Home » Archived » Visual Editor (VE) » Custom Controls in VE & Other questions
Custom Controls in VE & Other questions [message #52291] Wed, 28 July 2004 21:02 Go to next message
Originally posted by: mlopez.voicerite.com
Is there support for the Custom Control set from within VE ? Are there
any plans on supporting them ? Or do I have to stick dummy label objects
in places where I'd want a TableTree ( for instance ), and then replace
the label within the code by hand ?
Also, are there any plans to add things like a "property editor" to VE,
like you find within RAD IDE's like Visual Studio ?
Marcelo R. Lopez, Jr.
mlopez@voicerite.com
Re: Custom Controls in VE & Other questions [message #52318 is a reply to message #52291] Wed, 28 July 2004 21:45 Go to previous messageGo to next message
Originally posted by: richkulp.NO.SPAM.us.ibm.com
WE need more info on what you are saying?
SWT Custom controls will be picked up as we get to them. Some you can
drop already, they just act as a black box in that we don't know there
is anything special about them and think they just inherit from
Composite. Because of this we may allow some things that we shouldn't,
like allowing to drop children controls on it. It all depends on the
control itself with what VE will do with it.
You can add property editors already. We never stopped you. What kind of
property editors are you talking about? We support out-of-the-box
property editors that follow the Java Bean specification and are on the
BeanInfo for a class.
Thanks, Rich Kulp
Re: Custom Controls in VE & Other questions [message #52442 is a reply to message #52318] Thu, 29 July 2004 14:56 Go to previous messageGo to next message
Thanks for the speed response Rich. I mean in specific TableTree, etc. I
don't see them on the palette.
Also, would you happen to know where this library might be found, or
what package I have to install to get it ?
>>>>>>>>> import org.eclipse.ui.part.ViewPart; <<<<<<<<<
Where is this library supposed to be...I've downloaded and installed:
Eclipse 3.0
EMF
GEF
and VE
and it's not there.....
Re: Custom Controls in VE & Other questions [message #52463 is a reply to message #52442] Thu, 29 July 2004 15:12 Go to previous messageGo to next message
Marcelo,
You can drop a TableTree using the Choose Bean dialog. Because we don't
have beaninfo for this class, the style bits will not show up on the
property sheet. This list of SWT controls we're attempting to support
in this version is available here:
http://dev.eclipse.org/viewcvs/indextools.cgi/%7Echeckout%7E /vep-home/WebContent/docs/v1.0.0/line-items/index.htm
(in addition, we've added Browser and SashForm in the lastest code in CVS)
org.eclipse.ui.part.ViewPart is in the org.eclipse.ui.workbench plugin.
- Jeff
> Eclipse 3.0
> EMF
> GEF
> and VE
Re: Custom Controls in VE & Other questions [message #52490 is a reply to message #52463] Thu, 29 July 2004 16:26 Go to previous messageGo to next message
Jeff Myers wrote:
> Marcelo,
> - Jeff
Thank you, Sir.
Can Eclipse Forms be used to create stand alone applications ? Or are
they by definition, bound to only run within the workbench environment ?
Marcelo
Re: Custom Controls in VE & Other questions [message #52517 is a reply to message #52490] Thu, 29 July 2004 16:50 Go to previous messageGo to next message
Marcelo,
The org.eclipse.ui.forms plugins requires org.eclipse.ui, which requires
org.eclipse.core.runtime
org.eclipse.help
org.eclipse.swt
org.eclipse.jface
So yeah, it looks like forms is meant to be used only in Eclipse or an
RCP environment.
- Jeff
> Jeff Myers wrote:
>> Marcelo,
>> don't have beaninfo for this class, the style bits will not show up on
>> the property sheet. This list of SWT controls we're attempting to
>> support in this version is available here:
>> CVS)
>> - Jeff
> Thank you, Sir.
> Marcelo
Re: Custom Controls in VE & Other questions [message #52543 is a reply to message #52517] Thu, 29 July 2004 17:53 Go to previous message
Jeff Myers wrote:
> Marcelo,
> org.eclipse.help
> org.eclipse.swt
> org.eclipse.jface
> RCP environment.
> - Jeff
Just one word......bummer.
Marcelo
Re: Custom Controls in VE & Other questions [message #595966 is a reply to message #52291] Wed, 28 July 2004 21:45 Go to previous message
Thanks, Rich Kulp
Re: Custom Controls in VE & Other questions [message #596013 is a reply to message #52318] Thu, 29 July 2004 14:56 Go to previous message
Eclipse 3.0
EMF
GEF
and VE
Re: Custom Controls in VE & Other questions [message #596021 is a reply to message #52442] Thu, 29 July 2004 15:12 Go to previous message
Jeff Myers is currently offline Jeff MyersFriend
Marcelo,
- Jeff
> Eclipse 3.0
> EMF
> GEF
> and VE
Re: Custom Controls in VE & Other questions [message #596029 is a reply to message #52463] Thu, 29 July 2004 16:26 Go to previous message
Jeff Myers wrote:
> Marcelo,
> - Jeff
Thank you, Sir.
Marcelo
Re: Custom Controls in VE & Other questions [message #596037 is a reply to message #52490] Thu, 29 July 2004 16:50 Go to previous message
Marcelo,
org.eclipse.help
org.eclipse.swt
org.eclipse.jface
RCP environment.
- Jeff
> Jeff Myers wrote:
>> Marcelo,
>> CVS)
>> - Jeff
> Thank you, Sir.
> Marcelo
Re: Custom Controls in VE & Other questions [message #596045 is a reply to message #52517] Thu, 29 July 2004 17:53 Go to previous message
Jeff Myers wrote:
> Marcelo,
> org.eclipse.help
> org.eclipse.swt
> org.eclipse.jface
> RCP environment.
> - Jeff
Marcelo
Previous Topic:Latest VE Integration Build and what is JEM download?
Next Topic:Browsing the VE Source
Current Time: Wed Jan 15 13:58:10 GMT 2025
Powered by FUDForum. Page generated in 0.05272 seconds
