Home » Archived » XML Schema Definition (XSD) » order of attributes when writing a schema
order of attributes when writing a schema [message #52135] Wed, 01 September 2004 20:03 Go to next message
Originally posted by: gj.puredge.com
Is there a particular order of element attrinutes when writing out a schema.
For example, an element gets written as:
<xsd:element minOccurs="0" maxOccurs="1" name="NewField" type="xsd:string"/>
If I edit the xsd file and change the order, name first for example, it will
be written in that same order once I load it again and re-save.
Is there a way to control this?
Gary
Re: order of attributes when writing a schema [message #52163 is a reply to message #52135] Thu, 02 September 2004 06:08 Go to previous message
Gary,
I believe that the underlying DOM typically sorts the attributes
alphabetically and serializes them that way. I've found it annoying
too, but I've seen no way around it. If anyone does, I'd be interested.
>Thanks
>Gary
Re: order of attributes when writing a schema [message #591277 is a reply to message #52135] Thu, 02 September 2004 06:08 Go to previous message
Gary,
>Thanks
>Gary
Previous Topic:order of attributes when writing a schema
Next Topic:Getting an element's Children and grand-children!!
Current Time: Tue Sep 16 05:44:33 EDT 2025
Powered by FUDForum. Page generated in 0.04137 seconds
