Home » Eclipse Projects » Eclipse Platform » How do I know build is successful?
How do I know build is successful? [message #52315] Wed, 28 May 2003 15:34 Go to next message
Originally posted by: wgyun.hotmail.com
Hi there,
I have to use IProject.build function, is there a way that I know whether
the build is successful or not, since my next action after the build is try
to package the class files depends on build result, but unfortunately, I
haven't found out a way to detect that. Can anyone shed some light on this?
Much thanks!
Re: How do I know build is successful? [message #54177 is a reply to message #52315] Thu, 29 May 2003 12:19 Go to previous messageGo to next message
A bit of a guess, but may help: I'd look for IMarkers on your resources that
are of the appropriate type (you say "class files" so I assume you are building
a java/plugin project). The type would be IMarker.PROBLEM, and you can find
them on a given IResource using the instance method findMarkers(String type,
boolean includeSubtypes, int depth); probably you'll want to use an
IResourceVisitor implementation to look for them.
HTH,
Paul K
Cindy Wen wrote:
> Hi there,
> Much thanks!
Re: How do I know build is successful? [message #54345 is a reply to message #54177] Thu, 29 May 2003 12:41 Go to previous messageGo to next message
Actually I have the same idea with you but just wondering there might be an
easier way, seems I can't be lazy :-)
Thanks!
"Paul T. Keyser" <rolarenfan@earthlink.net> wrote in message
news:3ED63303.B28E39FE@earthlink.net...
that
building
find
type,
> HTH,
> Paul K
> Cindy Wen wrote:
> > Hi there,
whether
try
this?
> > Much thanks!
Re: How do I know build is successful? [message #56632 is a reply to message #54345] Fri, 30 May 2003 15:57 Go to previous message
Originally posted by: John_Arthorne.oti.com_
The java builder produces markers of type:
IJavaModelMarker.JAVA_MODEL_PROBLEM_MARKER
So, you can find them like this:
project.findMarkers(IJavaModelMarker.JAVA_MODEL_PROBLEM_MARK ER, true,
IResource.DEPTH_INFINITE);
> Thanks!
> that
> building
> find
> type,
>>HTH,
>>Paul K
>>Cindy Wen wrote:
>>>Hi there,
> whether
> try
> this?
>>>Much thanks!
Previous Topic:Currupt workspace.... how to restore projects?
Next Topic:Using Different Project Files
Current Time: Fri Apr 25 23:22:23 EDT 2025
Powered by FUDForum. Page generated in 0.03335 seconds
