Home » Modeling » TMF (Xtext) » Enabling a DSL editor to open concrete model files
Enabling a DSL editor to open concrete model files [message #52492] Tue, 23 June 2009 11:55 Go to next message
Hello All
I want to somehow facilate the opening of .xmi files of concrete model in
a DSL Editor.
For Example consider:
sample1.xml
<datatypes:PrimitiveDataType xmi:version="2.0"
xmlns:datatypes="http://q-impress.eu/samm/datatype"
id="_e94SQF8FEd6mb4izF2cfPA" documentation="" name="pr_01" type="int"/>
I want to be able to open this .xml file in the DSL editor as:
PrimitiveDataType id:"_e94SQF8FEd6mb4izF2cfPA"{
doc:"";
type:1;
Is there any way that this can be accomplished?
If my objective is unclear then, pls let me know and I shall elaborate it.
Thanks.
Durga
Re: Enabling a DSL editor to open concrete model files [message #52603 is a reply to message #52492] Wed, 24 June 2009 07:10 Go to previous messageGo to next message
Durga,
This is possible, but I don't think that it is simple. The main
issue arises because you have two concrete syntaxes for your
model. You could create an Xtext based DSL that uses your
'editor' syntax. However, this would also persist your model in
the same syntax.
One way to get around this would be to intercept the load
and save methods of the Xtext DSL and copy the contents
of the resource to/from one with an .xmi extension and use the
load and save methods on this resource. Note, this only
works if the two concrete syntaxes do truely share a single
meta-model.
Andy.
"Durga Prasana Sahoo" <durga.spirit@gmail.com> wrote in message
news:2870ff1edb4a9b70640b9edb8d362171$1@www.eclipse.org...
> Hello All
> a DSL Editor.
> sample1.xml
> xmlns:xmi="http://www.omg.org/XMI"
> doc:"";
> type:1;
> Thanks.
> Durga
Re: Enabling a DSL editor to open concrete model files [message #52793 is a reply to message #52492] Thu, 25 June 2009 03:49 Go to previous message
Hi Durga,
I think I understood what you described, however I've no idea about the
usecase. Maybe there are other ways to achieve what you want. Would you
please be so kind an elaborate a bit on it from a more user oriented view?
Andy was right, there would be some work to do, if you want to create
such a projection-based editor for your xmi-file.
Sebastian
Am 23.06.2009 17:55 Uhr, schrieb Durga Prasana Sahoo:
> Hello All
> in a DSL Editor.
> sample1.xml
> doc:"";
> type:1;
> Thanks.
> Durga
Previous Topic:Visiting a Tree of a Model
Next Topic:Documentation question
Current Time: Sat Oct 25 08:51:29 EDT 2025
Powered by FUDForum. Page generated in 0.04155 seconds
