CalendarCombo bug? [message #52175] |
Wed, 30 April 2008 10:46  |
I have tried CalendarCombo and if I edit by hand the edit field without
using the calendar popup, the date isn't really updated.
DateChooserCombo has similar problems when modifying the edit field.
Is this a known issue?
Re: CalendarCombo bug? [message #52369 is a reply to message #52253] |
Wed, 07 May 2008 06:01  |
Emil Crumhorn wrote:
> This bug has recently been fixed along with other updates. Due to nightly
> builds not working, please download the CVS code and try that, it should
> fixe your problem.
> Emil
> "David Perez" <craquerpro@yahoo.es> wrote in message
> news:d250b860c15368202d3a3beb47271261$1@www.eclipse.org...
Re: CalendarCombo bug? [message #589530 is a reply to message #52175] |
Wed, 30 April 2008 10:48  |
Another issue, the order of the date and month doesn't take into account
the current locale.
I have a Spanish locale set, and the month is shown before the date.
DateChooserCombo works ok.
David Perez wrote:
Re: CalendarCombo bug? [message #589552 is a reply to message #52175] |
Wed, 30 April 2008 19:28  |
fixe your problem.
Emil
Re: CalendarCombo bug? [message #589559 is a reply to message #52202] |
Wed, 30 April 2008 19:56  |
That is/was a bug indeed. Surprised I hadn't implemented that. I've made all
the appropriate code changes and committed new code to CVS. This will add a
method you can override as well in the settings called getLocale(). By
default it will return Locale.getDefault(), so if you're on a Spanish locale
and your Windows is set up as such, it should default to Spanish.
Let me know if you still run into issues,
Emil
news:467ebb16a6c2eed914467e7b22a41fcd$1@www.eclipse.org...
> the current locale.
> David Perez wrote:
Re: CalendarCombo bug? [message #589597 is a reply to message #52253] |
> fixe your problem.
> Emil
FUDForum. Page generated in 0.05067 seconds
