log file.
*** Installation Started 05/04/2004 15:22 ***
Title: Wise Test Package Installation
Source:
C:\PROGRA~1\ALTIRIS\EXPRESS\NSCLIE~1\SOFTWA~1\SOFTWA~1\{2A60 1~1\TestPkg4.exe
| 04-29-2004 | 14:11:26 | 264715
RegDB Key: Software\\
RegDB Val: 05/04/04 15:22:53
RegDB Name: Date/Time
RegDB Root: 1
RegDB Val: Failed Drive Space
RegDB Name: Status
RegDB Root: 1
RegDB Val:
RegDB Name: UserName
RegDB Root: 1
The file 'C:\WINNT\TEMP\GLF27B.tmp' could not be opened. Please check that
your disk is not full and that you have access to the destination
directory. The process cannot access the file because it is being used by
another process.
I have hard disk space and access to the TEMP folder. However, there isn't
a GLF27B.tmp file. I tried to downloading Eclipse again and re-launching,
but I still get the same error message. Please help. Need to finish my
class work in the next couple of days.
Re: Launching Eclipse [message #52527 is a reply to message #52501] |
Fri, 15 April 2005 17:17 ![Go to previous message Go to previous message](theme/Solstice/images/up.png) |
Originally posted by: jaredburns.no.spam.acm.org
Have you added any plugins or are you just using the Eclipse SDK? That
error really looks like something from a third-party plugin; I can't
think of anything in the SDK that reads or writes to the Windows temp
folder.
The error message you pasted talks about "Altiris".
- Jared
> Source:
> RegDB Root: 1
> RegDB Name: Status
> RegDB Root: 1
> RegDB Val: RegDB Name: UserName
> RegDB Root: 1
> that your disk is not full and that you have access to the destination
> by another process.
> isn't a GLF27B.tmp file. I tried to downloading Eclipse again and
> re-launching, but I still get the same error message. Please help. Need
> to finish my class work in the next couple of days.
FUDForum. Page generated in 0.08095 seconds
