Re: Can't seem to break in around advice [message #52284 is a reply to message #52255] |
Wed, 25 May 2005 16:06 |
Originally posted by: mchapman.uk.ibm.com
Hi Barry,
Your around advice is being inlined. You can disable this optimization
under AspectJ Compiler > Advanced > No inline
Matt.
On Wed, 25 May 2005 09:20:48 -0700, Barry Kaplan wrote:
> In the following code, I set a breakpoint at the first line in the
> around advice. The advice gets executed, but the breakpoint never hits:
> void around() : log4jLoggingInit() {
> PropertyConfigurator.configureAndWatch("log4j.properties",
> 1000);
> If I change the advice to invoke a method, and set the breakpoint on the
> first line of the method, the breakpoint /does/ get hit:
> initLogging();
> private void initLogging() {
> 1000);
> Has anyone else experienced similar problems?
> -barry
Re: Can't seem to break in around advice [message #588396 is a reply to message #52255] |
Matt Chapman Messages: 429 Registered: July 2009 |
Hi Barry,
Matt.
> 1000);
> initLogging();
> 1000);
> -barry
FUDForum. Page generated in 0.03753 seconds
